Question about General Electric Stove/Oven/Range Chrome Timer Knob Set - WB3X459
I have a GE slide in stove/oven that is showing a "F-1" code on the display. What does this mean?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F1 error indicates that the control board (ERC) has gone bad and the electronic range control (ERC) should be replaced to resolve the issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 16, 2010
Getting a PF7 code with beeping on my stove. Reset breaker, didn't fix it. Any help would be appreciated.
GE oven error code "F7" and how to fix it ' AskGene.com
www.askgene.com/.../oven...codes/ge-oven-error-code-f7-and-how-to-fi...
Jun 23, 2007 - The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic ... We have a GE Spectra Oven - GAS - we keep getting F7 errorcodes and the oven will not heat. ... In my case it was the keypad.
Why is my GE Range model number JBP80SM2SS making ...
www.shopyourway.com > Manage My Life > Questions
Apr 6, 2010 - Get shopping advice from experts, friends and the community! I was boiling water on back burner of ceramic stove top GE range Model ... When anyappliance picks up an error code or starts beeping the problem that caused it ...
Jan 08, 2016 | GE Profile 30" Self-Cleaning Slide-In...
I need Please a solution to F1 Error Code on GE/Kenmore electric ovens Model # 911.4658815 Thanks E-mail: elylimo@gmail.com I have the same model number. 9114658811 and plugged in the stove for the...
To my understanding error code F1 would indicate a faulty control board, possibly thermistor control. The only recourse is to have this replaced.
This of course would require a fair familiarity of electrical/electronic components/circuitry and safety procedures, use of a DVM and possibly a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 13, 2008 | Kenmore 46123 Stainless Steel Electric...
Display shows door not closed for self cleaning when door is closed
think it means lock door . there might be a sliding lever between the cooktop and oven door slide it to the right .
Feb 20, 2015 | GE JKP20 Electric Single Oven
Ge jsp 40 code f2 apears on display when trying to turn off oven
f2 means excessive oven temperature.
check the temperature sensor
Dec 15, 2014 | GE Kitchen Ranges
I can't get my clock set on my GE stove model # JB645DT1BB It said to hold for 3 seconds to change the time but it doesn't change. HELP Please
To Set the Clock
The clock must be set to the correct time
of day for the automatic oven timing functions
to work properly,The time of day cannot be
changed during a delayed cooking or a delayed
self-cleaning cycle,
1. Touch the Clock pad twice.
For models without a Clock pad:
Hold the + and - pads for 3 seconds.
2. Touch the + or - pads.
If the + or - pads are not touched within one
minute after Step 1, the display reverts to the
original setting. If this happens, repeat Step 1
and reenter the time of day.
3. Touch the Start/On pad until the time of
day shows in the display. This enters the
time and starts the clock.
To check the time of day when the display is
showing other information, simply touch the
Clock pad. The time of day shows until another
pad is touched.
http://www.managemylife.com/mmh/owner_manuals/138431/GE-Free-Standing-Electric-1112529L
Sep 19, 2013 | General Electric Stove/Oven/Range Chrome...
How to remove the touchpad on ge profile stove, I have f7 code
On most GE ovens you open the door and across the bottom of the control panel there are 3 1/4 inch screws, one in the center and 2 on either end going straight up into the console. remove the screws and slide the control panel up then out to you. Thats how you do it.
Aug 28, 2011 | GE Profile JTP18 Electric Single Oven
Where can I get a code book for GE troubleshooting of stove. I keep getting a loud beep and a code F 1 appears. What does F1 mean
Hello & Welcome to FixYa
F1 error code in your Kenmore is displayed when the oven temperature sensor goes bad, before replacing this sensor you can check it with a voltmeter. If it reads between 1050-1100ohms then it means that the temperature sensor is fine and the electronic control board needs replacement. However, after reading your question replacing the sensor is recommended repair. Please get back to me if you have any other questions.
Kevin
Dec 12, 2010 | GE Microwave Ovens
How to use stove timer for auto oven?
See if this helps. Page 26 shows a digital clock. Even if the buttons and knobs are different on yours the procedure may be the same.
http://genet.geappliances.com/DocSearch/pdf/49-4751.PDF
Oct 21, 2009 | General Electric Stove/Oven/Range Chrome...
Ge oven codes
F2 means your oven temp got too high. At least, that's what the control boards thinks. More than likely you have a bad oven sensor or bad wire to it or a bad connection somewhere between the board and sensor.
Dec 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
F3 display on ge xl44 model oven
The stove is detecting a temperarute issue. replace your rtd sensor. if the problem remains replace the control. if your slide your sange out then on the back of it should be a tech sheet with this information.
Nov 27, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
General Electric Stove/Oven/Range Chrome Timer Knob Set - WB3X459 Logo
73 people viewed this question
Top General Electric Hardware & Accessories Experts
jdthefixer
Craig Butler
Craig Butler
Are you a General Electric Hardware and Accessory Expert? Answer questions, earn points and help others
