Question about RCA 3-Device Universal Remote with Dedicated DVD Menu Key
I have a rcr312wr,I lost manual,I want conect it to dvd samsung...which is the code and the steps???
    President:
  • 1,932 Answers
HI,
Direct Code Entry:
Find the code your device.
1. Press and hold "CODE SEARCH".
2. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
3. Enter the 3-digit code number.
4. Release "CODE SEARCH".
5. With the device on, press another button to test (volume control/power button).If it does not work, repeat steps 1 to 5 with other codes which you have.
follow the below steps to set remote without codes
Code Search:
1. Turn on the device you wish to control.
2. Press and hold "CODE SEARCH".
3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
5. Press ON/OFF repeatedly until the device turns off.
6. When the device shuts off press and release ENTER.
7. Try using the remote. If it does not function repeat steps 1 through 6
To Get The Code Please Go To Below Website:
http://www.rcaaccessories.com/remotefinder/
You need to select the following information from the drop down list
1.Model of the remote
2.Type of device to which you want to program(TV/DVD/VCR)
Thank you
Posted on Sep 16, 2010
Sansui code list
2968,2927,2922,9217. Try these codes. If you wish to get more codes and other details. It has setup code list, and setup procedure to many popular brand remote controls.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Dec 31, 2013 | RCA Remote Control RCR312WR p/n:RCR312WR
I lost the page of codes of the remote control rcr312wr it's a RCA
The code list is available from the RCA Audio Video Device support site: http://rcaaudiovideo.com/remotes/2-3-devices/?sku=RCR312WR . Click on the Support/Manuals tab and the link for a PDF of the code list is at the bottom of the page.
I hope this helps.
Feb 25, 2011 | Televison & Video
I lost the code book to the remote>can you send
Try the following procedure:
Code Retrieval on the RCA RCR312WR 3 Component Remote Control
1.Press and hold the component key (TV, VCR•DVD, SAT•CBL) whose code you wish to retrieve. The illuminated ON•OFF key turns on.
2.While holding the component key down, press and hold the INFO key. The illuminated ON•OFF key turns off.
3.After holding down both keys for three seconds, the illuminated ON•OFF key turns back on.
4.Release both keys. The illuminated ON•OFF key remains on.
5.Point the remote directly at the component for which you want to find the codes. Then, starting with the number 1 key, press and release each number key on the keypad in the following order (1-9, then 0). The number that causes the illuminated ON•OFF key to blink is the first number of the code. As you find each number of the code, write them down for future reference.
Note: All TV codes begin with the number 1; all VCR codes begin with the number 2; all DVDs, the number 3; and all satellite receivers and cable boxes, the number 5.
6.Repeat step 5 until you have retrieved all four numbers in the code.
7.After the fourth number is retrieved, the illuminated ON•OFF key blinks briefly, then turns off.
8.To exit the Code Retrieval Mode, press and release the GO BACK key at any time.
9.If you press an invalid key during the Code Retrieval process, the remote will not respond. If you do not press a valid Code Retrieval key (TV, VCR•DVD, SAT•CBL, INFO, GO BACK), Code Retrieval times out after 15 seconds. The illuminated ON•OFF key blinks four times, and then turns off.
Hope this helps.
Feb 24, 2011 | RCA RCR312W Remote Control
Cant get dvd player to work on samsumg 6
check the cable and conexion that worked good.
check region dvd format/image for example ntsc or pal
check region tv format for example ntsc or pal
conect your dvd in other tv or lcd or crt and checking
conect your dvd in audio component or home sound
oh, read step by step the manual of tv and dvd manual...
bye....
Mar 07, 2010 | Samsung LA40A450 40 in. LCD TV
Samsung DVD-V3500 Remote control code
SOME UNIVERSAL REMOTES HAVE AN AUTO FIND FEATURE FOR THE CODE, READ THAT PARTICULAR REMOTES USER GUIDE FOR DETAILED INFO. YOU MIGHT ALSO TRY COPYING AND PASTE THIS QUERY (Samsung DVD-3500 Remote control code) INTO YOUR GOOGLE SEARCH WINDOW THE RESULTS PROVIDE VARIOUS SITES WITH MANY CODES FOR SAMSUNG EQUIPS
Jan 11, 2018 | Samsung DVD-V3500 DVD Player/VCR
RCA 3-Device Universal Remote with Dedicated DVD Menu Key Logo
703 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
