Question about Dell Latitude D600 Notebook
My battery won't charge on my latitude d600 - Dell Latitude D600 Notebook
  • 2,567 Answers
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Posted on Sep 15, 2010
Dell latitude won't charge
The internal battery may need replacement, especially if you have had this Notebook for several years
Mar 22, 2013 | Dell Latitude D600 Notebook
The battery of my Dell Latitude D600 is not charging fully. It only runs for 10 minutes when fully charged. Moreover, the battery indicator flashes 4 times red and one time green. Is it the battery problem...
That sounds like a bad battery. Be sure not to leave charger plugged into your computer while not plugged into power or the power switched off. That will really kill your weak battery and then you won't have 10 minutes. You can live okay with a battery like yours but if you ever need to replace ram or do a serious BIOS update the bad battery will not alallow it.
Sep 12, 2012 | Dell Latitude D600 Notebook
In my dell lattitude600 the battery status is idle thats why its not chraging.then what can i do to cherge battery again
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Aug 20, 2011 | Dell Latitude D600 Notebook
Charging problem
Charging port needs re-soldering.
Jul 30, 2010 | Dell Latitude D600 Notebook
D600 monitor is blank after I unplugged power cord
Your battery got fried Try replace with a new battery.
Jul 28, 2010 | Dell Latitude D600 Notebook
Latitude D600 not Charging batteries
Seems need to get another Battery.
Jul 23, 2009 | Dell Latitude D600 Notebook
Dell Latitude D 600 battery is not being charged
some problemwith ur motherboard circuit..so check up in service center...
Dec 01, 2008 | Dell Latitude D600 Notebook
Does not boot up
my laptop is very slow why?
Mar 17, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 new battery won,t charge
the charger in the laptop is not functioning. pc will need repaired
Dec 28, 2007 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
35 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
