Question about Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500
I have a pouland pro 250e weedeater. Runs for a while then stops. I replace fuel line and filter. Is there any specific length of fule line that should be in the gas tank. I am thinking that it may not be getting gas.
  • Poulan Master
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me
Posted on Sep 15, 2010
How do the fuel lines in a weedeater trimmer pe550 hook up inside the gas tank
I have an older model that has a weighted filter in the tank. The filter flops around and can 'fall' into the fuel no matter which way you tilt the trimmer/tank. You should have one in your tank. Feed in the new line and make the end come out the gas cap. Push the filter/weight into the end of the fuel line. Pull the extra fuel line out of the tank to match the original position. You should have cut the new line to approximately the proper or same length as the old fuel line with an angle cut so you could push it into the tank.
Jul 23, 2014 | Poulan Craftsman/poulan/weedeater Fuel...
Need to know how fuel line end in fuel tank on a weed eater. have two lines. on large one small witch line dose the filter fit on and were does the onther line stop inside the tank
Your Craftsman trimmer is made my Poulan/Weedeater and uses 2 different sized lines. The smaller diameter line is the fule supply line and runs from the pickup filter in the tank to the supply side of the carb. The supply side is usually the lower of the fuel nipples on the carb. Make sure to put enough line in the tank so the filter can drop to the lowest point of the tank while you are trimming. The larger diameter line is the return line, and will connect to the nipple on the carb that is closest to the primer bulb. From the factory, the return line went into the tank and had a small clear plasted connector on the end to prevent it from slipping back out of the tank. This fitting does not connect to anything in the tank, it is merely a return line. If the return line fitting is missing, just make sure to leave a couple of inches of line in the tank. If the filter is missing, you MUST replace it...it will save you from having to clean the carb out every 10 minutes of run time.
Aug 29, 2010 | Craftsman 25cc Gas Line Trimmer
I have a weedeater xt 200 trimmer. The parts in
The tube in the tank is the fuel pickup line and goes directly to the carburetor. You will need to get NEW fuel lines. Fish or shake the old parts out of the fuel tank after draining. Inside the tank will be a small length of smaller diameter fuel line that connects to the small fuel filter and there will be a small nylon line connector that is plugged into the end of the larger diameter fuel line which is the fuel return line from the primer bulb back to the fuel tank. That line ends just inside the fuel tank and is held there by the small nylon line connector. The other line (smaller diameter) needs some length inside the tank so it can flop around as you move the machine enabling it to always pick up fuel. 6" or so is about right from the hole in the bottom (or top) of the tank to the fuel filter. Buy long enough lengths of fuel line that they can be inserted into the tank and pulled thru the fill cap area and then have the parts put back on them and then cut to the correct length from the fuel tank to the carburetor and/or primer bulb. Buy about 1 foot of each size line needed. Small engine repair shops have it and sell it..not expensive.
Jul 18, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
How to replace gas lines on a Weedeater Excaliber Hedge Trimmer
My Bolens Weedeater runs for 3 or 4 seconds and stop but it will run only if I drop some gas in the caburator then stop. Can you help me with this problem?
Norris.
Sep 25, 2009 | Garden
WeedEater Featherlite String Trimmer fuel leak.
give it a week to see if the fuel hose swell and stop leak sometimes i have the same problem.
and ill wait for a week and it quits leaking.try that
Jul 30, 2009 | Garden
Replaced Poulan 25cc weedeater fuel lines/Now no start
You have/had a fuel filter in the tank.The connector goes to that filter, I think. The length does mean something but I don't know any way to figure it without a manual. You could try to figure from the total length. The fuel filter hold the line toward the bottom. Good luck.
Jul 11, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
This is a Poulan Pro Link model PPB 250E week
Take the casing off of trimmer and see if the one of the wires to the on/off switch is touching the engine.
Or it may even be a fuel line. If this is the case, look for damage to the fuel lines as well.
Jim
Jun 07, 2009 | Poulan Garden
Stihl weed eater runs 2min. then stop
Stihl weedeater was running and stopped suddenly. Put in a new fuel filter and cleaner air filter with soap and water. Checked spark plug and it appeared fine. Started the weedeater, ran for a second or so and stopped. Spark plug wasn't gas fouled. Could it be the carburetor needing new diaphram gasket and spring.
Apr 23, 2009 | Ryobi Garden
Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500 Logo
434 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
