Question about Thermador C301U Electric Single Oven
Indesit Single Electric Fan Oven - grating noise from cooling fan
Switch the oven on and everything's fine, ie oven circulating fan comes on and the oven starts heating. However, when the oven gets hot it starts making a grating noise and the oven circulating fan stops. We thought the problem was the internal oven fan but when we took the back off the oven it is clear that it was something to do with the cooling fan on top. If we were to replace this item (is this simple to do?) would this solve the problem, or is the problem likely to be something else which is causing this result?
Hope you can help?
  • embedded1 Oct 29, 2008
    Mine doesn't make the grating noise. It simply cuts out in the middle of cooking. The screen goes blank, light inside goes out but a fan continues to operate, blowing heat out from the sides and above the door of the oven. Seems like a design fault. Any ideas what needs replacing and how to get to it? Thanks.
  • 35 Answers
SOURCE: Heating elements do not heat
this problem your having is some connected with your oven shut down thermostat.if that does not solve your prob.next solution would be to check that control board.
Posted on Jun 25, 2007
watugot
  • 290 Answers
SOURCE: Convection/Conventional in same unit SC302ZS
If this oven works the same as the 302T, the bake element is not used during convection mode, only the convection element.
The cooling fan must come on
The air switch must close
The convection element must be good
I would suspect the element first.
Post back and let me know what you find out.
Posted on Nov 16, 2007
Rotu
  • 175 Answers
SOURCE: Thermador Built-in Oven Model SMW272
usually this is because you have the connecter on the touch pad off by a pin or not seated well. sometimes all it takes is taking the front touch panel off, re seating the connectors, and putting it back together. these thermadores are very sensitive to it for some reason. if all else fails, take all of the small multi pin wire connectors off one by one and re seat them. it should take care of the problem if it wasnt there before you started. good luck!
Posted on May 15, 2008
SOURCE: Thermadore SC272P door won't open after self cleaning
OK...you need to replace the lock, but first you need to get the darn think open. I looked at it, couldn't figure out how, and left it. My 14 yr old starting looking at it (after the kids had their TV, Ipod, etc taken away from him for the weekend.....) and he took a coat hanger from the side to pull the latch open.
The rest is straightforward sheet metal disassembly except for the front panel...label the connectors with a piece of tape before you pull the cables connecting the front panel (unless you are able to read a schematic). You can buy the part from AppliancePartsPros.com
AP2836100 (486324) Latch, door (microwave)
for about $100....next day delivery, and your ready to cook your Christmas goose!
Posted on Nov 14, 2008
SOURCE: thermador SC302 double oven the top oven is not getting hot
Thermador double oven, in Montreal Quebec. Similar problem with the display fading out. Thermador should step up to the plate or be obliged to through legal action.
Posted on May 02, 2010
Noise when oven running and stops when oven stops
Is it a convectional oven? If so, this is the fan turning on to circulate the heat. Being an electric oven, there really shouldn't be any noise whats so ever when on. I suspect your have a convectional oven and the fan is making the noise...either because it is working fine...or because its not and needs to be replaced.
Dec 02, 2013 | Thermador SC272T Electric Double Oven
Should the fan on my built in electric convection oven come on during normal 'bake' mode (ie not 'convect' mode ?
There is a fan for cooling down whole oven, it can turn on and off during the regular bake or broil cycle to cool down the oven on the outside. It's controlled by its own thermostat, so it will even stay on for awhile when you turn the bake off.
Mar 03, 2010 | KitchenAid KEBC107 Electric Single Oven
Oven set to 350F, using type k thermocouple , omega, left reading 370F, right side reading 389F, noticed the cooling fan is not running, baking problems, too ho.
You will not get an even temperature if the circulating fan is not working.
You need to check the fan control circuit and find out why the fan is not coming on, possibly a failed switch relay?
Jan 11, 2010 | GE JKP15 Electric Single Oven
Indesit FIE 56 K.B GB oven The circulation fan is squeeking
The symptons you describe are typical of the fan motor bearings failing. you could try spraying the bearings with WD40, but this would only be a temporary solution, in the end you will probably have to replace the fan motor complete.
Hope this helps.
Jan 07, 2010 | KitchenAid KEBC101 Electric Single Oven
Ge oven turns off by itself, and sometimes gives
F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F2
Note: Also see fan thermal switches Indicates that oven is over temperature in one of the following modes within either a cooking or clean mode of operation.
· Control senses oven temperature above 650 degrees F with the door circuit in the unlock mode.
· Control senses oven temperature above 935 degrees F with the door in the locked mode.
· Stalled cooling fan or airflow problem. · Look for welded relay contacts. (Heating elements on in off mode).
· Look for open thermal switch in lock motor circuit. Switch is normally closed and will open if area overheats due to fan not operating. Look for cause - fan thermal switch not closing, fan stalled, etc.
· Look for high resistance in the oven temperature sensor circuit due to high contact resistance (poor terminal crimp, deformed terminals, loose connection) or intermittent solder joint on control or intermittent oven temperature sensor.
· Look for electrical noise interference in the oven temperature sensor circuit (Ham radio, cordless phone, etc.).
Nov 11, 2009 | GE Profile JTP18 Electric Single Oven
STOVES fan oven - inlet fan on regardless HOB GRILL or OVEN
It is correct. The exhaust fan comes on to exhaust any heat.
The oven fan is for more even baking.
Apr 22, 2009 | Stoves Premier 600EMa Electric Single Oven
Fan making loud noise
Hi
does the noise start as soon as you turn the fan oven on?
does the noise stop as you turn off?
just depending what make and model you have there is two fans
in it 1 is the fan motor inside oven at back and other
is the cooling fan which is at top of oven .you just need
to find out which one it is and just replace . then should be back to normal
regards dan
Mar 19, 2009 | Belling XOU174 Electric Single Oven
Zanuisi top oven making noise
Yes , there is a cooling fan located at the top of the oven
It could be the fan blades catching, or a noisy fan bearing.
You would have to access it by removing the top oven cover to check., and yes it could be as a result of having it cleaned.
Plz rate my solution.
Thanks.
Dec 31, 2008 | Zanussi ZDF490 Electric Double Oven
Oven light always on, no heat
probably the clock not set properly - you have the oven on automatic. switch off at mains, wait 5 mins and set the clock according to the manual. if the over-temp stat has operated, the oven goes dead
May 05, 2007 | Smeg S351X/5 Electric Single Oven
Oven cuts out after ten minutes and comes back after cooling down.
We have the same problem with our oven, AEG B2190-1.It started on on Christmas day[worst day of year]gets up to temperature after 10-15 minutes cuts out everything switches off until the oven has cooled down, The oven is only 18 months old. We have been told that it is a thermostat problem.
Dec 10, 2006 | AEG B2100-4 Electric Single Oven
Thermador C301U Electric Single Oven Logo
392 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
