Question about Brother HL 1440 Laser Printer
First page comes out blank, with dRegular on upper left side, i am wasting paper every time i print out HELP
I had the same problem (first page empty except for the term "dregular") under Windows 8. My solution: Install the right driver... Before, I had a general driver (Brother Laser Class 1 or so), then I updated the suggest driver list and chose my exact modell. Now, I can print properly...
Posted on Nov 06, 2012
jay767
  • 386 Answers
SOURCE: pages coming oput blank -
HI Good day!! Try to Head Cleaning the printer, go to your printer properties and then "Maintenance you should see the head cleaning..
Posted on Oct 09, 2010
  • 670 Answers
SOURCE: the pages just come out blank. the printer has not
What probally happened is that the inkjet cartridges either dried out or the holes where the ink comes out became plugged up from lack of use. Try replacing the ink cartridges and see if that fixes the problem.
Posted on Jun 30, 2010
Testimonial: "thanks i'll try that. "
SOURCE: My printer prints but paper comes out blank
  1. Unplug BOTH cables from the BACK of the printer, not from the outlet.
  2. Shutdown the computer.
  3. Plug both cables back in and turn the printer on.
  4. Turn the computer back on. That's it!
Posted on Mar 25, 2010
SOURCE: not printing on left side of page
ADD PRINTER TO LAPTOP
Posted on Feb 25, 2009
SOURCE: Black Toner Problem
I had the same problem with my 4 month old Samsung. All of a sudden i had a missing black stripe down the left hand side after replacing the cyan toner with a refilled one!! So.....i uninstalled all the old drivers and downloaded and installed the latest ones.... replaced the cyan with a new genuine toner....removed the black toner, shook to redistribute and put it back.....checked the imaging unit for actual visual damage (there wasnt any!)..... then printed off 50 or so black n white documents. Eventually the 'stripe' dissapeared.
The colour toners were fine all the way through!
It worked for me, hope this helps!
Nigel
Posted on Feb 20, 2008
Print tow side on Canon LBP 800 Laser Printer
Hi
I have found both a Getting Started Guide here:
http://dl.owneriq.net/6/6b8eae44-71d6-4f7d-a01c-369b4426c2f6.pdf
and a User Manual (more comprehensive) here:
http://www.printerrecharge.com.au/manuals/Canon%20LBP-800%20User%20Manual.pdf
I've also looked through them and there is no mention of duplex printing capability, nor does the paper path shown in the manual show it as possible. The only way to double-sided printing is therefore manually. To do this
Print the odd numbered pages of the document (in properties box).
Remove the paper from the outlet and turn it over .
Replace it in the paper feed tray with the blank side facing you.
Print the even numbered pages of the document.
Please be careful to make sure that page 2 prints on the other side of page 1 and so on through the document, as it is very easy to put the one side printed pages in the feed tray with the last page, in the position to be printed first causing a complete waste of paper. Also leave the one side printed paper for a few minutes before refeeding as doing this too quickly can result in a paper jam.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 28, 2014 | Canon LBP 800 Laser Printer
My printer -X1185 prints the page with a 3 inch blank area on the left side and some of the right side printing is off the page. This is typical in my e mail page, and even if I center the letter on...
Web site designers create Web pages for display on a monitor, not for users to print on 8.5- x 11-inch pieces of paper. This becomes obvious the first time you try to print a Web page. Content you need may get chopped off by the right printer margin, whereas content you don’t need, such as the site’s copyright information, will print on its own sheet of paper. Fortunately, you can avoid such problems with a little foresight.
Before printing any Web page, open Internet Explorer’s File menu and select Print Preview. The current Web page will appear on-screen exactly as it will print on paper. Scan the preview carefully. If it appears that some content is chopped off by the right margin, click the Page Setup button located directly to the right of the Print button in the upper-left corner of the Print Preview window. In the resulting Page Setup dialog box, adjust the left and right margins so that each is set to 0.25 inches. The extra inch of space you gain by resetting the margins should provide just enough room to accommodate all of the content on most sites. Click OK to save the changes and return to the Print Preview window.
Next, scan the preview to determine which pages contain the content you want to print. Take note of those pages and click the Print button in the upper-left corner of the Print Preview window. Locate the Print Range heading and select the Pages option. Type the number of the first page you want to print in the From field and type the number of the last page you want to print in the To field. For instance, if you want to print just the first three pages of a Web page’s content, type 1 in the From field and type 3 in the To field. If your browser doesn’t have To and From fields, type the range of pages (such as 1-3) in the corresponding field. Make sure your printer has paper and click Print.
May 04, 2008 | Office Equipment & Supplies
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
HP 2840 will not print on 3 inches of left side of page
Take the toner cartridge out, shake it back and forth, and turn it around in a circle a few time. Put it back in the priter, and print. Order a new toner cartridge.
If this is an inkjet printer, ignore this response.
Apr 21, 2010 | HP LaserJet 2840 All-In-One Printer
Noisy operation and black marks on left side of printed paper
vacuum out the waste toner passages that lead from the drum and transfer belt to the waste toner container. Toner is building up inside the transfer belt and/or drum and has no place to go except onto your paper.
Nov 06, 2008 | Samsung CLP-510 Laser Printer
Left side of page prints blank
Hi there in the paper handling menu check the paper size settings as it maybe as simple as the incorrect paper size has been set in the machine
Hope this works for you
Thanks J
Dec 12, 2007 | HP LaserJet 2820 Printer
Prints four blank pages between each printed document...
this is your data cable problem change datacable
and change setting to your computer cmos setup
go cmos setup find parralal port mode option select EPP+ECP
First you change your datacable if problem can't solve so change
cmos setup option
Aug 15, 2007 | Printronix Line Matrix P5210 Printer
Print out blank pages after clearing a paper jam
Have you checked the obvious things? Such as pulling the tape off the new cartridge? Also make sure the transfer roller under the toner cart. is in securely.
Jul 04, 2007 | Canon imageCLASS MF6530 All-In-One...
Brother HL 1440 Laser Printer Logo
687 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
