Question about GE PTS22LCS Top Freezer Refrigerator
Freezer fan is very noisy - GE PTS22LCS Top Freezer Refrigerator
  • Yunus Badat Jul 10, 2008
    Hi, I have a Beko frost free freezer.
    Model: Beko Frost free freezer Model TZDA627FW.
    The fan has become noisy, its as though its touching something. I tried to remove the cover, although I removed all the visible screws I was unable to remove the cover. Are there some sort of clips I need to depress. I know the noise is not due to ice build up. Any help is appreciated.
  • Anonymous Mar 17, 2009
    where is the fan motor located to use my hair dryer
  • 828 Answers
What knid of a noise is it making. A high pitched squeal tells me the bearings in the motor are bad and you need to replace the fan motor obtainable through a dealer. If the noise is more of a grinding noise it could be a simple mater of the fan blade hitting some ice build-up. Defrosting the area of the fan motor with a hair dryer will melt the ice.
Posted on May 17, 2008
Much appreciated 22yooper. There was ice build up and a complete defrost solved the problem. However the freezer in question is supposed to be 'frost-free'....oh well, maybe not where the fan is located. All the best.
Posted on Apr 20, 2009
Noisy fan stops when I open my freezer
Some refrigerators control the freezer fan by turning it off when the door is open to minimize cold air loss. This is likely normal for your model (check wiring diagram to ascertain this.) The freezer fan is the noisiest component on a refrigerator so the noise might be typical of your model. If it is excessively noisy (it's louder now than it used to be) then it will probably be one of the following: 1) bad fan motor bearings and the motor should be replaced, 2) loose or broken fan blade and should be replaced, or 3) frost/ice buildup on the evaporator (cooling) coil that the fan blade hits and the cause of the frost /ice should be corrected (likely a defrost problem.)
Oct 10, 2014 | Refrigerators
My LG ice maker fan is making a really loud noise right after the water stops going in
Hello, Self-defrosting refrigerators use a circulating fan to move air through the freezer and refrigerator compartment. This fan runs when ever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall,near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, half way up or near the top.
Overtime the fan may become noisy, usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise,just open the freezer door and push in any fan/light switches, if the noise is louder when the door is open, the evaporator fan motor is the cause. You can lubricate or repair this motor. You must replace it.
There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor(if self-defrosting), or the defrost timer (if self-defrosting).
Thanks
Jun 17, 2010 | LG LSC26905TT Side by Side Refrigerator
New model ET1CHEXYQ02 VERY NOISY, LIKE TO MAKE
Hello there
Please follow these steps first ok
It's noisy Noise can come from these areas: The inside of the freezer The outside back of the refrigerator The bottom of the refrigerator The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows: If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer. If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer. If the freezer is on the left, the fan is on the back wall, halfway up or near the top. Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead. To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it. The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator it may make noise
Apr 24, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Noisy freezer, could be fan or condenser
I wouldn't defrost it. It could be a couple of different things causing this, from a bad defrost thermister to cubes overflowing out the back of the ice bin. Try removing the ice bin and clearing the cubes off of the dispenser motor cover. The fan will eventually sling the ice formation off.
Feb 14, 2010 | GE Refrigerators
Fan noisy
Thank you for contacting me, the noisy fan unit was resolved when the freezer
was defrosted'
Jun 26, 2008 | Bosch KGU32124 Bottom Freezer Refrigerator
GSG22KEPAFBB FREEZER VERY NOISY
15 mins or more is normal. noise could be due to ice build up round the fan - worth checking. otherwise fan could be noisy just due to age and needs replacement
Jun 22, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Noisy frig
it could be that your cooling fan gets noisy at times and stops for a while you could try to put oil on the shaft behind the fan this will help when it does get noisy pull the fridge kisten to the motor if noisy replace it its not to expencive about 40.00 dollaresthanks from gilles
May 12, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Hotpoint Fridge freezer FFA90 - Noisy fan top fridge
worthwhile checking closer. noisy fan can be due to fan blade hitting ice if there has been a build-up. otherwise needs replacing
May 07, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
GE PTS22LCS Top Freezer Refrigerator Logo
348 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
