Question about Dell 966 All-In-One InkJet Printer
"Wrong paper size. Reload correct paper then press start." HELP .. I have the correct paper size.
your printer papper seting is change the correct size of your papper
Mar 21, 2014 | Samsung CLX-3175FW Multifunction Laser...
The paper keeps jamming, I cant see anything in the way. any help is appreciated.
If paper doesn't feed correctly when printing, remove it and fan the edges of the paper to separate the sheets. Reload the paper against the right side and slide the edge guide against it. Do not load too many sheets at once.
If paper has jammed: 1. Press x Start to eject the jammed paper. 2. If paper is still jammed, gently pull it out from the output tray or sheet feeder. If paper is stuck inside, press the P On button to turn off the printer. Then lift the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the printer back on.
If documents don't feed correctly in the Automatic Document Feeder, make sure the corners of the paper are not bent, folded, or curled up. Do not load more than 10 sheets of legal-size paper at a time. If documents have jammed: 1. Open the ADF cover and pull any paper out to the left. Caution: Do not try to remove the paper without opening the ADF cover first, or you could damage the mechanism. 2. Select Yes or press OK to clear any messages on the display screen. 3. Reload the paper.
Feb 28, 2011 | Epson WorkForce 600 All-In-One InkJet...
Window says wrong paper size reload correct paper
its in setting on printer icon put it on full page.
Feb 26, 2011 | Brother MFC 6490CW InkJet Printer
41.3 unexpected size in tray 2.my printer is hp laserjet 4200.can you solve this
Thank you for contacting FixYa with your printer Inquiry.
41.3 Unexpected Paper Size Explanation
  • The printer detected a paper size different than what it was expecting.
  • This is typically caused if two or more sheets stick together in the printer, or if the paper tray is not properly adjusted.
Recommended action
  1. Reload the tray with the correct paper size.
  2. Ensure that paper in the tray is loaded under the front and back tabs.
  3. When printing from tray 1, verify that the correct paper size is selected in the control panel (see the Paper Handling Menu section in the User Guide ).
  4. When printing from tray 2, 3, or 4, verify that the three paper size adjustments on the paper tray have been made correctly (see the description of adjustments in the section on Loading Trays 2, 3, and 4 in the User Guide ).
  5. After performing the actions above, press GO. The page containing the error will automatically be reprinted if jam recovery is enabled. Or, press CANCEL JOB to clear the print job from the printer's memory.
    Hope this helps. Please keep us updated and remember to rate this answer.
Feb 07, 2011 | HP LaserJet 2420 Printer
My printer keep saying "
The unexpected paper size may cause the above error. Whenever your printer detects an abnormal size, this error appears on the device. It mainly happens when more than one sheet are attached with each other or when the paper trays are not set properly. To handle this issue, reload the trays with appropriate paper size followed by front and back tabs. For all the trays verify that correct paper size adjustments have been done. Now enable the jam recovery button and press the button 'GO' to print your document.
Nov 09, 2010 | Office Equipment & Supplies
My printer as problem in getting the paper
Oct 22, 2010 | HP DeskJet F4280 All In One Printer InkJet
It says load paper tray 1
Oct 05, 2010 | HP LaserJet 2840 Printer
FUJI XEROX DOCUPRINT C1110 WRONG PAPER SIZE MESSAGE
This printer have a sensor to remind the user when using a wrong paper size.
If you still using a paper that not the same with your software settings, it's still reminds you.
I solve this promblem by after print my works I just press "Cancel Jobs" button to clear a data.
Good luck.
Jan 05, 2010 | Fuji DocuPrint C1110B Laser Printer
Wrong paper size message
Choose the correct paper size from the setup and change the paper type to 'plain paper'.
Hope this help.
Apr 17, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Dell 966 All-In-One InkJet Printer Logo
383 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
