Question about Oreck XL2200 Bagged Upright Vacuum
I have an Oreck XL2 and the brush is not rotating.
  • 377 Answers
First, check to see if the drive belt for the brush is broken. If it is you need to get it replaced. Also, remove the brush from the cleaner and clean if of all debris then check the small caps at both ends of the brush. If they do not move freely, add a little WD40 and rotate by hand until they move freely. When putting the new belt on or replace the old one, be sure it is put on properly so the brush rotates in the right direction.
Posted on Sep 16, 2010
Motor smells Oreck Xl2
If it smells electrical, than you may need a new motor. If it smells more like burnt rubber, than you may have a brush or motor problem. To check you brush, take out the 5 screws that hold your bottom plate on the vacuum and remove the plate. Disengage the belt and see if the bearings at each end of the brush turn freely. If they do not, replace your brush. Also spin the motor shaft by hand and see if it turns freely. Hope this helps!
Mar 02, 2015 | Oreck XL21 Bagged Upright Vacuum
My oreck xl21 won't pull itself.
You need to rotate your brush or replace the brush. Lay your Oreck down, unplugged with the base plate facing up. Remove the 5 screws that hold the plate on and remove the plate. Look at the bearing blocks at each end of the brush, what you are going to be3 looking for are a series of "hash" marks on the black plastic mount. If you see several, rotate the block until you only see one mark at each end and reinstall the brush and belt and that should take care of your issue. If you only see one mark, you need a new brush roller. Hope this helps!
Apr 19, 2014 | Oreck Vacuums
Oreck brush does not rotate
The belt has broke. The easiest way to replace is by removing baseplate on bottom. There are 5 screws.
Aug 14, 2011 | Oreck XL2000 Bagged Upright Vacuum
Oreck XL2 does not start.
There could be a problem with the cord. I suggest taking it to a local vacuum shop to have it inspected as that could be the problem
Apr 13, 2010 | Oreck XL2000 Bagged Upright Vacuum
Simply won't turn on!
I believe all Oreck vacuums have a lifetime warranty. You should pursue that.
Mar 11, 2010 | Oreck XL2200 Bagged Upright Vacuum
I have a oreck xl2 and while vacuuming the vacuum quit. The vacuum has the red power light on. Please advise
sounds like a bad motor. if the light is on at the switch and the motor doesn't run, then it could definitely a motor problem, worn down or dirty carbon brushes. the motor on these machines are not the best built, they require cleaning of the commutator yearly.
Nov 18, 2009 | Oreck XL2200 Bagged Upright Vacuum
I shut my vacume off to change its bag out. Now it won't come on. Oreck xl2. There were no noises before turning it off or any smells of rubber burning. Just won't come back on. Is there a reset button....
An access panel mounted atop a vacuum nozzle base via finger operated latches. When the latches are undone the access panel is removed from the top surface of the nozzle base allowing access to the parts of the brush assembly. The panel also has an integral arm which engages a safety motor switch such that when the panel is removed the motor switch is switched into an open circuit position preventing the motor from continued operation
Sep 23, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Wiring diagram Oreck XL2
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=650346
Posted by geohil on Jun 06, 2008
Can I get a wiring diagram of the handle on an Oreck XL 2.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL Ultra Bagged Upright Vacuum. The best place to get an owner’s manual is from the Oreck Factory of which I will supply for you listed below or you can download the owner’s manual from the Oreck Website. . I would check with your local Oreck dealer or vacuum dealer in your area to see what is going on. This is most unusual for this to happen. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 06, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL2200 Bagged Upright Vacuum Logo
144 people viewed this question
Top Oreck Vacuums Experts
Kory Ronning
Randy Schumann
Randy Schumann
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
