Question about Westinghouse LTV-27w7 7 in. LCD HDTV
Picture comes and goes....when it works it is great...when it doesn't, there are vertical lines of many colors
  • ssmith720 Sep 15, 2010
    Thanks for the assistance, I will check the T-con board connections. If the connections are good and the board needs to be replaced, do you know what it typically cost to do so?
    Thank you, the information provided was helpful.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems that the inverter board is fine so it is either the T-con board in the unit has gone bad and/or it is not getting the required 12vdc from the power supply unit. If you have knowledge of internal circuitry of the unit then you can open the back of the unit and check the T-con board which is the last board before the LCD panel. Usually it is available with the LCD Panel. All this is only recommended if you have electrical expertise & know how to solder/re-solder components as these units contain high voltages even when in off position. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 15, 2010
  • Rylee Smith
    Rylee Smith Sep 15, 2010
    Its parts are not easily available however, if you are able to get them then it'll cost you around $150-$200 including labor for repair.
How to fix Multi color Vertical Lines on a Vizio E470i-AO TV
Does the menu function display the same lines? What kind of cables are using ? (HDMI, Component vid, S-video, co-ax)
Were you as tenacious checking all cables/connections as you were the electronics? Lets rule out this all too often over-looked possibility.
Do you still get the lines with nothing connected to the TV? (no source connected)
Feb 28, 2016 | Vizio E-Series E470I-A0 47" LED TV...
VERTICAL LINES ON OLDER ZENITH FLOOR MODEL TV
this was adjusted by the fine tune on the selector It is the picture not being held in place by being out of tune Same as if the picture goes sideways On the real old units there were 2 knobs to make these adjustments.
Jun 10, 2013 | Televison & Video
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
No picture just sound.
Ur video ic inverter board is dying about to be dead.U need a new video ic inverter board.
Aug 25, 2009 | Zenith P42W46X 42 in. Plasma EDTV
Screen is half picture and half black with vertical colored lines
I had the same issue. I could get the tv to work intermittantly by pressing on the boards while playing. This points to bad solder joint, so I resoldered every molex plug connector, and it nows works like a charm.
Apr 06, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Insignia ns32lcd no picture just lots of vertical colored lines
Usually this problem is caused by the connections for the LCD Controller(TCON). If you disconnect and re-connect the cable until it works correctly it will usually solve this problem.
Feb 08, 2009 | Insignia IS-LCDTV32 32 in. Television
Insignia LCD 27" w/vertical lines for picture
Happens with mine also usually happens when you change channels alot all you need to do is shut tv off and turn it back on.
Mar 09, 2008 | Insignia LCDTV26 26 in. Television
Picture reduced to a horizontal line across center
sounds like the vertical, more info ctechnicians.com
Dec 21, 2007 | Hitachi 35UX80B 35" TV
Vertical colored lines no picture.
if the tv is less than a year old , call 1-800-SAMSUNG for warranty repair, the lcd panel is bad
Dec 17, 2007 | Samsung LNT3242H Television
Westinghouse LTV-27w7 7 in. LCD HDTV Logo
411 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
