Question about Refrigerators
Whats the best setting for stella artois mini fridge?
  • 4,793 Answers
The best temp to keep Stella is plus 2C.(not cold enough for your hand to stick to the can....)good choice of beer.......
Posted on Sep 15, 2010
Does Stella Hudgens have a website for her fans?
http://www.fanpop.com/clubs/stella-hudgens
Jul 20, 2017 | Sewing Machines
What is the coldest setting on a Chefmate mini fridge?
Well, mine is set to 1 and it freeze everything in the fridge! I'm going to try the opposite
Sep 10, 2014 | Refrigerators
How do make my mini fridge colder there is a knob from 1- 10 is lower colder or warmer
Hi!
Here's an answer for you:
Setting the fridge knob to 10 will get it to the coldest possible
That means, lower is WARMER
Best regards!
Aug 09, 2011 | Sunbeam Refrigerators
How do i take a link out of my stella watch?
mcdevito75 here, Genearlly removeing the bands links are more common with Mens watches but some womans watches also have this option, the links are held together with pins which require a link pin remover tool so these pins don"t get bent. Best Bet is to look for a small watch repair shop in your araea and have them remove a link or two, also hold onto these removed links in case you need them again.
Feb 11, 2011 | Fossil Stella Topring Watch
My Kenmore elite mini fridge turns on and the light on the inside comes on and the compressor is running and is pretty hot but the fridge is not getting slightly cool, what would cause this and how could i...
We had small fridge in our RV Travel Trailer.It would run to the tempure control setting,then it would shut off.Check it out,set it up high,then as is cools in about 12-24 hours then set it to 3-4 setting that should keep fridge Kool.Or you may need some fridgerant reinstall.Call your local repair man to quotes to recharge/fridge.Hope this help you out.
Aug 08, 2010 | Microwave Ovens
How to change a fan belt
There should be a diagram attached to the car near where the belt goes showing how the belt is to run through the pulleys.
Newer vehicles have a tension pulley which is a pulley on a spring loaded arm that keeps the belt tight.
First run the belt on all the other pulleys and then use a wrench to hold the tension pulley back while you slip the belt on.
Older cars do not have a tension pulley and you had to usually loosen something like the alternator a little bit to get it on.
Mar 12, 2010 | Renault Sport Cars & Trucks
My Magic Chef mini fridge temperature trouble
That can be very difficult to do with a mini refrigerator. There is just not enough separation between the freezer and the refrigerator.
You will likely just have to find a compromise setting and accept the results.
Oct 20, 2009 | Refrigerators
Replace Evaporator in mini fridge
The system will definitely have to be recharged; the escaped gas was under pressure and you cannot remove the evaporator without losing its charge.
Since labor costs are not cheap, you might consider looking at craigslist for your area and buy a used one. Even new, they are mostly around $100 US which might be $30 higher than your planned evaporator swap.
Sep 24, 2009 | Refrigerators
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
Refrigerators Logo
114 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
