Question about True T-23DT Bottom Freezer Refrigerator
My refrigator/freezer is kicking off the circuit breaker each time I plug it in
    Sergeant:
    Novelist:
  • 193 Answers
Two obvious possibilites. One, it may not be the only unit on that circuit. If you have a 15 or 20 amp breaker, and have more than one unit like this, you are pulling too many amps for the breaker.That happens frequently. The other possibility is a dead short somewhere in the unit. Try plugging it in to a different outlet that you know has nothing else on that circuit. If it comes on and runs, You need to run a didicated circuit for this freezer only. A dead short in the machine will kick any outlet that it is plugged into. You will have to isolate each circuit in the freezer to find which one is grounded out.
Posted on Sep 15, 2010
My troy bilt 5500 generator circuit breaker kicks off at times
Check the owner's manual. That breaker may be a Ground Fault breaker, sensing a problem with the ground. This is not a normal condition, so check with the manufacturer's support services. Also be very sure you don't have it connected to a circuit or circuits that may also be energized by commercial power (you indicate the power is off.)
Nov 29, 2014 | Electrical Supplies
Reset
Hello jerrydj1021 - Often when the breaker trips, it is a mainly because there is too much current running on one circuit. Is the unit plug into a GFI outlet? It is not recommended to use GFI outlets or too many appliances plugged into that one circuit. Try plugging the unit into another direct outlet and see if the breaker trips again. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Jun 22, 2013 | Frigidaire 24 in. FDB510LC Free-standing...
No, i have a 50 amp GFCI in my main panel and i am trying to feed a sub panel in my garage. i have power to everything until i plug anything in or turn on the lights.
GFCI's are really temperamental. They are this way for a reason. It seems like you have something that is tripping this. I would try using a regular 50 amp breaker, and then see what happens. You can also try process of elimination. Shut everything down, then bring power up - one item/circuit, appliance, etc. at a time. This will narrow down your problem. Also, if you have a refrig/freezer on this GFCI, this could be tripping it too. Any appliance, etc. that has a motor - usually leaks to ground just enough for the GFCI breaker to sense, and trip it. I hope some of these solution's will help you...Good Luck!
Sep 01, 2011 | Cutler Hammer 1 Pole 15 Amp Ground Fault
GFCI on refrigerator circuit cuts off.
Yes. Refrigerators should not be on gfci protected circuits. They should have a dedicated 120v circuit .If your kitchen is new enough to be wired with gfci breakers ,it should also have an outlet dedicated for the refrigerator.
Dec 05, 2009 | Amana ARB2257C Bottom Freezer Refrigerator
The power supply to our whirlpool american fridge feezer is still there but the fridge freezer is not working, no lights are coming on the freezer is defrosting and the water dispenser has stopped working,...
Check the circuit breakers , or , use an extension cord to a plug that you know is working ( extension cord is for test purposes only ) . Or , unplug refrig , and plug in a small lamp etc to check refrig plug . Make sure the plug is not a G F I plug .
Oct 10, 2009 | Refrigerators
My Whirlpool refrigerator trips the main breaker of 40 Amps
A refrig cannot pull 40 amps in defrost , unless there is a direct short in the defrost system ( timer , heater , bimetal ) . I would use an extention cord ( for test purposes only ) , and try a different plug . Sounds like the circuit breaker is weak . In defrost , the MOST you should get , is 6 amps . This will not throw a 40 amp breaker . If you have an amp meter , remove the back refrig panel behind the refrig , and connect to one of the power cord lines (just not the green ground ) , turn into defrost and check the amps . This will tell you if short is in refrig , or weak breaker .
Sep 06, 2009 | Whirlpool ES5FHAXS Side by Side...
Microwave just died
The Microwave should be on a different circuit than the fridge. If the fridge kicks on at the same time you have the microwave on high you can damage them with low voltage causing high amperage and blowing the fuse, try replacing the microwave fuse and try to run it off a circuit that the fridge is not on, New hoses have a dedicated plug for just the microwave oven, I own a 1.4 cubic foot oven and it had to have it's own plug due to the breaker size and wire size, it pulled to much power to be on that circuit. So change the fuse if that does not work and post here and will see what else to check, and please rate if this helps.
Aug 08, 2009 | Hotpoint RVM1435 Microwave Oven
Freezer Just Stop Working
You should not run your freezer from a strip plug, only from a wall outlet. It is OK for a small spark to occur since the freezer is trying to start the compressor as you plug it in. If there is a big spark that kicks out the circuit breaker if you plug it into a wall socket, then there is a short in the compressor or light circuit in the freezer. A strip plug in probably will not have the capacity to run the freezer. Plug it into the wall socket and try that. If you have a circuit breaker kick out, then it's your appliance. Hope this helps you, Rick
Apr 25, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Water dripping from freezer when defrost kicks on.
You probably have a plugged drain in the freezer compartment. Open that up and check it. Hope this helps!
Feb 16, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
True T-23DT Bottom Freezer Refrigerator Logo
217 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
