Question about Autodesk AutoCAD 2006
Autodesk AutoCAD civil 3d 2009 locking up
I am troubleshooting this install for a company, we have two identical workstations for CAD, one is working fine, the other has no problems with any software other than autocad civil 3d 2009, the previous version 2008 runs fine, I have cleaned temp files, installed all updates for windows XP SP3, all device drivers are the newest available, the workstation is an intel motherboard (not sure which one exactly) with an intel core 2 quad 2.4 ghz 4gb ddr2, and a nvidia geforce 8800gts with 640mb video ram, the minimum requirements are a 1ghz cpu, 1gb ram, and 256 mb video ram if i remember correctly, but for some reason ac3d still locks up intermitently often before a drawing can even be opened, I have already placed about 3 calls to tech support and they have been of no help, I have also run memtest to ensure the system memory isn't going bad, drawings are stored on a server, copied some to the local machine, the software is being run from the local machine, has been installed alone and alongside 2008, both methods produce the same results, the page file was set to 2048mb and recomended was 4997 I changed it to 5500 still no luck, currently it is set to system managed, I have also run virus scans using F-prot and clamwin, also ran adaware(all at seperate times and uninstalling the previous before trying the next, currently the pc has no antivirus installed in order to troubleshoot). I am at a loss, and apparently so is cad research/Autodesk, any suggestions would be greatly appreciated, I've been working on this for a few days now, and dont seem to be making any progress.
  • Anonymous Jun 16, 2008
    autocad
  • alidholman
    alidholman Mar 20, 2013
    thank you
I am running AutoCAD 2011 and have had the same problem on the mechanical side where the system does a total lock down and has to be hard booted. I also found that inserting files into another file bogged the system down for 5 to 8 minutes and AutoCAD was not responding. I found the problem starts when I have to go deep into a directory file and its sub files. The solution I have found is to not run the Aero themes and just use the windows classic theme, this for some reason solved the problem for me.
Posted on Apr 22, 2010
  • 4,234 Answers
How may memory cards are in the machine. Try moving them around so that the ones on the outsides are on the inside. That forces the physical memory to change. Virtual memory is mapped to physical memory by the OS. When that happens some parts of memory are locked for the OS. It is possible that a portion of the "locked" memory is failing and not being detected/corrected. The OS can handle this in "user" areas without problem and usually everywhere as well. Sometimes it can not. Moving the mem cards around will likely put any undetected problem areas within the "user" area and thus be less of a problem should the problem be a faulty memory cell.
Keep us posted.
Dan
Posted on May 16, 2008
I need to Get the authorization code for this software that my wife got for me in 2002? It's autocad LT 2002 serial #341-88732540. Key#HQZ3U6. Any help would be appreciated. I've tried registering it...
Autodesk AutoCad 2000 serial: 112-11111111
cdkey: 5X8NUG
Autodesk AutoCad 2000 Educational serial: 111-11111111
cdkey: GX8NUG
auth: FFD54A5A
Autodesk AutoCad 2002 Serial #: 400-12345678
cd-key : T4ED6P
Autodesk AutoCad Data Exchange 2000i 400-12345678
Autodesk AutoCAD Land Development Desktop Release 2i s/n: 400-12345678
cd-key: T4ED6P
Autodesk AutoCAD LT 2000 serial: 110-98539662
cdkey: 2ZC3DJ
Autodesk AutoCAD LT 2000i serial: 400-12345678
cd-key: T4ED6P
Autodesk AutoCAD LT 2002 s/n : 400-12345678
cd-key : T4ED6P
Autodesk AutoCAD Map 2000i serial: 400-12345678
cd-key: T4ED6P
Autodesk CAD Overlay 2000 s/n: 110-98539662
cd-key: 2ZC3DJ
AuthCode: 08BB785
Autodesk CAD Overlay 2000i serial: 400-12345678
cd-key: T4ED6P
Autodesk CAD Overlay 2002 serial # : 400-12345678
cd-key : T4ED6P
Autodesk Civil Design Release 2i serial: 400-12345678
cd-key: T4ED6P
Auth : no requiere
Autodesk Civil Design 3.0 serial # : 400-12345678
cd-key : T4ED6P
Autodesk Land Development Desktop Rel. 2 Serial #: 400-12345678
CD-KEY : T4ED6P
Auth : no requiere
Autodesk Land Desktop 3.0 serial # : 400-12345678
cd-key : T4ED6P
Autodesk LightScape name: EzD
company: PWA
s/n: 700-15158000
code: 6A147AF9
Jan 31, 2015 | Autodesk AutoCAD LT 2002...
Fatal error unhandled c00000fdh exception at 30119435h in autocad 2011
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Fatal-Error-Unhandled-Access-Violation-Reading-0x0000-Exception-at-bcbdad73h.html
Fatal Error while opening AutoCAD Dec 05 2014
Applies to AutoCAD 2009, AutoCAD 2010, AutoCAD 2011, AutoCAD 2012, AutoCAD 2013, AutoCAD 2014, AutoCAD 2015, AutoCAD Architecture 2009, AutoCAD Architecture 2010, AutoCAD Architecture 2011, AutoCAD Architecture 2012, AutoCAD Architecture 2013, AutoCAD Architecture 2014, AutoCAD Architecture 2015, AutoCAD Civil 3D 2009, ...
See More
Issue:
While in the process of starting AutoCAD , a Fatal Error occurs.
Causes:
Fatal errors usually indicate program corruption or a corruption somewhere within the operating system.
Solution:
There are several ways to address the problem: Note: A fatal error can be caused by DisplayLink Core software. If you have this installed on your system, try uninstalling it and then see if this resolves the issue. Additionally, some antivirus or desktop locking programs can cause errors in AutoCAD as they lock the system environment from working. Your antivirus may even need to be uninstalled.
Sep 16, 2010 | Autodesk AutoCAD 2010
When inserting a raster images, receive the "FATAL ERROR Unhandled Access Reading 0x0000 Exception at 10b0961eh" message.
See More
Issue:
Causes:
Solution:
If all of the above solutions fail to resolve the issue, and a full uninstall and reinstall of AutoCAD does not help (see Remove All Products from a Windows System), then you may need to reformat your hard drive and reinstall the operating system.
Article ID: kA230000000tTXu
Sep 15, 2010 | Autodesk AutoCAD 2010
How to install autocad 2004 in windows 7
I had no issues installing AutoCAD onto a Windows 7 x86 Professional system. User is making and saving new drawings as well as opening existing drawings.
AutoCAD 2004 works fine on Windows 7 Professional 32-bit.
Aug 04, 2010 | Autodesk AutoCAD 2004 for PC
Autodesk AutoCAD 2006 Logo
936 people viewed this question
Top Autodesk Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Clive Gray
Are you an Autodesk Computer and Internet Expert? Answer questions, earn points and help others
