Its going onto the spin but its not draining the water
  • 176 Answers
Check the water pump and all houses
Posted on Sep 15, 2010
Not spinning and goes back to start of programme
Sounds like a problem we had on are washing machine. I assume that the you have confirmed that the pump has removed the pre spin water ?
We found the problem that the small pipe to the sensor from the sump area had a split in it. The sensor could not detect most of the water had been pumped out so it kept trying to empty
Jan 08, 2014 | Washing Machines
Water spills over tank onto floor
check for object in the drain hose going to the water pump or the pump going bad also check drain hose make sure is not blocked
Jul 30, 2009 | Amana Washing Machines
SPIN CYCLE WON'T DRAIN WATER FROM TUB IT RUNS ONTO MY FLOOR
Sounds like you have a bad water pump. Remove the hose going into the water pump and coming out of the pump and the pump should pull directly off the shaft check to make sure it spins freely.
May 01, 2009 | Frigidaire GLWS1349A Top Load Washer
Water level high when spin/drain cycle begins.
The water level is higher when in the rinse mode; but it should never leak. Examine the interior through the rear, there should be a loose hose somewhere. Or at the filter area. Plug off the mains caution.
Feb 28, 2009 | Kenmore 22932 Top Load Washer
Water leaking from top
That's an easy one... There is something caught in your diverter valve, keeping it partly open in spin, so that when the water is supposed to be draining out the drain hose, some of it is gettng back up to the recirculator hose, spilling onto the spining tub and then out onto the floor...
Nov 17, 2008 | Fisher Paykel EcoSmart GWL15
Wont drain, wont empty, wont go onto rinse, drain or spin during
The filter on this machine is behind the flat at bottom right of machine. Tilt machine back before unscrewing to avoid spillage. If filter is clear get back to me and will explore other possibilities.
Nov 16, 2008 | Washing Machines
Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. (consult your manual to know where/how filter is cleaned). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Dec 29, 2007 | Washing Machines
Roper washer does not drain
Alicia7q : Faulty water pump or restriction in drain line between tub and outlet hose.
arlenekc,: That metal thing is part of the motor. What you have is a leaking water pump.
badwasher,: Check the lid switch. This machine will not spin or drain if the switch is faulty.
Oct 23, 2007 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
