https://www.mt.com > Editorial > Generic > Op...
PDF
2.1 Switching on and off. Switching on. ? Press . The scale conducts a display test. When the weight display appears, the scale is ready to weigh.
Using a set of vise grips clasp the blade so that the pliars get hung up on the blade housing/protector. Then get the correct size wrench and remove the nut and washer from the blade and replace it taking care to install it on the right side for proper cutting.
UNplug the saw. Lift the guard and set the blade on a piece of wood. Using the proper wrench, turn counter clockwise and loosen the nut. Reverse the process to install a new one.
Unplug the saw first. Then raise the guard and lower the blade onto a piece of wood to keep the blade from turning. Using a proper wrench, turn the nut in the direction the blade spins when cutting and remove the nut and blade.
www.bargainbrushes.com have over 1000 type of brushes you are sure to be able to match one from there. Just measure the size in mms and match it they have a wonderful list of all types i.e with springs, without springs etc
