Question about Nokia 6600
NOKIA 6600 General: System error? - Nokia 6600
  • 4,102 Answers
Hi, the error is saying the firmware is corrupt and it will mean the phone needs flashing and the firmware re-installing, the problem with this is that you will need to take it into a phone shop to have this done.
if you can connect it to your computer then do this and back everything up as the phone will be reset and all data will be wiped, if you cant do this yourself and you want the phone fixed then make sure you ask the phone shop to back all the data up for you.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Sep 15, 2010
    Problem Solver:
  • 10 Answers
Hello.
Welcome to Fixya Community.
This kind of errors occurs when the Phone's Firmware is Corrupted.
in order to solve this problem you need to Update the Firmware of your phone, or take it to an entrusted phone repair shop and ask them for a "Flash", this term is used to refer to the updating process.
additional help:
Nokia 6600 Support.
Thank you.
5 Suggested Answers
  • 490 Answers
SOURCE: nokia 6600 system error
see budy either some of the starting files must have gone courrupted of your OS in ur handset or there is a Virus in ur mobile which is stoping ur startup file to get executed, so what u can do is either scan it once with any AV or after taking the backup make a flash updation,,,,, it will sort out the prob...... best of luck
Posted on Nov 07, 2007
  • 32 Answers
SOURCE: Nokia 6600 not starting
Make sure that you format the memory card first so that there is no trace of virus in the phone and remove any password from the memory card.
1. First of all make sure that your phone's battery is full and then switch off you mobile phone.
2. You'll need to hold three buttons together which are : The green button, left selection key and the no. 3 key
3. Keep on holding these three button and then press the power button to switch it on.
4. After this you'll get a screen which will say FORMATTING.... after that you can leave the keys.
Caution : This will completely format your phone memory and will reload the whole phone due to which you'll loose all your contacts or infact anything stored in the phone memory.
I hope this helps you....this step can be taken for any Nokia phone which has Symbian OS Series 60 Version 7 and above...you can say most of the phones which came after Nokia 6600
Posted on Feb 11, 2009
SOURCE: when i start my nokia 6600 then my phone
You should go for a hard reset.
press *#7370#
The *#7370# is the equivalent of a hard reset on any SERIES 60 mobile. It will delete all software/settings etc., and restore all applications to as they where when the phone was bought.
You can get the SYSTEM ERROR problems from corrupted/edited/deleted/incompatible files that are in use, either in the fone or on an MM/SD card fitted. To see which is at fault, simply remove the card & turn on the fone again!
I get these errors often as I make software on these things (just starting).
  • if it doesnt work your bluetooth IC ic is faulty.
  • Soft format: If the Handy (only telephone memory) formats, puts back the attitudes (see * to # 7780 #) and implements a software RESET. (however still another inquiry comes before.)
    NOTE! If the Akku to 75% are loaded at least, Akku do not only accomplish during the procedure under any circumstances remove! The procedure takes some minutes (approx. 3-4), is absolutely waiting!
    This is "only" a soft format...
    Hard format: If the Handy (only telephone memory) formats, puts back the attitudes (see * to # 7780 #) and implements a RESET.
    Proceeding: Equipment switch off, which keep "green key" (take off) at the same time pressed, "*" and to "3" key and switch the equipment on (the keys thereby keep further pressed)... to "Formatting" on the display appears...
    If that does not function, then equipment for 1 hour switch off, Akku so for a long time rausnehmen and again try.
    "only" virtual the memory is generally cleared - genuine formatting can take place only in a Nokia service center, if the Fash is deleted there and/or new L.G. is installed.
  • Format the cell phone using *#7370#....if ur cell is slow....change the log duration to 1 day.....u can see an instant change in the speed
  • if you felt i ve spent my time for you... a very helpful rating is appreciated....
    Posted on Aug 30, 2009
    paraskandpal
    • 102 Answers
    SOURCE: general system error when i switch on the 6600?
    A virus is placed in your mobile phone.
    So if your mobile is switching in then format it,
    & if not then press 4 buttons "*","3","calling button"& "switching on button"
    it will be formatted
    & your phone will properly work
    Posted on Jan 25, 2010
    System error at the end of installation of software
    This error usually comes in Nokia 6600, N70, N72 and N73. One of the reason for this is your phone is infected with virus then please format your phone and try to open the handset.
    May 24, 2010 | Nokia 6600
    General system error when i switch on the 6600?
    ths is a software problem...resoftware the system.....it will surly clear...bcoz once i had ds problem.i solve it by ths method
    Jan 25, 2010 | Nokia 6600
    upgrade or restore the mobile with the griffin ttool or the dfs at factory firmware and
    Nov 03, 2009 | Nokia 6600
    Hi there...to fix your problem you have to format your 6600...just simply turn off the phone...and then hold this buttons at the same time Power button,3,*,Call button...be sure press it at the same time...wait until the formatting msa appears after that your phone will work now normally...hope this will help you
    Feb 11, 2009 | Nokia 6600
    General Sysytem Error
    CODE : 0516518
    IMEI : 353766/00/013842/9
    IC : 661AE-NHL10
    FCC ID :QVVNHL-10
    Jul 16, 2008 | Nokia 6600
    Nokia 6600
    start up without m.card.conect to ur pc n save ur data.after that format it
    Mar 10, 2008 | Nokia 6600
    Help me
    format you're phone and it won't show that error again
    Jan 26, 2008 | Nokia 6600
    Nokia 6600
    It is necessary to format your phone, because system files regarding your phone boot sector seems got corrupted. There is not enough room in your RAM it leads to your phone at this status. Take important data backup, remove MMC and enter the press four keys i.e. 3.*,green send key and power on key together for sometime and hold it for sometime. Your phone screen will indicate "FORMATING". Your phone will get formatted, then switch off and on it again as usual . Remember to scan your MMC with a good anti virus before inserting it back in phone. During formating don't remove battery and do this process only with enough charged battery. You will be able to send your message then. Do vote this solution....
    Jan 10, 2008 | Nokia 6600
    Nokia 6600 system error
    Nov 07, 2007 | Nokia 6600
    Nokia 6600 Logo
    5,183 people viewed this question
    Top Nokia Cell Phones Experts
    Computer Repairing
    Computer Repairing
    IT Solution
    IT Solution
