Question about Health & Beauty
Error 2 being displayed on salter 9013 scales I've changed the batteries and the error2 continues.
  • 86 Answers
SOURCE: how do i contact salter scale customer service i
you can contact our customer service by this email address
sales@accurate-scales.com
Posted on Aug 04, 2009
SOURCE: Reset digital bathroom scales
I cannot reset my digital scale to lbs. it is a conair ww body mass scale
Posted on Oct 18, 2009
SOURCE: The display on my salter bathroom scales is
I held the two arrow and set buttons together for a few seconds and it cleared
Posted on Oct 20, 2009
SOURCE: Kitchen scale, Salter, model 2006: change batteries
The 1 part just slides off.
Posted on Jun 28, 2010
SOURCE: I changed the battery on bathroom scale Salter 987
I had the same problem with my Salter 987 scale. Pull the battery out for about 10 seconds and put it back in. Then push the scale once so it turns on. After the blinking stops, push it once more. The scale will now zero itself. After the scale has zero'd itself it may turn off after a brief moment. It's now ready to use normally. If you're standing on the scale when it's trying to calibrate to zero, it will assume your weight is zero. Don't stand on the scale after replacing the battery untill you first complete the steps listed above.
Posted on Aug 29, 2010
I just want new batteries for salter scales 9141 wh3r
Fixya does not sell replacement batteries for Salter scales.
Feb 25, 2018 | Salter Health & Beauty
How do I clear the 'L' error on my bathroom Salter scale. I have changed the battery but I cannot get the error to clear.
new batteries? or one's that have been sitting around.
they may be low.
what they say to do...
1.
Open the battery compartment on the scale underside.
2.
Remove isolating tab from beneath the battery (if fitted) or insert batteries OBSERVING the polarity signs (+ and -) inside the battery compartment.
3.Close the battery compartment.
4. Select kg, st or lb weight mode by the switch on the
underside of the scale.
5.For use on carpet attach enclosed carpet feet.
6.Position scale on a firm flat surface. next......
INITIALISING YOUR SCALE
1. Press the platform centre and remove your foot.
2.'0.0' will be displayed.
3.The scale will switch off and is now ready for use.
This initialisation process MUST be repeated if the scale is moved. ie battery replacement.
Feb 14, 2018 | Salter Health & Beauty
'out 2' error message shows on a brand new Salter Disc Electronic scale.
Below is a solution for the "Out2" error on the Salter scales.
I have a Salter Model 1400. It was dropped and started to display the "out2" error on the LCD display. I looked for solutions on-line but could not find anything which showed a solution. With no solution in hand I figured I would at least try to find out if my scale was salvageable. I removed the screws, there are two below the 9V battery, two under the footpads, two under the "model sticker", and two larger screws holding the scale plate to the base. After all the screws are successsfull removed, the case of the scale comes apart easily. I started looking at the small circuit board and looked for damage, and also tried several things, turned on and off the unit while it was apart but still saw the "out2" error. I then removed the circuit board, there are many screws holding it down. Looking at the LCD display, I noticed that there must be proper contact between the LCD display and the copper contacts on the circuit board, or nothing is displayed. Perhaps, "out2" is an indication that it can not display "out" anything because after it was dropped the LCD display moved enough that it no longer aligned with the contacts on the circuit board. I noticed that there is quite a bit of "play" or area of movement around the LCD display and the case. There were no cracks or damage so I assume that the loose LCD display is common even with a scale that was not dropped. I was able to align the LCD display, by moving it several times and realized that after pressing the ON button, I no longer saw the out2 error. So I decided to put something in between the LCD display and the case so that the LCD display would not move and therefore would align. It took some playing around, but I eventually took a very small piece of papertowl, about the size of my thumbnail and rolled it up and placed it between the LCD display so it made the LCD display snug and would no longer move around. I screwed on the circuit board, and voila, no more out2 error! It started working perfectly.
Jan 19, 2011 | Salter 2001 electronic kitchen scale
The display on my salter bathroom scales is flashing error, i have changed the batteries, this did not help
Oct 19, 2009 | Salter Health & Beauty
Jul 21, 2009 | Salter Stainless Steel Electronic Bathroom...
E appearing on display of Salter kitchen scale
i have the same problem- did you manage to fix it??
Mar 31, 2009 | Salter 2001 electronic kitchen scale
Health & Beauty Logo
173 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
