My Kenmore top-loading washer (model 16862) has stopped mid-cycle after filling with rinse water. What can I do?
Jimster
  • 240 Answers
SOURCE: kenmore top load (model # 110 82370120) drain problem
Good AM. I see here that you have a fairly old belt drive Kenmore washer. The real problem with these is that the parts for them are so very expensive anymore to get. A timer (which you may be needing) will run you around $100.00 to $175.00 depending on where you live. Very expensive repairs on these, but if you want to go for it, here are some hints to help. Sounds like you have one of three problems. First off PLEASE UNPLUG YOUR MACHINE BEFORE WORKING ON IT. Your timer may have lost or has a stuck contact inside (unrepairable in most cases) which is making it do something is shouldnt be doing in that area of the timer. This would probably be the most expensive of your repair. The next thing is it could be the water level switch could be going bad. This one is highly doubtful since it fills and stops filling, but I have heard (but never have seen) that they can short out sometimes and cause wacky operation. Both these issues can be fixed by remove the console rear panel and front knobs to remove both. The next item could be a defective wig-wag in the bottom of the unit. One of the positioning solinoids maybe going bad and sending bad signals back to the timer.
None of these problems are really hard to fix. And truthfully (even though some of these guys will be mad) you can sometimes find these parts on ebay for a halfway good price. Part numbers for each are:
Timer: 381860
Water Level Switch: 359712
Wig-Wag: 89814
Good luck with this one, and if you know how to use one, try to run resistance with an ohm-meter on your wig-wag to be sure your getting power flow through the soilnoids (you will have 2, be sure to unplug the solinoids before testing to be sure its a true test) before replacing.
Posted on Dec 06, 2007
SOURCE: GE washer won't fill with cold water
Cold water pipe had become frozen. FYI this model of washer has a nice feature whereas you can test each component i.e. valves, by setting the timer and reading the LED's on the front panel. Instructions are in the schematic.
Posted on Jan 19, 2009
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
  • 530 Answers
SOURCE: Kenmore top load washer 110-24642300 is leaking when it fills
tip the unit back and lean against the wall so you can look under it you will see the pump it is plastic. more than likley this is your problem. let me know if you need more assistance
Posted on Mar 26, 2009
SOURCE: top load Kenmore 800 washer will not fill with water
OK - I have a solution to my problem with this washing machine. Nothing would work except for one of the spin cycles. I thought it was the main switch - the cycle selection and start switch - but I was wrong. The service tech replaced the switch behind the fabric softener. It's the switch that controls the water levels. Part # W10292584. Our government is forcing the manufacturers to put controls on the washing machine to save water. It's a bad idea and is causing lots of problems. Tech says he's replacing them on a regular basis. Less than $100 if you do it yourself. Hope this helps.
Posted on Feb 20, 2010
Skipping wash cycle
follow this steps and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Jul 13, 2013 | Admiral 3.4 cu. ft. Top Load Washer in...
Washer stops during rinse cycle and beeps at me
see this causes and fix it. God bless you
Lid Switch Assembly If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design
Door Lock Motor and Switch Assembly If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Oct 02, 2012 | Fisher and Paykel WA37T26G Top Load Washer
Kenmore top load washer 29822800 - washer-selector is set on one rinse- when machine starts the agitator starts immediately as water fills - then when machine stops after spin cycle in off position water...
if you are saying that the washer finishes the load of clothes and timer goes to off and water is filling the tub after this then you have a bad water valve on the back of the washer.disconnect the water lines and change out the valve
Aug 14, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore series 70 fills with water on rise cycle but stops halfway throught then starts agian and finishes is this normal
If this has always stopped during the rinse cycle, most likely it's the "cool down" part of the rinse cycle.
See the following Sears site for manuals. Enter your model number and you should be able to download the proper manual for your washer.
http://www.managemylife.com/mmh/owner_manuals/
Aug 01, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore top load water temp switch problems and hot water rinse
Hi, Switch the hoses around going to the mixer/inlet valve. I am sure this will take care of the problem.
If not, please let me know so I can assist you further.
Vic
Jul 01, 2009 | Washing Machines
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
