Question about Hotpoint Dryers
I have a Hotpoint dryer model # dlb1550blad. In the timed dry position the element heats but dryer motor does not engage when start switch is attivated. even tho dryer motor does not engage the dryer is still heating.
  • j_m_nvestmen Sep 15, 2010
    Found problem...motor clamp had come loose and lodged in motor switch..in turn I think it burned out the push to start switch.
    President:
  • 1,194 Answers
Dryers have a belt that turns the drum, I think dryer belt being broken or slipping badly, burn out motor, or worn support parts.
  • Dryer have a belt that rotate the drum, If the belt worn out or broken, it can not move the drum then you just need to replace it.
  • You can check motor by hearing buzzing sound, if the belt has the problem. If you do not hear any sound from the motor then you may have to replace it.
  • Try to move drum manually (by hand), if it is hard to turn then problem with the idler pulley, glides, or drum rollers.
I hope this will solve you problem
Thanks..!!
Posted on Sep 16, 2010
  • Hotpoint Master
  • 19,396 Answers
Hi.
If problem was the thermal fuse the thermal fuse should blow stopping the element. The only condition when the element stays on with blown thermal fuse is when the element is shorted to ground, and stays always on.
The fuse can be tested reading Ohms with multimeter, if good at room will read zero Ohms or very little impedance. If it is open, it is gone.
Also ensure that the problem is not a broken belt, in that case motor will start. The belt is accessed removing the screw that hold the upper panel and tilting the top on the hinges.
Other probem may be the wiring to motor, or the motor itself.
If you need to call a technician call the number listed on the owners manual.
Here all parts and diagrams.
Posted on Sep 15, 2010
My condo has a Hotpoint dryer. It is about 3 years old and last fall it no longer dried. I took the dryer hose off from the wall and the dryer works fine, heats the condo. The dryer vent goes into the...
Hi.
With most Hotpoint/GE dryers the blower motor is not spin by a belt. The problem is unlikely the blower motor. The problem is lint in the air ducts and in the blower housing. The lint results in overheating and the high limit switch cuts off the power to the heater (burner or element depending on the model).
As a result the dryer does not heat up.
Access the heating group and remove lint from the air ducts. Also clean the lint filter.
Hotpoint appliances are built by GE. Below service manuals for different GE-manufactured dryers:
Technical Service Guide
Service manual
ELECTRIC & GAS DRYER SERVICE MANUAL(Kenmore)
Jun 14, 2011 | Hotpoint Dryers
The dry will not start the display or dig. Controls wont engage anything the start button keeps flashing was just working great
Bad Heating Element
Most clothing dryers heat up and dry clothes with a heating element inside the appliance's body. Maytag dryers are no different and sometimes these heating elements break down or burn out, making the dryer cease to get hot. Make sure the dryer is unplugged and the breakers that run the dryer are switched off before inspecting so you don't electrocute yourself. The heating element is in the bottom panel of the dryer and is often a silver part which heats up when the dryer is on. Sometimes the heating element will be cracked or burned out, which means it is broken. Other times it won't look damaged but may not be working. Replace the heating element if this occurs, to see if this is the main problem.
Broken Motor
Maytag dryers have motors which turn the dryer drum, tossing the clothes so that air and heat can help dry them out completely. When the dryer drum is not turning it means there is something wrong with the motor or that the motor is not getting power. Unplug the dryer and take it apart to inspect the motor. Once you have found the motor, plug the dryer back in and use a meter to see if the motor is getting power. If it is, and isn't working, then there is something wrong with the motor and how it is operating. If the motor isn't getting power, then there is something wrong with the circuits or fuses which disperse power to the motor itself.
Bad Switch
When Maytag dryers won't tumble or heat the clothes which have been put inside of them, this means there could be a number of different things wrong. However, sometimes there's a simple solution to this problem: The switch on the door of the dryer itself may be faulty or not making the electric connection it should to allow the dryer to run. This is a cheap fix and worth troubleshooting before tearing your Maytag dryer apart. Remove the switch and inspect the two leads to make sure they haven't broken or are still transferring electricity. If they aren't you will have to replace the switch
Mar 11, 2011 | Maytag Dryers
I have a may tag performa gas dryer. When I start it, it spins and heats but it spins very slow. I opened the top and checked the belt and it was tight and does not appear to be slipping. Is the motor...
  • There are a number of different problems which can occur with models of Maytag dryers resulting in them not heating and drying clothes properly. A variety of parts could have broken or been worn out over the course of the time you have been using your dryer or something could just malfunction, as appliances tend to do from time to time. Check warranty information before trying to repair the Maytag dryer yourself.
  • Bad Heating Element
  • Most clothing dryers heat up and dry clothes with a heating element inside the appliance's body. Maytag dryers are no different and sometimes these heating elements break down or burn out, making the dryer cease to get hot. Make sure the dryer is unplugged and the breakers that run the dryer are switched off before inspecting so you don't electrocute yourself. The heating element is in the bottom panel of the dryer and is often a silver part which heats up when the dryer is on. Sometimes the heating element will be cracked or burned out, which means it is broken. Other times it won't look damaged but may not be working. Replace the heating element if this occurs, to see if this is the main problem.
  • Broken Motor
  • Maytag dryers have motors which turn the dryer drum, tossing the clothes so that air and heat can help dry them out completely. When the dryer drum is not turning it means there is something wrong with the motor or that the motor is not getting power. Unplug the dryer and take it apart to inspect the motor. Once you have found the motor, plug the dryer back in and use a meter to see if the motor is getting power. If it is, and isn't working, then there is something wrong with the motor and how it is operating. If the motor isn't getting power, then there is something wrong with the circuits or fuses which disperse power to the motor itself.
  • Bad Switch
  • When Maytag dryers won't tumble or heat the clothes which have been put inside of them, this means there could be a number of different things wrong. However, sometimes there's a simple solution to this problem: The switch on the door of the dryer itself may be faulty or not making the electric connection it should to allow the dryer to run. This is a cheap fix and worth troubleshooting before tearing your Maytag dryer apart. Remove the switch and inspect the two leads to make sure they haven't broken or are still transferring electricity. If they aren't you will have to replace the switch.
  • please stay how helpful it
    Dec 21, 2010 | Dryers
    Hotpointdryer timer problem
    There are two coils in the heating element, and if one burns out, the timer will not advance in automatic dry. The timer should still advance when using manual (or timed) dry.
    Jan 20, 2010 | GE DBSR453EBWW Electric Dryer
    Condenser not drying stuff properly
    I am hoping your talking about a clothes dryer here. based on the model number you posted here. Does your dryer even feel warm to the touch as in any signs of internal heating? If not then here are some things to check. 1 the basics: Check the circuit breaker and make sure that both of them are in the on positon. Just trip them off and then back on again to reset them. 2. Check the power cord for any signs of a bad connection. It will show up as a dark discoloration. 3. I know you said you checked the lint filter but have you gone outside and verified that the external outlet vent is free of obstructions? If not please check it and clear any obstructions. 4. The heating element itself may be open. Ovetr time they are like light bulbs and the burn out requiring repl;acement. 5. There can be a thermostat failure causing an open circuit and no power to the heating element. 6. The motor switch also controls the heating element circuit and it is actuated when the motor is running. If the switch has failed it will prevent the heating element from being energized. 7. The least likely suspects are the timer and heat setting controls yet either of them can cause a no heat condition. You did not mention if it was a gas or electric dryer and the comments above are for an electric dryer. If you have a gas dryer then you can have 8. a bad ignitor, 9. a bad gas valve, 10. a failed gas regulator. Based on this model number CTD80 it does not cross to anything that I can find. The bottom line is your unit is probably worth the cost of getting it repaired. You may want to check your model number again please and repost it you need more information. It appears this is a UK model. I hope this was helpful. It certainly was educational here.
    Jan 11, 2010 | Hotpoint Ultima WF860 Front Load Washer
    Hotpoint dryer nvl333eyoww, Motor runs, heating
    Did you ohm out the thermal overload?
    May 18, 2009 | Hotpoint Dryers
    Dryer element stays warm
    If it heats w/ the timer in off position whenever plugged in the the element is shorting to ground, its most likely due to either a broken coil or a cracked insulator. If heating w/ timer set for drying but motor is not running, the heat circuit thru the centrifugal/start switch on the motor is stuck closed.
    May 16, 2009 | Maytag MDE2600 Electric Dryer
    Not drying my cloths . runs but there is no heat
    Since the unit will run but won't heat...
    The following are things that could stop an electric dryer from heating:
    bad heating element(s)
    loose, corroded or burnt wire(s)
    thermostat(s)
    thermal fuse ( not all models )
    motor heat switch
    timer
    selector switch
    The older the unit the more likely it's heating elements or thermostats
    Sorry....this can take some time to diagnose
    Apr 10, 2009 | Amana ALE866SB Electric Dryer
    My hotpoint ctd 40 wont heat up
    Things that could stop a electric dryer from heating:
    - house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
    A ohm meter test for these parts is here.
    Jan 27, 2009 | Hotpoint Dryers
    Heating element
    this could be a partial faulty heater element, a 2 heat element could only be working on 1 element, this can overload the other one causing it to keep switching on and off at the thermostat, sometimes this can be normal but saying as you think its not hot enough, check you have the settings correct on the heater options, i have seen stranger things happen test element contacts for both circuits unplug machine first
    Sep 27, 2007 | Hotpoint TDL14 Electric Dryer
    Dryers Logo
    55 people viewed this question
    Top Hotpoint Dryers Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Dan Webster
    Dan Webster
    Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
