Question about Apple iPod touch
Ipod touch will not charge - Apple iPod touch
  • 2 more comments
  • dorka May 28, 2008
    my itouch will not charge.  I also am getting a message to restore my itouch to its original setting now it says it can not be resored.
  • knapster08 Nov 30, 2008
    i got an ipod and it keeps tellin me to restore my ipod but when i do that it wont charge, and also it keeps dosconnecting it self
  • clong1434 Dec 29, 2008
    my itouch says its dead.. when plugged in in just flashes a black screen with the apple symbol in the middle for about five seconds and shuts off.. then repeats that over again
  • Anonymous Mar 04, 2009
    i can't charge my ipod touch
  • 502 Answers
It looks like in all of these cases it's either a battery or a motherboard issue, both can be replaced by a tech savy user or friend if you use an iPod touch repair guide, the parts are readily availabe on ebay.
Posted on Mar 15, 2009
    President:
  • Apple Master
  • 688 Answers
Coolgirl, you probably need to have the battery replace in your itouch.
Check and see if there is a local repair person or go here.
Posted on Mar 05, 2009
Hi i am having super trouble with my ipod touch it wont turn on and i keep charging it every night but in the morning it wont turn on. WHAT do i do?????
Posted on Oct 03, 2008
    President:
  • 4,402 Answers
Posted on May 28, 2008
I have the memorex Mi4004 and it won't charge my ipod touch. I have to third generation ad it is 8GB.
Hi, I do have the solution, the Memorex Mi400 clock radio does not itself support charging of the iPod touch. last model supported was the iPod video 5g. There may be a way around this however, I have an iPod sound system that doesn't support charging either-however it has a ipod charging port on the back-if I plug in my iPod touch's charger there it charges, so I would look on the back of your clock radio to see if there is a connector that looks like the one on the bottom of your iPod touch. Plug charger in there and you'll be good to go. I hope this was helpful and thanks for choosing FixYa-good luck, Prodzilla.
Apr 20, 2011 | Memorex iWake MI4004 Clock Radio
How do i charge my ipod
To charge the battery, choose one of the options below:
  • Connect the device to your computer (not your keyboard) using the included cable to charge the battery and sync. Your computer must be turned on and not in sleep or standby mode. If the device is connected to a computer that's not turned on or is in sleep or standby mode, the battery may drain.
  • Connect iPhone or iPod touch to a power outlet using the included cable and a USB power adapter to charge the battery.
An icon in the upper-right corner of the screen shows battery charging status. If you charge the battery while syncing or using iPhone or iPod touch, it might take longer to charge.
Note: If using a portable computer, make sure it is plugged into power and that the lid or display is open. If the lid is closed, the computer may go into standby, sleep, or hibernation mode and iPhone or iPod touch may not charge.
Important: If iPhone or iPod touch is very low on power, it may display one of the following images indicating that the device needs to charge for up to ten minutes before you can use it. If the device is extremely low on power, the display may be blank for up to two minutes before one of the low-battery images appears. If you don't see the white charging or plug icons, your iPhone or iPod touch may be connected with a FireWire cable. Disconnect the FireWire cable and connect the iPhone or iPod touch to a USB cable or dock.
that should be everything you need to know about charging an iPod Touch. If you require further assistance please feel free to followup with additional comments. If this solution solved the problem please feel free to rate it. Thanks and have a great day-Midwest-Tek
Aug 20, 2010 | Apple iPod touch Second Gen (8 GB,...
Charging
Some Pure-Fi's has a problem charging 2nd Gen Touch iPod, even when proper supplied adapter is used. You can try pressing the iPod further into the connector and see if it stays charging. If not, you can tilt the Touch slightly forward to make proper charging contact with Pure-Fi's iPod connector.
If you only charge your 2nd Gen Touch in your Pure-Fi, or other devices less thick than the Touch, like iPod Nanos, then you can stick a spacer on the Pure-Fi behind the Touch to always properly tilt it slightly forward. Only space it slightly forward just enough to cause it to charge so as not to stress the connector.
Stick-on chair/furniture protectors work good for this. If they are too thin, stick one on top the other till you get the thickness you need. Do not use any thicker a spacer than needed so as not to stress the connector any more than needed to make charging contact Use thinner stick-ons, like double sided foam tape, to get the final spacing you need.
The added advantage to a proper spacing between an iPod and Pure-Fi, is it relieves connector stress when plugging in and using an iPod while plugged in, since the taller Touch iPod cannot tilt backward. If you place your spacer at the very top of the Pure-if back panel, then iPods thicker, but shorter, than the height of your space can also be used.
Hope this helps everyone with this irritating Pure-Fi design problem.
To view the charging/not charging status on the 2nd Gen's screen, turn off the 2nd Gen and the Charging Icon will show when contact is being made.
May 24, 2010 | Logitech Pure-Fi Express Plus...
Jamo i200 doesn't charge iPod Touch
have you tried changing the charger or charging it through a computer. some chargers are too outdated for the ipod to charge!
Jun 20, 2009 | Jamo I200 Ipod docking station
Does the new bose dock station charge the new ipod touch (32g)?
The new SoundDock II charges your new iPod touch and is fully compatible all iPods and the iPhone 3G. Also the SoundDock Portable will do this. But..
Better news-> Call Bose. They can upgrade the 30-pin connector to charge via USB-only and function with the remote as well. $99. This will make your iPod touch 100% compatible and somewhat future-proof your SoundDock. If the SoundDock was purchased within 90 days (at full retail price), they will do the upgrade for a smaller fee or even free I think.. (new 1 year warranty given with repair/mod) btw- This is an Apple issue, not a Bose issue. All 3rd party iPod connection devices had to make this change at some point.
May 31, 2009 | Bose SoundDock digital music system...
i have the same problem with the old docks not charging my ipod touch and yes new bose docks and ihomes charge the 32g ipod touch
May 15, 2009 | Bose SoundDock digital music system...
My Jensen ipod docking system wont charge my i touch
The older ipods charge using 12v, the newer ones (including the Touch 2nd gen) use 5v. So a lot of docks that will charge a nano will not charge a new Touch. If a dock says it will work with the iPhone then it will work with the newer iPod Touch (2nd gen).
If you have an old dock and want to charge a new Touch (sounds like the case here) then you can get an adapter. Scosche makes one just for this.
Dec 26, 2008 | Audiovox JENSEN IPOD DIGITAL DOCKING...
Itouch charging
Some speaker systems which are only compatible for charging the ipod nanos and classics do not work with the iPod Touch and the iPhone, the internals are slighly different from one another which will not allow that speaker system to charge your iTouch.
To play & Charge your touch, i suggest getting a speaker system that supports the iPod touch platform.
Hope this helps ?!
Oct 28, 2008 | Apple iPod touch
Ipod not getting connected to itunes nor getting charged, and please recommend which ipod converter to download. Thank you in advance my ipod is not charged, when connected to a computer
hello!
if your IPod touch is not connected to itunes, please try the ff:
Check the iPod touch Display
-- When you connect iPod touch to your computer, the iPod touch should display an image or message on the display
-- If you do not see any image, check some basic troubleshooting here: http://support.apple.com/kb/HT1737
-- If you see a message on the screen, this indicates that the iPod touch does not have sufficient battery charge to operate and will need to be charged for several minutes before it can be recognized in iTunes.
Verify Windows PC System Requirements
--iPod touch requires iTunes 7.4 or later
Check USB Connections
-- iPod touch requires USB 2.0 to function properly
-- Try connecting iPod touch to a different USB port, preferably a port that is built-in to the computer instead of an external USB hub. Connecting iPod touch to your keyboard's USB ports is not recommended.
Restart your PC
-- In some cases, your computer's USB ports may become temporarily disabled or you may experience other software related issues. Restarting your PC is an easy troubleshooting step that may resolve this issue.
Verify iPod touch Driver/Service Installation
-- iPod touch requires two important pieces of software to operate properly on Windows. First, the driver must be installed; for iPod touch the driver is USBAAPL.SYS. Second, Apple Mobile Device Support must be installed as a Windows Service.
May 08, 2008 | Apple iPod touch
Apple iPod touch Logo
219 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
