Question about Palm Vx Handheld
I have not used it for a long time. Now it will not switch on
  • 4,102 Answers
HI, have you tried charging it for at least 2 hours if the battery has gone totally flat then it wont switch on until has been charged for at least a couple of hours.
if it is charged and you have charged it up and its shows you its charging then try removing the battery for few minutes then put it back in and give it a try, if after doing this it still dont work then the problem could be the on/off button or it could have got damp or knocked about.
let me know what you have done so far and let me know if it shows you it is charging, if it dont then the chances are the battery has got bad cells and this is causing it not to hold a charge and if this is the case then your going to need to get a new battery.
let me know how you get on or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Sep 15, 2010
What Are Similarities and Differences Between Console and Mini USB Interfaces?
A console interface can be connected to an operation terminal for onsite configuration. It must be used with a console cable. After a switch is powered on for the first time, you need to log in to the switch through the console interface to configure the switch.
A Mini USB interface is also used to connect the switch to an operation terminal. The Mini USB and console interfaces on a switch are multiplexed and enable connection to the switch through different types of physical interfaces. Only one of the Mini USB and console interfaces can be used at a time. The Mini USB interface is preferred.
Apr 21, 2016 | Computers & Internet
Tip
TGHK watch instructions
This is not for Tag Heuer, it's for TGHK watches.Here's the procedure: Press the MODE switch to step through the modes until you see the seconds blinking (righter after the ALARM set mode). Press the RESET switch to advance to the function you want to change (e.g. hours). Press the START switch to increment the hour to the correct time. Press the RESET switch to advance to minutes and, again, increment the setting using the START switch. (Hold the switch down to advance the numbers rapidly.) When you have stepped through all the elements and have everything as you want it, press the MODE switch once to return to normal time display. To set the ALARM: Press the MODE switch to display the alarm function. Press RESET once to see the hours blinking. Press the START/STOP switch to advance to the desired hour. Press RESET to advance to the minutes and set the minutes using the START/STOP switch. Press the RE#SET switch. The time will stop blinking. Set the alarm sound for either ALARM or CHIME using the START/STOP switch. Press MODE to return to the time display. To turn the ALARM off: Press the MODE switch to advance to the alarm mode. Next to the AL indicator there will be either a small ALM or CHI displayed. Press the START/STOP switch until they both are off. Press MODE to return to the time display.
on Mar 18, 2010 | Watches
Upm etw350
Copy following link to identify timer and download manual:
http://waterheatertimer.org/UPM-timers-and-manuals.html#ETW
ETW can be used to replace 3-way switch.
3-way switching has 2 switches. Timer can replace one switch or the other switch, but not both.
The remaining 3-way switch must be rewired as shown in manual. What the remaining 3-way switch does is reverse timer programming, so programmed ON times become OFF times, and OFF times become ON times.
Add a comment as needed.
Jul 19, 2013 | UPM Programmable Wall Switch Timer
Black Screen
You might have set its 'On Timer and Off Timer' time. If so, the set will only switch ON, after the On timer time set. Try to switch on at different times, and when the set switches on, go to its menu, and set both On Timer and Off Timer to '0:00' and save the settings.
Jun 26, 2013 | iSymphony LED19iH55D 19 TV
Time switch
Car seats do not use 500 watt lights...
Apr 22, 2013 | Baby Gear
I have installed dlink 1016 10/100 Switch I have two computers and one dsl router connected to this switch but i am facing slow internet problem. when i connect my pc directly with router it works fine...
you'll probably find the router is set up to ignore ping requests, most are by default, for better results, try pinging a website and compare the results both with and without the switch. The switch shouldn't make any noticable difference to your connections, I use one and there's not perceivable difference in performance.
Apr 19, 2011 | D-Link DES 1016D (DES-1016D) 16x10/100...
My daughter has just moved house and inherited a Randall 702 time unit for her central heating but no manual was left. Where can she download one for free, please?
This programmer is very easy to use, I wish I could get a modern one so simple.
Use the 6 white buttons along the top to move the time setting bars to the desirded on/off times.
Then using the two rows of switches below decide if you want hot water or heating between the time bars.
Switch 1 is for operation between bars 1 & 2
Switch 2 is for operation between bars 2 & 3
etc
but Switch 6 is for operation between time 6 and time 1 the next day.
The slider switch has 3 positions
Off, Auto (ie the time settings above), and On all the time
Hope this helps but if you are scrapping the programmer please let me know
Dec 18, 2010 | Heating & Cooling
Model 31981B Replaced AAA battery's and now it is 3 hours behind
PROGRAM MENU: b> TIME ZONE: Use a pencil or paperclip togently press and release the TIME ZONE button one time. Press and release the PLUS button to choosefrom: PST= Pacific Time MST= Mountain Time CST= Central Time EST= Eastern Time Press and release the SET button to return to a normaldisplay. DAYLIGHT SAVING INDICATOR: The DST indicator isdefaulted to the ON position. If your area does not observe DST please removethe battery cover on the back of the station and move the DST switch to the OFFposition. SET CALENDAR, TIME, 12/24HR & F/C: Press and release the SET button once toenter the program menu. NOTE:Holding a button will move the digits faster. YEAR: The Year will be flashing. Use the PLUS or MINUSbutton to set the Year. Press and release the SET button one time. MONTH/DATE: The Month and Date will beflashing. Use the PLUS or MINUS button to set the Month and Date. Press andrelease the SET button one time. HOUR/MINUTES: The Hour and Minutes will beflashing. Use the PLUS or MINUS button to set the Hour and Minutes. Press andrelease the SET button one time. 12/24-HOUR TIME: 12Hr will be flashing. Use thePLUS or MINUS button to switch to 24-Hour time. Press and release the SETbutton one time. FAHRENHEIT/CELSIUS: The Temperature will beflashing. Use the PLUS or MINUS button to switch from F to C.
Dec 06, 2010 | Equity Time USA Sky Scan 44100 Clock Radio
Canon P170-DH Calculator
CLOCK & CALENDAR FUNCTION
Look for the key with the cal/clock pic on it. Use to switch between calendar or clock mode. It is next to the feed key.
(12/24) Key used to switch between 12 or 24 hour at clock mode.
(Time Set) Key used to set the date and time in calendar & clock mode.
(AM/PM) Key used to switch between AM or PM at clock mode time setting.
(Format) Key used to select date format between "YYYY/MM/DD",
"DD/MM/YYYY" or "MM/DD/YYYY" at calendar mode.
Hope this helps, play with it I figured it out with instruction sheet.
Jan 10, 2009 | Canon P170-DH Calculator
Router failed numerous times so i bought a netgear fs605 5 port switch to hard wire in a ps3 and my dell lap top. can only run one or the other. not both at the same time. what is wrong?
The FS605 is a switch, not a router. You can only run one device at at time because you only have one ip address. You need a router between the internet and your switch if you want to use more than one device at a time.
Dec 08, 2008 | NetGear GS605 5x1000 Mbps Networking...
Palm Vx Handheld Logo
24 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Raj Patel
Andrew Taylor
Andrew Taylor
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
