Question about Jane Powertwin - Navy Jogger Stroller
Tires are flat. I want to change tires. How do I odrer tires? Please, help me..
  • 419 Answers
Go to www.johnstonprams.co.uk to order new tyres or innertubes.
Hope this helps!
Posted on Sep 15, 2010
My tires keep losing air pressure
Rosie, Tires loose air usually for the following reason, could have a small puncture, Tire may have deep weather/cure cracking,valve stem leaking, tire to rim seal(corroded or damaged), even big changes in temperature can change air pressure in a tire.
Best to take it into a good shop and have diagnosed and repaired.
Check the attached links,instruction and guides for more info., Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Why do my tires keep losing air
Why Are My Tires Always Going Flat
What Are the Causes of Tire Pressure Loss
http://www.city-data.com/forum/automotive/1545072-losing-air-pressure-one-tire.html
Apr 23, 2016 | Cars & Trucks
What is the cause of a flat spot while driving
Hi Khalil:
There are two sources that I am aware of:
1) If an emergency stop was made and the tires wire locked up, as the vehicle skidded to a stop, rubber was scrubbed off the tires from friction with the pavement. When trying to drive on these tires, the flat spot will cause a discernable "bump" when impacting the pavement.
2) While not as common, older or inadequately inflated tires on parked vehicles will present a "flat spot" when the vehicle is first used. This will be particularly obvious in cold weather. As the tires warm up while being used, this flat spot circumstance typically cures itself.
Hope this helps.
Jun 27, 2015 | Cars & Trucks
How many kilometers can you drive with a tubeless tire puncture? will it harm the tire or the wheel? at what speed you can drive with the puncture?
Unless you have those "Run-Flat" tires, the answer is "No further than it takes you to safely get out of traffic. One should NEVER run on a flat if it can be avoided, as the sidewalls of the tire can be damaged very quickly. Even with run-flat tires, you still should change it ASAP, but you have a little longer before damage sets in. Your tubeless tires, completely flat and assuming 30 MPH, will probably start showing serious damage in a block or two. Note that tire sidewall damage can not be repaired.
Nov 27, 2014 | Cars & Trucks
My 2005 infinity has all of a sudden thrown me 3 different lights. Service engine soon, vdc off, and slip. I recently had a flat and got a used tire put on. The car stalls to start and is now cutting off...
Your tire sensors are sensing different size tires./ Your tires are rotating at different speeds because of the size difference. put the same tires on the front axle if front wheel drive. and the same tires on the rear if rear wheel drive. be sure to match tire pressure.
Aug 03, 2014 | Cars & Trucks
Will fix a flat mess up the tire sensor
please just go buy a Safety Seal Kit and plug it.
That Fix a flat stuff will cost you a bundle when you need new tires.
Jan 08, 2014 | 2012 Ford Escape
My Lincoln Navigator air suspension went flat after we replaced all four tires, it won't air back up...please help!!!
AIR COIL SPRINGS WILL DEFLATE AND BE DAMAGED IF YOU DID NOT TURN OFF AIR SUSPENSION SYSTEM BEFORE RAISING VECHICLE AND CHANGE TIRES IF YOU DONT TURN OFF AIR SUSPENSION IT WILL CAUSE AIR SPRINGS TO OVER INFLATE CAUSE AIR SPRING SPRING DAMAGE.
Oct 16, 2011 | 2004 Lincoln Navigator
While driving sounds like i have flat tires all
My fist guess would be faulty wheel bearings. Take it in and Mechanic should be able to diagnose.
Oct 02, 2009 | 1998 Ford Explorer
My 2003 wrx has increasing road noise - its getting hard to hear the radio - no grinding, no pops, grunting - just loud and louder humming above 40 mph - even when i put it in neutral. drives fine - could...
i want you to feel all 4 tires, feel for lots of flat spots. feel all the way around them. they might have flat spots on them. this will cause this noise. you neer to rotate your tires at 3,000 miles front to back. this will stop them from cupping out. thats what the tire store calls it. have your tires checked for balance when you rotate them. your tire with flat spots will make a good spare tire. switch the bad one to your spare to see if the noise gets changes
Jul 31, 2009 | Subaru Impreza Cars & Trucks
Jane Powertwin - Navy Jogger Stroller Logo
78 people viewed this question
Top Jane Baby Gear Experts
Shehu Pro
Shehu Pro
Thomas Perkins
Thomas Perkins
john h
Are you a Jane Baby Gear Expert? Answer questions, earn points and help others
