My printer is HP Deskjet f2810. the out of ink light keeps flashing after i refilled cartrige. I tried restarting the printer. unplug and plug the cartidge again.
Nicolomd
  • 84 Answers
SOURCE: refilling ink cartridges
hp74a.jpg HP #74 Cartridge Refill Instructions
Black cartridge
Instructions
1. Put the cartridge on some paper towels in an area where you can tolerate a spill.
3. Fill the syringe with 20ml. of black ink.
4. Very S-L-O-W-L-Y inject ink into any hole (they all go to the same sponge, HP just used the same color mold for the black ink cartridges).
5. When finished, replace the top label or leave it off (it will make no difference in the printing).
6. Replace the cartridge and run 1 - 3 cleaning cycles as per printer instructions.
Or print the following pages:
http://www.refillinstructions.com/black.htm for Black
For best results, leave cartridge in printer for 8 hours after refilling so the ink can saturate the entire sponge.
A Refill Kit should include Ink plus the following:
One 30cc Syringe
Posted on Jan 14, 2008
  • 390 Answers
SOURCE: how to refil ink in hp 2120 cartidge
try also resetting the ink levels once ink is flowing out holes. If ink is not blotting from cartridge onto unscented wipe, you may need more ink to let ink get to bottom, to force air bubble out. Half filled ink will create bubbles. Try blowing into ink refil hole also. When ink is free flowing out printer end, you know it is ready to go, and reset cartridges on printer too (ink levels) cheers lilacgerry
Posted on Jul 31, 2008
gbeltrao
  • 10 Answers
SOURCE: Ink Refill for HP Photosmart c7280 not working
Hi Lisa,
If it responds ok with the old cartridge then the problem is with the cartridges' chip not the printer. Probably the manufactor has a problem with certain cartridge chip (contact them!). I would suggest to use the original at the problematic spot if it works without a problem.
- Gilberto
Posted on Jan 05, 2009
  • 320 Answers
SOURCE: HP Deskjet F4280 Ink Level
when you refill the cardtridge, you can not reset the ink level... because refilling doesn't show the ink levels.. you no need to worry. if ink is there in the carttridge it will print...
Shouldn't worry about it. They are only a rough guide. The only time to worry about it is when the printer stops working and it has told you it's run out of ink! Thank you.......
Posted on Jan 29, 2009
aicaxz
  • 511 Answers
SOURCE: I used to refill the ink cartridge of HP Deskjet D1460 by injecting ink. The problem is the level of ink is not resetted to full level, its still very low level. However, the printer prints normally
Close the top left pin at head contactor (1 pin only), with tape. Plug it in head carriage. Unplug it. Close to top rigtht with tape too. Plug the head. Unplug head. Remove all the tape cleanly. Plug again. See ink monitor.
Posted on May 31, 2009
Empty cartridge
HP Deskjet 3915 Inkjet Printer.
Empty cartidge status is related to the refilled catridges.
Please do not use any refilled cartriges in the above printer.
There is a chance of leakage of ink as a result the entire printer will not work properly.
Buy genuine HP Catridges and install the same in the printer.
If the problem still persits, please lodge a complaint with local HP office and get the cartidge is replaced with a new and genuine one.
Try to make user of Annual Maintence serice contract with local authorized ho Vendor for regular servicing of this printer.
Jul 16, 2009 | HP Deskjet 3915 InkJet Printer
Hp94c Installed refilled black ink but printer does not recognize
try cleaning the contacts with a wet towel
from both cartridge (black and color) and in the printer
where the cartridges get in (metal pins)
Jun 07, 2009 | HP DeskJet 940c InkJet Printer
May 28, 2009 | HP DeskJet D1460 InkJet Printer
Hp 845c orange light keeps flashing
When the orange light is flashing, either paper jam or ink problem is happening.Try unloaging & reloading the stack of paper in the main tray. Remove & reinsert ink cartridges in the printer. You may also clean the contacts of the cartridge and inside the product.
Mar 09, 2009 | HP DeskJet 845c Printer
Printer has all lights flashing
Remove all ink cartridges. Then unplug your printer and plug it in again
Jun 07, 2017 | HP DeskJet 5150 InkJet Printer
Printer indicating out of ink
Hi! joeandtam
Did you run a cleaning cycle on your cartriges? Check your tool options from your Programs/HP page.
InMrFixIt
Nov 08, 2008 | HP DeskJet 810c InkJet Printer
D1360 black ink didn't print and green light keep flashing
just unplug the power cable and usb cable from the back side of the printer and let it be for an hour it will help
Apr 15, 2008 | HP Deskjet D2360 InkJet Printer
Flashing ink refill light
Sometimes refilling them over and over doesn't work well. Once ok...but i suggest that you buy a new cartridge. I know that they are expensive but it will help. Also take some Rubbing alchohol and a q-tip...clean inside where the cartridge sits..that will help...this is for sure a bad ink cartridge
Feb 28, 2007 | HP DeskJet 810c InkJet Printer
265 people viewed this question
jasbo
jasbo
