Question about Cell Phones
When trying to turn phone on it doesn't fully switch on, keypad lights come on but nothing elce happens
    Guru:
  • 458 Answers
You have a firmware problem. you have to reinstall firmware by flashing it. take the phone to a repaire center and they will do it for you
Posted on May 18, 2008
1988 Trans Am will not start when ignition is turned all the way.
Take a test light to the small wire on the starter and have someone turn it to the start position. If the light lights up and the engine doesn't turn over, I would suspect the starter itself. If the test light doesn't light, try it in neutral and repeat test. If it still doesn't light up, it may be the PRNDL switch or the ignition switch itself.
Sep 22, 2012 | 1988 Pontiac Firebird
Occasionally when i turn my ignition key, nothing happens, i get dash board lights and power to radio and windows but the engine doesn't try to start. I have to try several times (turning key on and...
Hi, the problem may be with the safety switch on the clutch. Locate the switch--it will be touching the arm of the clutch when the clutch is fully depressed. Make sure the arm is properly aligned to the switch or adjust the switch as needed such that the arm closes the switch. If the adjustment is good, pull the connector off the switch and connect the terminals of the connector using a large paper clip. If this solves the problem, replace the switch. If not, please get back to me.
Jul 30, 2011 | 2004 Hyundai Santa Fe
It wont turn on i get a light on my keypad but thats it only the 789*0# keys light up nothing elce happens no vibrate or anything
There is a total failure of the mother board of your set , canbe due to possible inter board break in the plated though holes of the PCB. You must remove and check for traces of moisture in the board, if so dry and clean it well with a good brushing to reset it back again.
If there is no life yet the main board can be faulty but it is good to seek second opinion from the Sony service for the fault code and estimate.
Sep 25, 2010 | Sony Ericsson S500i Cellular Phone
My w980 just switched-off. I've connected
when you turn your phone on only the keypad lights up right? or nothing happens?
if nothing happens charge your phone til red led on side turns off
after that please continue to read
its a w980 software problem, very common
the solution is to open up sony ericsson pc suite
then under tools click "phone repair" and follow the prompts
if this fails it means your battery is dead, try charging it and try again
please note this will restore phone to factory state
Dec 22, 2009 | Sony Ericsson Walkman W980i Cellular Phone
My phone ran out of battery and now it will not switch on. the keypad lights up but nothing happens. how can i get it to switch back on?
The way to solve this is to put your phone on charge.It may take 10 mins before you see anythng on screen.
if that fails try a new phone battery, or if you are under warranty contact your supplier.
Oct 30, 2009 | Samsung SGH-G600 Cellular Phone
My phone won't turn on!
you may broken the turn on button so when u connect it you turn it on instantly. try connecting it and then when its turning on pulling the cord out fast and it may send u to the page were u enter ur pin code or if u dont have one then it will send u to the main screen. but then u wont be able to turn it off and you may have to try a few times
Dec 08, 2008 | Motorola Mobility V547 Cellular Phone
Phone turns on fine but nothing happens pushing buttons except power.
If your phone has a keypad lock option, make sure that the keypad is not locked. Refer to the user manual to know how to unlock the keypad.
It is also possible that the keypad is defective and needs to be replaced.
Jerry G.
Jul 12, 2008 | Motorola Mobility i560 Cellular Phone
How toTurn on Samsung T-Mobile phone
just press the on button.....if you are having problem booting it up change the battery on the phone.
Mar 21, 2008 | Samsung SGH-D900 Cellular Phone
Phone won't turn on
You may need a new battery. Also, hold the power button in for at least 10 seconds before letting go. The RAZR has a bad habit of not completely turning on unless you hold it in long enough.
Nov 30, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
79 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
