I replaced the lamp, when power button is turned on (after plugging in the tv), green light blinks, then turns on (3-7 secs) then goes to blinking red light.
  • eferrer Sep 15, 2010
    panasonic pt43lc14 lamp replacement. the previous lamp that i replaced on inspection had the wires close to the screw looking like it was subjected to extreme temperature (wire sheaths crumbled on touch)
  • 10,594 Answers
Let me know model number and brand info of your tv to diagnose possible cause of problem.
If its Sony tv then make sure lamp cover has been fixed back in its position securely, lamp cover is first plastic cover that was removed from tv to replace lamp.
Thanks.
Posted on Sep 15, 2010
  • 5 more comments
  • Shahid Electronics
    Shahid Electronics Sep 15, 2010
    DLP lamp always have very high temperature that is why exhaust fans are used in tv to maintain temp.
    If you put new bulb in old lamp cartridge then recheck bulb connections and make sure lamp has installed correctly in lamp box in tv, make sure lamp cover is back in place and turn On tv.
    If tv still shows problem then count red light blinking and let me know.
    Thanks.
    new bulb in new cartridge put in this time, i screwed the lamp in snugly, plugged in the tv set, turned it on. Power button blinks green several times, green light becomes steady for a few seconds then goes to the red blinking light mode: no set pattern - just regular blinking thereon.
    OK, sounds ballast supply board problem
    ballast board drives that lamp.
    Did tv showed lamp replacement message or old lamp was broken?
    is that something i can do myself meaning the ballast supply board? the old lamp popped all of a sudden without warning (filament was shattered to pieces) that's why i bought the replacement lamp/cartridge thinking that it would be that simple.
    (added note: this lamp that just got busted is less than a year old. I replaced it myself )
    Ballast supply board replacement is job of pro.
    Just make sure lamp cover has been fixed after lamp replacement as this cover engages safety switch inside and if that switch is open, tv wont turn On.
    Thanks.
    Ok then, then i guess i've done everything that i can do and it'll have to be a professional then. thanks.
    OK, Thanks
Sony lcd projection tv (kdf-60wf655) Tv lamp turns off after 30 secs then come back on over and over ,Green light is solid when lamp is on and blinks green when the lamp goes off. Only when I turn off the...
The board that call the Ballast board might dead,require replacing.This Ballast board only job are to ignite the tv projection lamp.The tv projection lamp been inside the tv like 1 1/2 or 2 years already?Yes.Tv used it everyday like 4 or 5 hrs daily?Yes,the tv should be replacing it projection lamp too.Tv projection lamp life are ending too.
Jun 10, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
Dec 14, 2008 | Panasonic PT-44LCX65 Television
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
