Question about Home
Hi I have a Grohetherm Wireless 36022 Shower unit. I am not getting any hot water out of the shower although there is hotwater to all other taps. The unit turns on and flashes as normal but never gets to the default temp of 38degrees infact the water temp doesnt change at all from ice cold. The remote displays LIMIT and 38 degress keeps flashing. The main controller is located in the loft approximatly 2.5m from the hotwater tank. the hotwater pipe feeding the unit seems to cool down about a meter up from the tank. I have reset the unit and powered it off and back on. Any ideas?
Did u get the sorted as we Are having the same problem ?
Posted on Aug 03, 2011
When I use the shower, the unit defaults to level I heating. Why is water not hot enough?
it probably has an anti-scald control in the shower line that lets cold water in to prevent burns
If so that unit has a wax bulb that sometimes fails and the default fail setting is cool water
have a plumber check it out
Dec 25, 2015 | Water Water Heaters
Vanquish shower goes hot and cold sometimes
Are the pressure ballance taps? If the shower is on and someone flushes the toilet the water will get hot in the shower,if they are not pressure ballance taps,or if they are the cartridge needs to be replaced in the tap.
Apr 18, 2013 | Home
Good afternoon, We have a 25yr old delta shower faucet and head. both work wonderful but the water is not all that hot- our new hotwater tank is set at 130 degrees. If i need to change the mix do i do it...
You don't change the setting on the faucet or behind the shower wall. You change the mix in the hot water heater itself. New hot water heaters are set at a relatively lower hot-water-setting for liability purposes. To achieve a hotter mix, take the cover plate off the hot water heater. You will see a dial setting that allows you to turn up the heat. Depending on what type of water heater you have, there might be two cover plates (lower and upper). If so, you'll need to adjust both of these.
Feb 26, 2011 | Delta T13420 Chrome Classic Single Handle...
Shower goes hot then after few minutes cold then hot again and constantly up and down. this shower is only 2 month old and has done this since fited
it is possible that the hot mix valve needs to be adjusted higher or there is a crossed plumbing line somewhere down the line. ( just wondering(?) are you tapped off a standard hotwater tank or a hotwater on demand system ? ). also, how is the hot water throughout the rest of the house ?
c...
Dec 29, 2010 | Home
Turn on shower, only a little bit of heat but only when you really turn up temp gage. there's no power light on as well.
make sure the rest of the house is getting good hot water to rule out a problem with your hotwater heater, if all other is ok then your shower valve may be clogged with trash on the hot side restricting flow and hot water. If its an ant scald shower valve you may need to raise the temp control.
Oct 26, 2010 | Home
Vibration from my shower panel
Sounds like the pipe going to the shower head is vibrating. Not secured tightly indige the wall. That is about the only thing it could be in my opinion. Hope this helps you out .
Kurt
Mar 26, 2009 | Home
Home Logo
113 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
