FixYa.com
Tags:
Brother PE-150V Computerized Sewing Machine
Babylock Espree (by 2 users)
posted by MJSH on May 16, 2008
The top thread keeps getting jammed up in the bobbin area. How do I fix this? I have changed the needle, rethreaded it, changed the tension back and forth...
Comment by MJSH, posted on May 17, 2008
Why does the Babylock Espree question point to the Brother PE 150 V? Are they the same machine?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Jul 24, 2008
The top thread will not go over the bobbin,it goes under the lip of the bobbin,It just started this, help please!
Best Solution
posted on Jun 25, 2008
Helpful (85)
Shipsimm6
Rank:Apprentice Apprentice
Rating: 85%, 1 votes
we just found that if you are using an aftermarket bobbin (even produced by brother) that they are not the same size and once we put an original bobbin back on it fixed it perfectly. the aftermarkets were a bit larger and did not fit in the case as well. Good luck
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on May 23, 2008
Helpful (85)
Sewman7
Rank:Guru Guru
Rating: 85%, 76 votes
If the machine is threaded properly, the tension is set somewhere in the middle, the bobbin is the correct size and the needle is inserted properly then you probably have a problem with the bobbin case. Remove the bobbin case and examine it for any kind of scratch or rough spot or needle puncture. If you find such a spot you will need to polish it with emery cloth or something very smooth.
sewman7
Can you Help with these Sewing Machines problems?
EMP6 Babylock
#4 thread path sews only a few... Answer This...
Not picking up thread from...
My machine is not picking up... Answer This...
Needle bent - thread break...
My wifes PE-150 starts to... Answer This...
will not sew
I messed with the thread... Answer This...
Embroidery arm
I have a PE 150 it was sewing... Answer This...
Repair Service
Find Sewing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
