Question about Pioneer DEH-P6800MP CD Player
CD skipping with the bass
I have a pioneer deh-p6800mp in my scion xb with one 15inch sub, when the bass hits, the cd skips, is there a solution for that?
    President:
  • 624 Answers
Has it always done this, or is this a new problem? If this is a new problem you may need the unit serviced. It may need the lens cleaned, or laser replaced. If the laser is getting weaker it can do that. They also have these small oil filled dampers used like shock absorbers. If one of those is torn and has leaked a little oil out it will skip much easier. They also use springs to support the cd mech, if a spring has streched out or come loose, that can also make it skip on big bass hits.
You can always try putting some foam or something around the radio to help keep those heavy bass hits from vibrating the radio. But then the radio may get too hot.
Make sure the radio is very secure in the dash.
If this problem has been going on since you installed the radio, you have an installation problem. The radio is a little loose and prone to move around a little.
Posted on Jun 17, 2008
Pioneer- ipod doesnt have bass
On the EQ on the ipod turn it to bass boost if not try a new cable
Feb 12, 2010 | Pioneer DEH-P7600MP CD Player
I have a pioneer head unit deh-400ub, whats the best way to adjust the radio to have it give the best sound I dont have any subs all i have are after market mids/highs please i want it to sound good
speaker mounting is key to a good sound, make sure your speakers are mounted well and the wiring is correct, if you get the speaker wiring wrong it will loose all Bass.
Nov 21, 2009 | Pioneer DEH-P6800MP CD Player
I cannot get to the Aux feature
u gotta turn the cd player off.....then press hold the volume botton...then u will see lots of option and u will also find the option to turn on the the aux and off...so u turn on the aux on...and will see it when u trun on the cd player ...
Aug 23, 2009 | Pioneer DEH-P6800MP CD Player
Alpine deck
check rubber suspention of cd mechanism, down side of the mach, may be punchared.replace it, or cd and woofer/speaker on the fixed on same platform then due to vibration track maybe
changed
Jun 23, 2008 | Pioneer DEH-P6800MP CD Player
Cuttinng out
Does it cut out when you are listening to the tuner as well as the cd player? If so, you have a bad connection somewhere. Sometimes the solder joints inside the radio can be cracked and will cut out when you hit bumps. May be a wire that is a little loose. Check all the wiring.
If it only cuts out when you are listening to the CD player, you may need the lens cleaned or the laser replaced. Sometimes the cd player cuts out because the unit has too much wiggle room and it bounces a little when you hit a bump causing the cd to skip or cut out. and there is always the dirty CD. Try cleaning the CD's with windex and a soft cloth like a bath towel. It works great for me and is cheap. Fingerprints can and will cause a cd player to skip.
Jun 07, 2008 | Pioneer DEH-P6800MP CD Player
BASS ADJUSTMENTS
What type of deck is it?
Mar 20, 2008 | Pioneer DEH-P6800MP CD Player
Pioneer deh-p6800mp wiring
You can find the wiring diagram online in a PDF of the installation manual, which is at this location
Hope that helps!
Jan 14, 2008 | Pioneer DEH-P6800MP CD Player
Pioneer DEH-P6800MP CD Player Logo
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
