Question about Whirlpool Washing Machines
I put a load in it started then it started to beep it is blinking H then it blinks to a F what could it be? the washer is a duet
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error code F/H means no water was detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. It can also happen if the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. You'll need to Press PAUSE/CANCEL twice to clear the display and then check:
  1. If there is no water in the unit:
  2. Make sure that both valves at the water source(s) are turned on all the way.
  3. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
  4. Verify inlet valve operation
  5. If there is water in the unit:
  6. Verify Drain pump operation
  7. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  8. Verify there is not a siphon problem
  9. Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter and Central Control Unit (CCU)
  10. Check all hoses for possible leaks
  11. Verify pressure switch operation
  12. Verify flow meter operation
  13. Verify CCU operation
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 16, 2010
My duet dryer control lock is blinking and beeping....tried pushing the end of cycle button, but still is blinking and beeping. Any other suggestions??? We have had lots of humidity this summer and...
It is not related to moisture directly by any chance. If END OF CYCLE does not work. it can be short circuit inside which can cause this. Moisture can cause short circuit or the whole control board may be faulty.
Aug 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer has done GREAT for two years..now suddenly,
this means your drain pump is clogged--- there are 3 screws at the bottom of the lower front panel. Remove these screws and there is a drain pump cleanout located in the middle. Twist this off by hand can clean out the debris--- WATCH OUT LOTS OF WATER will come out so have towels ready.
Jan 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Cycle will not complete
F H is a sign that the unit has a no incoming water issue, check your hose connections/water pressure,
Whirlpool DWF B00 W
Hunca, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Hunca), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 24, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Blinking light cycle won't start
sounds as if you have a bad door latch assy, the unit is not recognizing the door closed, so when the button depressed probly only beeps 3 times at you. check the lock/latch for an obvious broken part
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washing machine will not start a cycle.
sounds as if its a door latch/lock issue, not recognizing the door closed will simply beep 3 times when the start button is depressed. try unplugging and replugging after 2 min.
Nov 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
16 people viewed this question
Dan Webster
Dan Webster
Sal De
