Hi this is a very common problem and its to do with the ps3 over heating,
try the following.
leave it off and unplugged for an hour
check all air vents are free from fluff and dust and vac if needed.
make sure the ps3 is not being used whilst its on carpet
make sure the ps3 is not sitting on top of another electrical item such as dvd or sky box as this will cause it to over heat a lot quicker.
make sure its not wedged in a confined space it needs to have plenty of room around it to ensure cool air flow.
unplug all the leads from the back of the ps3 and the telly then plug them all back in, doing this removes any static that may have built up, then switch it on.
if after doing the above it still dont work then this indicates that either the gpu or cpu chip has over heated, if you have any warranty left take it back you need to check on the ps3 web site to see how old your ps3 is as this fault is covered by ps3 warranty for a couple of years but you need to check this.
now as for getting it repaired, well its a bit hit and miss i repair them myself and if it was an xbox 360 then i would say the chance of it working again is pretty high but as its a ps3 then these can be a bit hit and miss if the ps3 has over heated a lot and fried the cpu or gpu chip or both then the cost of repair would not be worth doing as it would be cheaper to buy a second hand ps3 or even a reconditioned one.
its not the kind of repair you can do yourself as you need to know how to test the circuit board to find out if the chips have been damaged.
the only other option you have is selling it for spares, i buy the damaged ones for spare parts but you wont get much for it as it is, i mean you could pay for the repair and you may get charged even though it cant be fixed,
i always say to my customers that if i cant repair it i will only charge for the parts i used which is nothing but if i do fix it then i charge them the cost of the repair, usually if its beyond repair they let me buy it off them as i pay more than they would get from ebay as they sell on their for about 30 quid with the problem you have got.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Testimonial: "I looked up how to fix this problem on youtube. I think all I have to sacrifice is about ten bucks for thermal compound and the time to get it done. "
Hello there Kerryorvin
If you have the brief
flashing yellow light, then its followed by a red blinking light then
you have the yellow light of death AKA the YLOD.
The lights are a
warning sign to let you know something is wrong. I can give you the
quick explanation, There are 2 chips on the motherboard inside the
PS3, the GPU (graphics) and the CPU (brain), when playing the ps3 the
solder heats up and when you finish playing it cools down, over time
this will cause the soldering to crack and the chips to lose
connection with the motherboard and you get the YLOD.
WHERE TO GO FROM
HERE
Option
1 - Call Sony
In warranty the Price
is Free, out of warranty the Price is $150,
the whole process is 4-6 weeks
You can call Sony and
they will collect the PS3, repair/replace, and deliver the PS3 back
to you
Option
2 - Fix it your Self
You can use a PS3 fix
manual to get this fixed easily and at home using household tools you
probably already own.
Click
here to know more on PS3 Fix Manuals which has helped so many
people like you.
Good luck
Best regards
Peter
