Question about Dell E152FPc 15" TFT LCD Flat Panel Monitor
The monitor will turn on with the green power light for about 5 seconds if that, and the screen looks great. Then goes black. The power light will remain green. I have it hooked up to a docking station with my Dell laptop M1710. I have tried to connect it to a desktop and get the same results. I have other monitors, standard CRT type, that work fine on this desktop. I not sure if its a hardware problem or software settings under display settings, but so far, nothing works. I think the monitor is OK, because it will come on just fine with full color and desktop screen and everything, but then goes black in 3-5 seconds. Any ideas? Thanks for your help..............Rich
  • Rich Lyddane Sep 16, 2010
    I tried the monitor with another computer that was working fine on its own. I changed out the monitor with the problem child, and it STILL did not work. I bought a new male 15/15 monitor cable, and it STILL did not work. Same thing, works fine for 3-5 seconds and then goes black. I know trying to repair the monitor itself probably is not worth the effort, but I would just like to try to verify the problem in case I run into a similar situation in the future. Any other ideas would be gratefully welcomed. Thanks........Rich
  • Rich Lyddane Sep 21, 2010
    I have not tried the new solution yet, I was out of town. But I will this week. I need to find a desktop to try it on again. I can try to hook it up to my laptop on my docking station and follow your directions. Thanks for your help. I have not given up yet..............Rich
  • Dell Master
  • 4,737 Answers
First let's try to find out the culprit, remove/unplug the monitor and connect it to another computer using the same cable, if it's working fine, then check the System. (If not skip the next para).
Disconnect all the cables connected to the system, like mouse, keyboard, power cord, etc... etc.. and leave it off for few minutes, again reconnect whatever is required (not all, if you have additional usb cables, you can connect them later, sometimes usb interferes with the display), once you are ready, power on the machine and enter the "Bios Setup" and restore it to Default, i.e. "Optimized Default" or something similar which is in the "Exit" menu. After it's done, save the settings (Press F10) and let it restart. While it boots up, keep tapping F8 and when you see the "Advanced Boot Options" menu, select "Safe Mode" and boot into "Safe Mode", if everything is ok with the Safe Mode, restart the system and let it boot normally. If the problem's no longer persists, then you are done, but if the problem persists, make sure the system is still running normally. Try tapping the Numlock/Capslock to assure it's still running. If it seems hanged, you better try with another monitor or replacing a ram or uninstalling recently installed hardwares, etc...etc..
If the monitor doesn't work on another computer, no doubt, it's with the monitor or with the cable, try with another cable and check again.
Sometimes motherboard itself or the Bios chip could be the problem, but let's deal with them later. For now try to find out the cause and the troubleshooting will be easier for you and for me.
Good luck.
Thanks for using FixYa.
Posted on Sep 15, 2010
  • Lebanon Raingam
    Lebanon Raingam Sep 16, 2010
    Well, I guess you've tried enough, but unfortunately without success. Now I suspect the display settings or the display drivers. We have only one means to deal with this and I hope this will definitely work.
    Connect another Monitor and power on the machine. Now uninstall the graphics drivers installed on the system, shutdown the computer and reconnect the monitor. Power on the machine and check if the problem persists or not. If not, proceed with the graphics drivers installation, or if so you'll need to check the power settings by right-clicking the desktop, "properties" > "ScreenSaver" > "Power" ....................... (for windows xp) or Control Panel > Power Options..................
    It's also important to check the registry entries and clean the unused/unimportant contents. Let me know if it's necessary.
    Once again good luck.
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
Acer monitor AL1706 Power On problem
You are more likely to have bad capacitors problem in the power supply, inverter circuits. I would look for bad caps first. Look at some of the sample here: http://s807.photobucket.com/home/budm/allalbums
Jan 02, 2010 | Acer AL1706AB LCD Monitor
Screen goes black, but power light is on (not blinking)
The problem is not with your screen. Its the problem of Video Card of your system which is unable to send Video Signals to the Screen.
Apr 23, 2009 | Daewoo L700C 17" Flat Panel LCD Monitor
YOU NEED TO HAVE THE INVERTER BOARD REPLACED.
YOU CAN USUALLY FIN THEM ON E BAY OR YOU WILL HAVE TO TAKE IT IN IF YOU DON'T FEEL COMFORTABLE REPLACING IT YOURSELF.
Dec 18, 2008 | Proview PL926WBi 19" LCD Monitor
do you have an aftermarket video card. In the bios you have to tell the computer if it is looking for a agp/onboard or PCI video card. Either that or the video driver or settings are wrong Try safe mode to check
Jun 25, 2008 | Dell Dimension 2400 PC Desktop
Beautiful screen, lasts about for a few minutes, goes black. Power button still green. If I turn it off, and then back on, it works again for a while. Any ideas?
May 11, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
I start my computer and turn it on, and everything looks fine for about 1/4 of a second and then it goes black while leaving the power light green. I can only see the screen again after turning it off and on, but that's only for another 1/4 second. What's up?
I got my rosewill flatscreen as a hand me down from my father. I've had it for several years now. Was working fine until a month ago. When I turn the computer on the screen goes black after 1/4 of a saecond. I have to turn it off and on anywhere from 10 to 20 times before it stays on. I have checked all plugs to the computer and outlets. I have absolutely no idea whats causing this.
Dec 28, 2007 | Rosewill R700J 17" Flat Panel LCD Monitor
RE:monitor goes black
Monitor going black after a few seconds can be causd by a faulty power supply or inverter. Some monitors have both as one unit.
Sometimes it is basic failed capacitors, After that then I would look at transistors.
The average monitor from 17 to 20 and sometimes the 22s have usually 4 bulbs in them. One bad bulb will also cause the inverter to not fire up.
Bad bulbs usually show pinkish tint, or flickering or are dark at center top or bottom of the display.
ebays bammbammfran
Sep 21, 2007 | Acer AL2017 20" LCD Monitor
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Dell E152FPc 15" TFT LCD Flat Panel Monitor Logo
70 people viewed this question
Alun Cox
