Question about Mitsubishi SD205U Multimedia Projector
When I turn on my mitsubishi sd205u projector, I hear a clicking noise
2008 Mitsubishi lancer radio from loud squealing noise
What is causing that irritating noise? ' DSMtuners
www.dsmtuners.com > ... > Articles: Miscellaneous
Jun 1, 2009 - 2 posts - ‎1 author Check the ECU power relay in the console, under the radio. ... You hear a loud clicking type noise from under the hood when you try to start the car. .... You hear a squealing, grinding, or rubbing noise in the lower timing belt .... The Mitsubishi Eclipse, Eagle Talon, Plymouth Laser, Mitsubishi Galant VR-4, ... LOUD squeak when turning steering wheel (Video Inside)
Mar 5, 2011
Why does my alternator belt squeal so much on initial ...
May 14, 2010
More results from www.dsmtuners.com
Lancer Troubleshooting [Archive] - evolutionm.net
www.evolutionm.net/forums/mitsubishi-evolution-forums/f-203.html
NEED RADIO HELP! ... Help not start Lancer GT 2012 EngineOverheating STOP SAFELY warning on ... AC ISSUES 2011 Mitsubishi Lancer ES · 2008 Lancer GTS no start please ... 2011 lancer no sound · Driver/Passenger side floor squeaky? ... plastic piece of rear shelf rattles a lot · Very loud noise on Lancer ES 2008 ...
Dec 03, 2015 | 2008 Mitsubishi Lancer GTS CVT Sedan
Why does my Mitsubishi XD221U projector have a power light blinking red and green?
Reset the lamp timer by holding power and menu button down for 25 secnnds
Sep 03, 2014 | Mitsubishi XD221U New
No Picture but still has sound
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs,It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator, it could be time to replace the lamp.The lamp you need is 915P049010. you can find it here: http://www.discount-merchant.com/Mitsubishi-915P049010-Lamp-Replacement-p/mitsubishi-915p049010-lamp.htmHave a blessed one!
May 03, 2010 | Mitsubishi WD-57731 57" Projection HDTV
Powers off red light starts blinking
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.But if you don't hear any strange noises,tv is around 4000 hrs,2-3 yrs it could be time to replace the lamp.The lamp you need is 915B403001.Have a blessed one!
Mar 23, 2010 | Mitsubishi WD-Y657 65" HDTV
My mitsubishi tv turns on for 3 seconds then turns off
Hi,If you hear continueous clicking most likely is t an issue with the ballast which is the board that powers the lamp.But if you dont hear it often and tv is between 1-2 yrs most likely it's time to replace the lamp.
Oct 05, 2009 | Mitsubishi WS-48313 48" Rear Projection...
62 in LCD mitsubishi
Not too sure about the thumping, possibly the cabinet expanding and/or contracting with heat, the lack of and weather change. But the scratching sound could very well be the HV discharge. So, not being able to hear it myself, I would suspect that yes it's probably normal.
Bill
Nov 20, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Mitsubishi SD205U Multimedia Projector Logo
44 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
Martin Murray
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
