Brother dcp 7010 How to print envelopes
Hi! Lost instruction manual - wanted to print address on envelope. Put envelope in front slot, but printer said paper jam. Which way round do you put the envelpe in?
  • wryals222 Aug 15, 2008
    I have a similar problem with the DCP 7020, occasionally getting a "paper jam" message which I "fix" by opening and shutting the front of the machine.
    A more frustrating problem for me is getting standard size envelopes to print straight. I move the paper guides in to fit the envelope but as the envelope is pulled into the printer, the paper guides seem to open, allowing the envelope to slide in crooked. Any ideas?
    Will
  • 3 Answers
Use the manual feed slot to print or copy on labels,
envelopes or thicker paper.
Slide the paper guides to fit the paper
size.
Using both hands put the one sheet of
paper in the manual feed slot until you
feel the front edge of the paper touch the
paper feed roller.
Let go of the paper
when you feel the machine feed the
paper in a short distance.
Posted on May 16, 2008
How to load evelopes HL 2140
Brother Hl 2140 Printing on thick paper, labels and envelopes 2
When the back output tray is pulled down, the printer has a straight paper path from the manual feed slot through to the back of the printer. Use this paper feed and output method when you want to print on thick paper, labels or envelopes.
Open the back cover
Open the manual feed slot cover.
Using both hands, slide the manual feed slot paper guides to the width of the paper that you are going to use.
Using both hands, put one piece of paper or one envelope in the manual feed slot until the front edge of the paper or envelope touches the paper feed roller. When you feel the machine pull in the paper, let go.
• Put the paper into the manual feed slot with the side to be printed face up.
• Make sure that the paper or envelope is straight and in the proper position on the manual feed slot. If it is not, the paper or the envelope may not be fed properly, resulting in a skewed printout or a paper jam.
• Do not put more than one piece of paper in the manual feed slot at any one time, as it may cause a jam.
• If you put any Media (paper, envelope and so on) in the manual feed slot before the printer is in the Ready state, the media may be ejected without being printed on.
Jul 18, 2011 | Brother HL 2140 Laser Printer
I just purchased a dcp-8085dn copier and wondering how do you print on envelopes, do you need a special tray to load your enveopes, if so, where can you purchase
On this machine, envelopes can be run thru the manual feed table. Just open up the front door with "Brother" on it and you will see inside of that door is the manual feed with the side guides that are adjustable. Just insert your envelope and adjust the side guides up against the envelope. Then when printing you have to specify the manual feed as the paper source and envelope as the paper type. Takes a bit of getting used to but is not to hard.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 08, 2010 | Brother DCP-8085DN Mono Laser P/s/c USB...
Double printing addresses on envelopes
You need to make sure you set up for envelopes in printing preferences as this makes the fuser a little hotter. If all is set up properly you need a shop to adjust the fuser temperature. The thick envelopes require more heat to bond the toner properly.
Feb 05, 2010 | Brother DCP-7020 All-In-One Laser Printer
Print envelopes brother 2040
Ummm... Just go to the user manual. It will show you how to do this. It's really not hard. Manually feed the envelope into the printer (that thing on the front that you can play with and the sides get closer, and further apart at the same time) You'll need to have word set to print on an envelope. Again not hard just a little bit of know how. Google "word envelope print" and you will find instructions on how to set up word.
Sep 23, 2009 | Brother HL-2040 Laser Printer
Can i print envelopes addresses on brother HL 2140 laser printers
The manual by-pass slot just below the brother name on the front allows a user to load envelopes just put the envelope in the slot and adjust the size.by closing the two grey tabs
Nov 25, 2008 | Brother HL 2140 Laser Printer
Printing Envelopes
Hi - You can download the manual from the link below:
Brother DCP-130C
Yes you can print envelopes:
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 07, 2008 | Brother DCP 130C All-In-One InkJet Printer
Printing envelopes
Pull down the front and slide the paper guides together till they are the size of the envelope. Place your envelope front side up (return address will be at your bottom left)
Apr 01, 2008 | Brother MFC-8460N All-In-One Printer
Addressing Envelopes
i need an instuction manual for BROTHER DCP 115C all in one anyone got one spare
Oct 30, 2007 | HP LaserJet 5200tn Printer
PRINTING ENVELOPES
Printer does not except all kinds of envelopes. Please read user guide which envelopes are allowed: http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000063/faq000063_003.html?reg=us&c=us&lang=en&prod=dcp110c_us&Cat=4
Aug 27, 2007 | Brother DCP-110C All-In-One InkJet Printer
569 people viewed this question
jasbo
jasbo
