Question about Jamo A 102 HCS 5 System
I need to power-cycle the board, but how? - Jamo A 102 HCS 5 System
  • Jamo Master
  • 3,289 Answers
This speaker system is described as consisting of "passive" satellite speakers with an "active" subwoofer. Passive means they require an external amplifier to work - and conversely active means there is a built in amplifier. To "power cycle the board" simply disconnect the power cord for a couple minutes (allows capacitors in the circuit to discharge) and plug back in. That's it.
Posted on Sep 15, 2010
Help diagnosing a problem with a LG 50PA6500ua T.V. will not turn on.
sorry tv number does not match any on search. plasma tvs can be a pain to diagnose, but usually if its in cycle mode, it will be a regulator chip on the voltage side. and the voltage regulator on main controller for the Y board cycle mode is its trying to turn on the back light and the voltage is either to high or too low. can also be voltage is in ac when it needs to be dc. as there is a mix on board parts this can be the bridge rectifier. left side board there are a few parts on this board that can need replacing if it has gone wrong. there are repair kits for this board you will just need to find them. an LG i repair, the parts had to come from china as they were not available anywhere else. but these fixed the power problem.
Feb 16, 2018 | LG Televison & Video
How can i fix my tv, power cycles on & off, only pixels & screeching sound during the on portion, then cycles off & on again. eventually no pic but sound. how do I figure out which board is bad?
Sounds like back-light inverter problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Oct 05, 2015 | Samsung LN46A500 46 in. TV
Can't select wash cycles
Is the control board displaying any fault codes?
Try disconnecting the power cord to the washer from the wall outlet for 5 maybe 10 minutes...give the control board enough time to power down and hopefully the control board could self-correct itself by resetting. No different than re-booting a computer.
If you still run into the same problem, and if so equipped, try holding down the "end of cycle" signal button for 10 seconds and see if that resets it.
Dec 07, 2013 | Kenmore Washing Machines
Maytag dishwasher model MDBTT53AWW2 wont drain completely in normal cycle. I time drain cycle in normal cycle and it took 45 sec. in cancel cycle it run 2 mins. I replaced the pump and check the flapper...
Sometimes the machines get out of cycle and you have to remove power from the board to rest the electronics. After a while the code on the board gets corrupted and you need to reset. Try uplugging for 30 minutes to clear the board of power.
Oct 17, 2013 | Dishwashers
Toshiba 50hp66 Plasma repeats power sequence without turning on
A case of which came first the chicken or the egg, Power supply board may be the issue or the sustain board--have you looked for the usual bad caps on the power board?
Dec 03, 2012 | Toshiba 50HP66 50 in. Plasma Television
LG55LH40 LCD TV wont come on
The set will need to be properly diagnosed. It could be a defective main board or power supply.
Sep 01, 2012 | Televison & Video
My whirlpool GU2300XTSS0 dishwasher does not cycle between wash/rinse/dry cycles. It fills, washes, drains and refills in the same cycle. What can I do to solve or check for solutions to this?
This means the software in the control board is corrupt. YOu would need to try a power cycle, if that does not work, replace the control board to fix the issue. You could purchase the control board from the link below. Type your model number in the search box to look at a parts diagram.
The screws around the control panel would need to be removed and the control rotated down. The board clips into position and the ribbon cable simply plugs in. Very easy repair.
Appliance & Refrigerator Repair
Mar 22, 2011 | Whirlpool GU2300XTSS Stainless Steel 24 in...
The unit is a Maytag model MDB5601AWW which it has recently began to lose power at the touch pad. The electrical breaker has been checked to confirm normal voltage. Additional investigation suggests that...
It sounds to me then that the display board or touchpad needs replacing,you havn't said that it's not doing it's cycles.so it's not causing any washing or cycle problems.i would replace the display board.
May 28, 2010 | Dishwashers
Hoshizaki KM-450MAB Ice Machine
maybe not. it could be that the heating cycle is taking a lot of time to remove the ice from the evaporator that is why the electronics is shutting off the compressor as a protection. check the heating cycle if it is working fine. check the evaporator for dirt that would hold the ice slab from falling down quickly. check the level of the unit. it may have move and now its out of level. the unit must be leveled with the ground.
Feb 21, 2008 | Hoshizaki Cubelet Ice MakerDispenser Water...
Jamo A 102 HCS 5 System Logo
118 people viewed this question
Top Jamo Audio Players & Recorders Experts
Steve
 Grubhead
Grubhead
rjivaro
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
