Question about Bose 3·2·1 II System
BOSE LIFESTYLE LS 48 loose music library
Hello, my company instal BOSE material in FRANCE and we meet problem with library. Sometimes, the library on LS48 loose all music stored and BOSE dealers don't know how to back up and restore the library. I don't find any subject about this problem so...thank you for advance....BG
    Genius:
  • 1,224 Answers
If im hearing you correctly it sounds like you need a hardrive for the system as a back up easy to install and backs up all info for system
i hope im hearing this right to make sure i give you right help
Posted on Jun 08, 2008
Bose lifestyle 48 power went now not switching on..
Bose Lifestyle Problem - ecoustics.com
www.ecoustics.com > ... > Home Theater in a Box Forum
May 27, 2006 - My Bose lifestyle 38 will not switch-off completely and the "Saving your music ... On the phone they said power down and check cables and ... Here we goagain with more Lifestyle 38 problems . We are now unable to watch DVDs or listen to CDs without ... Recently bought a TV and Lifestyle 48 system. Archive through April 10, 2009 - How to DIY Repair a Bose ...
Jan 19, 2009
Archive through January 06, 2008 - How to DIY Repair a Bose ...
Dec 26, 2006
How to open the bose lifestyle 25 receiver
Aug 14, 2005
Archive through December 25, 2006 - How to DIY Repair a Bose ...
Mar 7, 2005
More results from www.ecoustics.com
Oct 24, 2015 | Bose Audio Players & Recorders
Tip
Reset Bose LifeStyle 48 VChip Password
Bypass or Reset Bose LifeStyle 48 System V-Chip Password Lock
Would you like to bypass, defeat or reset your Bose LifeStyle 48 System Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked signal without entering your password.
When your passcode is requested, enter the temporary code 2673. This process temporarily unlocks your system, and you can reset or change the password.
I hope that helps.
_______________________________________
Bose LifeStyle 48 Manual Download
Bose LifeStyle 48 Video Mode
on May 02, 2010 | Bose Lifestyle 48 System
Tip
Download Bose LifeStyle 48 System Owners Manual
Have you misplaced your Bose LifeStyle 48 System Users Guide?
Would you like a digital, searchable, pdf version of the Bose LifeStyle 48 System Owners Manual?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
on May 02, 2010 | Televison & Video
Bose lifestyle 48 won't play stored music. Everything else works fine
Hard drive is ****..... impact computers.com hard drive number is MK4026GAX pull out of system and replace look at my other posting for 801 code!!! and dont be a ******** again and buy a bose!! TELL YOUR FRIENDS , FRIENDS DONT LET FRIENDS BUY BOSE!!!!
Mar 19, 2010 | Bose Lifestyle 48 System
Connecting ipod to Bose lifestyle 48
I have a Lifestyle 48 and called Bose today. It is possible all you need is a cord that is a 35mm headphone jack on one side and RCA jacks on the other. You plug it into the AUX jack in the back of your system and the headphone jack in the Ipod headphone spot. I got the cord at Best Buy for ten bucks. It works GREAT!
Aug 26, 2009 | Bose Lifestyle 48 System
Tip
I hope that helps.
Bose lifestyle fault code 802 hi there- i have a bose lifestyle 48 and on display it reads format unsupported when i try to listen to cd's gut not on dvd's - in addition i am unable to store music into the...
Unfortunately, an 802 error is bad. That means hard drive (HDD) failure. This can happen to any hard disc drive, and there's no way to predict it and no way to fix it from home.
If you even try to troubleshoot it (reset etc), you could loose more data (music you've already stored to the system). If you try to access 'stored' music- the error will continue. Also, every time you turn the system off, it checks your HDD, and will probably cause the 802 or 801 errors to display again.
The "Format Unsupported" message may be related, but usually temporary. The 802 (and also 801) errors mean irreversible HDD damage so it doesn't matter.
Call Bose tech support immediately.. They can repair it for $165 and give a new 1 year warranty. And if it's already under warranty they will repair for free. In either case they will replace your HDD with a new one, and transfer any salvaged music files from your existing drive to the new drive.
May 31, 2009 | Bose Lifestyle 48 System
Bose Lifestyle 48 System play's dvd in black & white only also connect to vs-2 video enhacer hello, my bose lifestyle 48 only plays DVD's in black and white. I can't find a setting or a reason why it...
Your s-video cable at the back of your media center is loose. This will cause black and white internal video and is known to fall out or just become loose from minor movement. (it's the nature of s-video cables) This should solve your problem. This is the s-video cable that connects to the VS2 and media center.
If this doesn't solve the problem (I'd be surprised), just reset it by unplugging the DC power cable at the side of the VS-2 for about 30+ seconds and plug it back in..
Bose Lifestyle 48 not responding to remote or manual functions
I hd this same problem a couple of months ago. Disconttect all peripherals (any exterior amps, roommates) plug the power connector and wait for two minutes, while waiting connect the main system. try turning the LS 48 on. If this clears thing turn off the LS 48 and connect the peripheral one at a time testing with each new connection. Happy hunting.
Apr 21, 2009 | Bose Lifestyle 48 System
Black and White instead of color
Assuming you are using the VS-2 with your system. I have experienced the same problem when I fiddle with equipment. Each time it is due to the S-video plug from the VS-2 cable becoming loose or detached. Make sure every cord is re-inserted into the back of the LS 38.
Dec 07, 2008 | Bose Lifestyle 48 System
Bose 3·2·1 II System Logo
227 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
