Question about MSI K9MM-V Motherboard
I dont have any signal on monitor. how do i troubleshoot the motherboard?
  • MSI Master
  • 27,725 Answers
Test all the leads that attach to your hard drive IDE,SATA the ones that attach from your motherboard to hard drive
Posted on Sep 15, 2010
Monitor does not connect with computer . dvi no signal
Could be a bad monitor and if not, then the graphics card if it has one, if not the motherboard connection. Try it with another monitor to rule out the monitor, then if you ave a graphics card, remove it and reseat it.
Jul 24, 2012 | ASUS P5GC-MX/1333 Motherboard
Monitor (no signal) after replacing mother board and CPU
try only connect Monitor and keyboard, and check for booting (disconnect all the rest (HDD, CD DRIVE, Sound Card, Network Card, ....) then try connect one by one and always off to change hardware config.
If dont work with monitor and keyboard, try reset bios(jumper),check again, then replace memory modules (must be compatible to new motherboard), evan dont work, send back the motherboard for defective motherboard.
Jan 14, 2010 | Gateway Intel (El Paso 2) Motherboard P4...
My computer is not working shows keyboard erro and stop
Hi...
When you monitor saying which is no signal this is a monitor port problem. Check your monitor connector if it is properly connceted to the motherboard. That is the only way of monitor saying no signal.
Regards
PCmania
Aug 22, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Building new computer - nothing on the monitor.
whats your graphics card model and what kind of power supply you have?
Dec 21, 2008 | Acer AL1916W 19" LCD Monitor
No Signal
No signal on screen means that there is no input for your monitor from the PC.
1. There might be problem in your PC or in the cable connected to PC from monitor.
2. Your PC might damage that it could not send signal to the monitor.
2.1 In your Motherboard might be faulty in the VGA chips.
2.2 In your Motherboard's SMPS mean power supply.
I think you can got my point. If you are tech person it will help you, otherwise you should take a tour to any service centre.
Thanks & Goodluck
Iqbal
Jul 21, 2008 | Intel Desktop Board D845GLVA...
No signal to monitor
Sounds like a bios issue. Check your manual for resetting your bios to default parameters. Good luck.
Mar 20, 2008 | Gateway GT5408 PC Desktop
Monitor not receiving signal from affected computer but works well with other PCs. 12/12/07-received a critical update from MS-after update installed correctly the situation became critical. The computer...
Basic network troubleshooting A network may not work because of any of the below reasons. ... card is not connected properly, or that the card is not receiving a signal from the network.
Good Luck...Please dont for get to Vote..Thank You.
Dec 14, 2007 | EliteGroup L7VMM2 Motherboard
No Video Output - HP 6635 Desktop minitower - CPU Intel CELEROM 533Mhz
if you have changed the monitor and the same no signal have you noticed a beep sound? or can you see the green and red light in front of cpu? if both of this doesn't light it's power supply and if there are led lights (green&red) lighting but there is a continous beep sound the problem is the on board video card. if a sound short beep, beep the problem is your memory card.
Nov 27, 2007 | HP (5064-6630) Motherboard
MSI K9MM-V Motherboard Logo
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
