Question about Hayward SAND FILTER, PRO SERIES
Removed all old sand from filter put new sand in but getting lots of sand in the pool
  • 366 Answers
When removing the old sand, you have to be extremely careful not to break any of laterals at the bottom of the tank. Also, when you added the sand, you should have filled the tank with water at least up to the lateral assembly/hub. If you have not broken a lateral and filled the tank with water up to the laterals before adding the new sand, you could have a problem with the multiport valve. Make sure the spider gasket inside is in place and not damaged/deformed. Also make sure the spring is not broken. Those are the only problems you can have with sand returning to the pool.
Posted on Sep 16, 2010
Sand getting in pool
check laterals inside filter if broken replace or put fine mess over them until you can replace old sand will go through the holes because it breaks down in size
Jun 21, 2014 | Sta Rite 21 Sand Filter System with 3/4 Hp...
Pump is blowing cloudy water back into pool
Cloudy water is the bane of sand filters!. I suggest letting filter run day and night. Do not backwash until the pressure rises 8 - 10 pounds above clean starting pressure. Do not try to vacuum or stir up the sediment. when water clears, vacuum to waste. Keep the hose running while vacuuming. A dirty filter is a better filter (up to a point). At a higher pressure the filter will trap more of the fine particles that are clouding your water.
May 28, 2013 | Pentair Meteor Above-ground 22" Sand...
I just finished cleaning my pool when I noticed debris around the area where my inground pool jets are. So I backwashed and vacuum that area. However, once in filter mode I noticed sand at the bottom of...
When sand comes back from the filter, that means that the device inside the filter that keeps the sand in has broken. In order to replace the item, all of the sand must be removed and the tubes must be removed and new ones installed. Go to your local pool supply house with your filter information and they can show you how to remove your old units and they will sell you new ones. You only have to replace the ones that are broken.
Gary
Aug 12, 2011 | Hayward SAND FILTER, PRO SERIES
Just installed a new filter and 1 month old sand from defective filter. Removed the cardboard cover used to prevent sand from going into pipe. Piped everything together and no leaks. When I try to run the...
Too much sand or wrong type of sand in the tank are two possibilities; should tell you on the side of the label how much sand to put in but generally it fills to about half way up the tank body.
Are you getting sand back in the pool at all? If not it is unlikely the sand is the issue since too small a grain would pass thru the laterals and get to the pool.
Have you used any clarifiers in the water? Over-dosing with a clarifier can literally turn the top of the sand bed into mortar impeding the flow of water.
John
Jul 09, 2011 | Hayward SAND FILTER, PRO SERIES
What would cause my pool water to bypass the sand filter?? When i vacuum the algae off the bottom of the pool, i can see it coming back thru the return. The filter removes some of it, but not all. We...
algae is too fine for the sand to filter, filter to waste when you have algae or it will get in your filter now you have to backwash and super chlorinate your pool to get rid of it
Jul 07, 2011 | Hayward SAND FILTER, PRO SERIES
Sand Leaking From Filter into Pool. When my filter is running I am experiencing sand in the bottom of my pool from the filter. What can be causing that?
There is only one thing that can cause sand to come back into the pool from a sand filter. The internal assembly, called the lateral assembly, is either cracked or broken. This is an easy fix and should cost you around $70 to replace the whole thing. You need to unscrew the bottom drain cap on the filter to remove the water in the tank. Then, remove the multiport valve on top of the filter. Take a shop vac and remove the sand in the filter. If the sand hasn't been replaced in the last 3-5 years, this would be a great time to do that since you already have the sand out anyway. Then, remove the lateral assembly and inspect the entire thing. After you replace the lateral assembly, you'll need to fill the sand filter tank 1/2 full of water before adding fresh sand. This is done to cushion the laterals from the weight of the sand. Cover the hole in the top of the lateral assembly pipe with a cup or duct tape to prevent any sand from getting inside the pipe (the sand will come out into the pool if it gets into the pipe). Fill the tank 3/4 full of pool filter sand. Make sure it is genuine silica pool filter sand from a pool company. A lot of big box and home improvement stores sell play sand as filter sand. This will cause you more problems!
Jun 16, 2011 | Hayward SAND FILTER, PRO SERIES
Water comeing out cloudy and makeing suds in pool
There could be a few things causing these problems. How old is the sand in the filter? Filter sand looses its filtering ability after 3-5 years and needs to be replaced. If the sand needs to be replaced, make sure you get actual pool filter sand. A lot of big box and home improvement stores sell play sand as filter sand. That will cause your pool to stay cloudy and never clear up. If the sand is less that 3-5 years old, you may need to clean it with a liquid filter cleaner that is poured through the skimmer. This works quite well!
Another issue causing the cloudiness and bubbles could be the type of chemicals you are using. I know that shock from big box and home improvement stores cause the water to be cloudy. Algaecides from these stores also cause foaming.
Jun 15, 2011 | Hayward SAND FILTER, PRO SERIES
Pentair sm2-pp3 valve, triton II filter. Upon
Lots of sand? You may have a broken lateral in your filter.
To repair, you will have to remove all the sand from the tank to physically inspect.
Might you have changed the sand this year? (top 1/3 needed to be changed every 3 to 5 years normally) If you changed the sand ... did you put water in the filter tank first? If not ... there is a good possibility you broke a lateral (a small pipe with slits in it) when you put the sand into the filter.
It could be that you have too much sand in the filter. Check the owners manual for the clearance - top of sand to top of filter.
Thanks for your interest in FixYa.com
May 14, 2010 | Pool & Spa
Sand Dollar Filter
If sand is returning to the pool, the most common cause is the laterals, or the internal pipe is not connected to the valve properly.
If you have laterals with "slots" on one side and solid plastic on the other side, the slots have to be installed so that the slots face downward, toward the bottom of tank. If one, or more, are facing upwards, you are pulling sand right into the pool. If you have the newer laterals, with slots on all four sides, one, or more, may not be tightly in place.
If you have too much sand in the filter, that could cause this issue also. Pentair recommends using the #20 Standard Silica Sand in the filters.
Hope this helps!
Jun 13, 2009 | Pentair Sand Dollar 19" Filter with 1 Hp...
Hayward SAND FILTER, PRO SERIES Logo
100 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
