Power will not turn on,checked all power connections
  • 27,725 Answers
Replace your PSU then test all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty because a computer has to have an end to the circuit any fulty leads will lead to no boot up
good luck
Posted on Sep 15, 2010
I TURN KEY POWER CUTS OUT CLOSE HOOD HARD POWER RESTORES TURN KEY POWER CUTS OFF . TAP FUSE BOX POWER RESTORES TURN KEY POWER CUTS OUT. WHATS GOING ON I CHECKED WIRES AND CONNECTIONS IM LOST
Apart from the obvious electrical connections, you could try checking each fuse. Sometimes they appear to be ok but 1 end of the fuse may be broken and touches intermittently. Try lightly tapping each fuse 1 at a time with the handle of a screwdriver and see if anything goes on and off.
Mar 21, 2017 | Cars & Trucks
My acer aspire v5-531 will not turn on and no lights at all when connected to tested power supply
kindly remove the battery n check with power, if possible get checked the power connector of the power supply, with a multi meter, if its ok then its a main board issue. u have to change the main board
Jul 16, 2016 | Acer Aspire Laptop PC V5-531-4636
Lower element is not getting any voltage
First check that all connections are good. turn off power and take off the cover plates pull out the wires connected with wire nuts and check that they are not loose remove any electrical tape covering the nuts and turn power back on. with a meter check that you have 220 at the connections. if all is good at the incoming service check the upper element if power passes it in parallel check the exiting connections.if good there check the bottom power if you have 220 there either your element is bad or the thermostat. check the element by turning off power again and check the element with a continuity tester. if the element is good then your thermostat is probably defective try turning it up higher and see if you get 220 out of it.
May 04, 2015 | RELIANCE ELECTRIC WATER HEATER
Garmin 765T
Hello
Try connecting it to a power outlet and check it turns on. If does then the replacement Battery is faulty. Once connect to power outlet check the battery connection from the GPS if they give out any power (You will need a multimeter to check). If the is power coming out from the GPS to the battery connection then the battery is the problem, Make sure to check the battery too. If it works or no.
Hope that helps
Apr 10, 2014 | GPS
Television will not turn on
Check your power cord, power socket, try connecting something else on the socket, try connecting the tv on another socket, ohhh, did you recently have a power outrage?
If so your starter may have burnent, check a specialist for a valid diagnosis.
Nov 28, 2013 | Televison & Video
Dvd is stuck in my player
follow this steps and fix i.t God bless you
No power
  1. Check if the power cord has been properly connected to the power outlet.
  2. Check if the main power has been switched on.
    (DVD player's power supply transformer could be burned out)
Screen is "frozen" or completely black, or Power button does not work
  1. Try turning the power off and wait 3 seconds before turning it on again.
  2. Make sure the TV and VCR (if connected) are set to the correct channel or line.
Oct 02, 2013 | 2003 Toyota Sequoia
Cannot turn on the printer even if connections are ok ?
The only thing that could stop you from turning the printer on other than a broke printer is the power/power cord is not connected. The printer should turn on without a USB or parallel printer cable attached.
If no lights are showing when you try to power the printer, check the power connection in the back of the printer to ensure it is plugged in, check the plug into the adapter is connected and that the power cord's plug is connected to the wall outlet - if you have a power strip make sure it is turned on and the circuit breaker is not popped. Make sure that there is power to the outlet by plugging in something else to show it has power. If all of those check out ok and you have a meter, check for voltage at the power connector at the printer (pull the plug out of the printer and check voltage from inside the plug to outside the plug. It should be 18 vac.
If all of this is ok, there is something wrong inside the printer. Probably time for a new one as cost to repair is probably too high.
Oct 11, 2010 | HP DeskJet 810c InkJet Printer
Does not turn on
have you checked the power pack connection if it is well connected to the mother board?
Also, does the fan on the power pack work when you turn on the mother board.
Since its not turning on, then the problem is a power related is problem. Therefore, you need to check those areas that supply power into the motherboard, such as the; power cable/cord, power pack, etc.
I wish you good luck.
Mar 22, 2010 | Computers & Internet
Won't turn on, switches itself off after a few seconds
Check that the main power switch on the system rear is turned on. Check the AC power cord is securely inserted in the system and the electrical outlet. Also check the connecting power cord is not damaged/bent and the connections in the power plug are OK
Mar 11, 2010 | Sony Playstation 3 (PS3) Console
TRC520 CB wont power up
Hello, First of all you only have the Power wire Red, and the ground wire Black to connect for 12v DC to power the unit. If you memory power it is usually connected to a constant power source such as the cigarette lighter or continuous 12V dc powersupply off of the battery. These are the only connections that should be connected to provide power. Since the unit will not turn on I suspect that the CB's power supply and regulator have been blown. Another possible choice is that the radio was working and someone removed the antenna cable and the the RF power amplifier malfunctioned taking the power supply and regulator with it. To solve this problem, check the voltages on the wires before connecting them to the radio (these should be the 12 volt power off of the radio circuit, and the 12 volt power off of the continuous 12V connector (or the cigarette lighter). These voltages should read 12V. Connect the CB with it turned off and measure the voltages (should be 12V) Turn the radio on and check the voltages (should be a little less than 12V) If the radio does not come on then the internal power supply of the radio might be defective (In this case I would advise taking the CB to a qualified radio repair shop) I hope this helps Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 11, 2009 | Radio Shack TRC-521 CB Radio
Computers & Internet Logo
David Payne
David Payne
