Question about Saeco Coffee Makers & Espresso Machines
Salton won't pump water - Saeco Coffee Makers & Espresso Machines
What kind of Saeco machines have you got?
It's a problem of syntia? could you explain me specifically what is the problem, so I could be helpful.
bye
F
Posted on Sep 16, 2010
The washer broke filled with water and won't drain
see this causes and fix it. God bless you
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Sep 28, 2012 | Kenmore Washing Machines
I have a Salton micorwave oven (MW-2027P). The timer works but the cook setting will not start. There is also no light on the inside when I open the door.
I had this exact same problem with my salton microwave! Even tried taking it back to the store, but with no reciept there was little they could do. Anyways try jiggling the clasps on the side of the the door, the ones that connect it to the microwave. Mind you don't jiggle too hard. Now firmly close the door, you should hear a distinct click. Now try it! The light only works when the microwave is on. The microwave won't work unless the door is closed properly and my problem was the claps were stuck! I hope this helps.
May 15, 2011 | Salton RRMW1 / RRMW1A 900 Watts Microwave...
I need a salton dishwasher instruction manual please where do i find this. also the water does not want to go out whitout puting the drain pipe flat on the ground!
you have not mentioned the model no. of your dishwasher.
The instruction manual for Salton SDW12 is available at this site. Scroll down after you select Download button and enter the code displayed to enable download.
It says Haier on the link but the actual manual is for Salton.
Hope this helps. Check the installation instructions for the output drain connection.
Sep 29, 2010 | Dishwashers
How do I make rice with the salton 5 cup rice cooker
Here is a tip that I wrote about rice cookers and the amount of rice and water needed...
How much Rice and Water go in the Cooker
http://www.fixya.com/support/r5396567-much_rice_water_go_in_cooker
heatman101
May 20, 2010 | Salton RA5 5-Cup Rice Cooker
Salton RA3 3-Cup Rice Cooker Question
Put equal amounts rice and water (up to 3 cups only) in liner pot, plug in, put lid on, flip little front switch. 10-15 minutes later it will be done and the pot will switch to "warm" mode by itself. Gently fluff with paddle before serving. You can also add salt or other seasonings to the water/rice mixture before starting.
Mar 19, 2008 | Salton RA3 3-Cup Rice Cooker
Salton ice cream maker manual
I downloaded a manual for the ICM21, same picture as yours, today, August 2009, from kitchen.manualsonline.com
Click on frozen dessert maker under Member Contributed Manuals.
Click on Salton frozen dessert maker
Scroll down to Comments, get this manual
Click on instructions
Salton ice cream maker pdf
The one there is for the old ICM21 ice cream maker.
Jan 16, 2008 | Salton ICM-21 1.5 Quart Ice Cream Maker
Need Instructions on how to use the Salton RA-10NS Rice Cooker
hi!
good news! you can use any small cup as a replacement for that. just remember that the ratio is 1:1
1 cup of rice = 1 cup water.
hope this helps!
cheers!
Jan 05, 2008 | Salton RA10 10-Cup Rice Cooker
Coffee Makers & Espresso Machines Logo
265 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
