Question about Toys
How do we take apart the little tikes wave climber? It looks like one side goes up while the other goes down.....the platform keeps it from moving. What is the trick?
  • 6 Answers
SOURCE: REPAIR LARGE CRACK IN THE PLASTIC OF LITTLE TYKES CLIMBER
You call them up and you COMPLAIN. You tell them that you just bought this item in the last 6 mos. and the store will not take it back. Talk to a supv. if you have to. THEN they will tell you to take a permament marker and write a # they give you on the item, take a pic, email to them, and then call them back up and you should be able to 'order' any item of the same value you paid thru their online c/s. We had a Cozy Coupe car from 2003 that the parent handle swiveled and didn't hold firm. I called them up in 2005, sorry, had to lie and say I had just bought it that year, and they had me do what I explained, and then I purchased a $60 toy box from them and I did not pay for S&H. Good luck! I've always told people they back their products, regardless of how old they are! And honestly, that's what I thought with climbers, etc. They should really offer you a replacement. Now if none of this works, EPOXY glue always works great! And brace with something? Just bring the broken piece into Home Depot. :)
Posted on May 31, 2009
  • 6 Answers
SOURCE: hi I'm looking for spare parts to a Little Tikes
Little Tikes sells replacemnt parts for all most anything. Have you checked their website? Look in the consumer section for replacement parts and then search by the type of equipment.
Posted on Jun 13, 2009
SOURCE: Disassembly of Little Tikes Wave Slide playground
Hi there! On putting together my daughter's hide and slide (not having ordered it or seen it before) followed the instructions and managed to put the bottom step inside the frame instead of outside. Of course other half only noticed it once I had put the top step in - so to take it apart you will need the following:
Two long heavy duty flat bladed screw drivers and a lot of muscle!
First take the top platform on one side and disengage the two tabs on one side. Then insert one of the srewdrivers under the red locking tab and push up - the plastic will distort however, returns to original shape with judicious use of a heavy hammer. You will need to use the second screwdriver to disengage the clip in the tab and then twist the platform out of the frame to release the second. Repeat for the other side. The bottom platform is a just a reversal of the installation to release. I haven't moved the slide but as this is a 'gravity' fix should release with a bit of 'persuasion'. As these things are not designed to be taken apart after assembly they are frustrating to take apart - but with a little flex and muscle it can be done. Hope this helps.
Simon
Posted on Aug 02, 2009
  • 100 Answers
SOURCE: I too need the tunnel for the little tikes 8-1
You might want to go to the link http://www.littletikes.com/consumerservice/replacementparts.aspx You can order replacement parts at this site. If you are having issues ordering throught this link then call this number 1-800-748-2204. Please let me know if this works for you. This is the contact information for little tikes.
Thank you
Posted on May 05, 2010
Ironfist109
  • 3018 Answers
SOURCE: Have a Little Tikes Endless Adventures Mountain
Regards, Tony
Posted on May 17, 2011
Little tikes bike trailer pulls to side
Look under trailer and see if the axle is loose or disconnected on one side. That would keep it from running straight. Look it over while you have it upside down. It will probably be something obvious.
Sep 07, 2012 | Little Tikes Cozy Cruiser Trailer
We have a Little Tikes sports climber (the one with a slide, goal and basketball/netball hoop. We have lost the nut that fixes the basketball hoop to the climber. Any suggestions please?
If there is an identical nut attached to any other part of the equipment, remove it, and take it to your hardware store to see if they have a match, then put it back on after you find the new one.
Jun 02, 2011 | Little Tikes Swing Along Castle
I bought an older four sided little tikes climber cube with slide and need help putting slide on!
I might be little late in replying ur query.. u might have even figured it by now.. But this is for the future reference.. here is the assembly instruction of cube climber with slide
http://www.littletikes.com/pdf/4969_4589.pdf
Jun 01, 2011 | Toys
Have a Little Tikes Endless Adventures Mountain Climber. The brown platform has cracked and has a hole in it now. I would like to replace this part.
Regards, Tony
May 17, 2011 | Little Tikes Endless Adventures Look Out...
I too need the tunnel for the little tikes 8-1 climber.. Not sure where to look??
Thank you
May 05, 2010 | Toys
Help! I have a Little Tikes outdoor play set with
I am looking for a replacement tunnel for ours. Would you be willing to sell the tunnel??
To take apart...Start with the slides, remove the rods first. Then select any exterior panel corner and pull up on one side and push down on the other. The tabs just slide, there is no hardware to loosen. Hope this helps.
Jul 18, 2009 | Little Tikes Endless Adventures Playcenter...
We have a 'Little Tikes Hide and Slide' and we need to take it apart. How do we do this (without breaking it)?
The key is the red locks on each side of the climber wall. Be careful not to force the red locks open because it WILL cause them to tear on the seam.
I used two big flat screwdrivers and another pair of strong hands. What I did was I inserted the screwdrivers in between the outer part of the red lock and the yellow wall, leaving just enough gap between the screwdrivers for a hand to slide in. Then pushed the screwdrivers outward as lever to loosen up the lock. Then my husband finished the job by inserting his hands between the gap created by the screwdrivers and pull.
I hope this is helpful for you, as I know I'm better in demonstrating than describing.
Jul 10, 2009 | Little Tikes Toys
The key is that one side/side combination must be done 1st then the others are easy. On ours I think it is the yellow/orange combination. Just try all the combinations. One works pretty easily, the others do not. We struggles too until we found the right combination. good lluck
Jul 09, 2009 | Toys
Hi I'm looking for spare parts to a Little Tikes Jungle Climber (plastic climbing frame - themed as jungle safari by Little Tykes Jane
Jun 11, 2009 | Toys
Need Instructions
I also needed them. I downloaded them from the Little Tikes website: http://www.littletikes.com/toys/jungle-climber.aspx
Apr 28, 2009 | Computers & Internet
Toys Logo
547 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
