Question about Danze 1 1/4 Drain - D495082 - Chrome
How do you join this to a 1 1/2" drain - Danze 1 1/4 Drain - D495082 - Chrome
    Filmmaker:
    Uploaded 5 video answers.
  • 119 Answers
There is an 1-1/4 X 1-1/2 reducing plastic or rubber washer that you should be able to purchase at most any hardware store or home center. You will still use the 1-1/2 nut, but then you slide the reducing washer ( tapered side down) up on the Danze 1-1/4 drain.
Posted on Sep 15, 2010
How Do I Restore the Default VLAN Configuration of an Interface?
We can take S5700-28P-PWR-LI-AC as example.
The default VLAN configuration of an interface involves the default VLAN of the interface and the VLAN that the interface joins. By default, the default VLAN configuration of an interface is as follows:
Access: The default VLAN is VLAN 1, and an access interface joins VLAN 1 in untagged mode.
Trunk: The default VLAN is VLAN 1, and a trunk interface joins VLAN 1 to VLAN 4094 in tagged mode. That is, a trunk interface allows all VLANs.
Hybrid: The default VLAN is VLAN 1, and a hybrid interface joins VLAN 1 in untagged mode.
Dot1q-tunnel: The default VLAN is VLAN 1, and an dot1q-tunnel interface joins VLAN .1
Negotiation-auto or Negotiation-desirable: If the interface is negotiated as an access interface, the default VLAN configuration of the interface is the same as that of the access interface. If the interface is negotiated as a trunk interface, the default VLAN is VLAN 1 and the interface joins VLANs 1 to 4094 in tagged mode. That is, the interface allows all VLANs.
Run the display this include-default ' include link-type command in the interface view to check the link type of the interface, and then perform one of the following configurations to restore the default configuration of the interface.
Restore the default VLAN configuration of an access or dot1q-tunnel interface.
<HUAWEI> system-view
[HUAWEI] interface gigabitethernet 0/0/1
[HUAWEI-GigabitEthernet0/0/1] undo port default vlan
Restore the default VLAN configuration of a trunk interface.
[HUAWEI-GigabitEthernet0/0/1] undo port trunk pvid vlan
[HUAWEI-GigabitEthernet0/0/1] undo port trunk allow-pass vlan all
[HUAWEI-GigabitEthernet0/0/1] port trunk allow-pass vlan 1
Restore the default VLAN configuration of a hybrid interface.
[HUAWEI-GigabitEthernet0/0/1] undo port hybrid pvid vlan
[HUAWEI-GigabitEthernet0/0/1] undo port hybrid vlan all
[HUAWEI-GigabitEthernet0/0/1] port hybrid untagged vlan 1
Restore the default VLAN configuration of the Negotiation-auto or Negotiation-desirable interface.
[HUAWEI-GigabitEthernet0/0/1] port trunk allow-pass vlan all
Jun 28, 2016 | Compex PS2216 16Port 10100Mbps Smart...
Tip
Nimbuzz tricks
<span> <a href="http://t3.gstatic.com/images?q=tbn:ANd9GcSf57CUbBs7cwN_58TpgE9Tg9QKtfomhmP--KkQ-LnAjG17IunI1Q"><img src="images?q=tbn:ANd9GcSf57CUbBs7cwN_58TpgE9Tg9QKtfomhmP--KkQ-LnAjG17IunI1Q" /></a><span><span><b>EASIEST WAY FOR HACK ROOM</b></span></span><span><br /></span><span><span>EAsiest way for hacking room , follow instruction : after blocking hacking room trick by nimbuzz server . in last update here i want to learn you the old and gold way for get a nimbuzz room for hacking a room and get it you need an empty room !! if you want hack an full user room you should try to make it empty !! Now after it follow this instruction :<br /><span>1) log in with an id on BombusMod , after that set join room setting on it and hold & minimize it. now log in with that id on nimbuzz Symbian or java !<br />2) you need add target room to joined room history for this join that room for once !<br />3) now go to room history and try to join Target room for 5-6 time but dont join , for this select room and after 3-4 second select cancel !! do this for 5-6 !! Don't forgot this : TRY TO JOIN TARGET ROOM NOT JOIN !!!<br />4) Its time to try build target room with Nimbuzz java ro symbian ! !do this and minimize nimbuzz than go to bombusmod and join target room , try to join it for 4-5 time !!! after it You will owner in that room</span><br /><br /><span><b>TRICKS FOR REMOVE ADMIN & OWNER ID</b></span></span></span><br /><a></a><span><br /><span>1. go to baby 1.7<br />2. account seting with hang id<br />3. resource same (hang id)<br />4. send room message period (11) don't much.Enjoy friendz..</span><br /><br /><span><b>LOCK YOUR ROOM</b></span><br /><span>How to lock a Room ?. . . . First,entre in your room on bombus,bombusmo or any jabber client. . Click action in right side button on your phone. . On your room name. . Then,click,configure. . And,tick password. . . . Then,create a secure password. . Then,option and send it. . Now,your room now locked</span><br /><br /><span><b>SAVE YOUR ROOM</b></span><br /><span>Save your room. . . . Jab nimbuzz refresh ho to apna room lock karde. . Isse apka room hack nhi hoga. . Zyada tar rooms nimbuzz refreshing ke time hi hack hote hai. . So be carefull. . !!</span><br /><br /><span><b>HIDE YOUR MOBILE DISCRIPTION</b></span><br /><span>1.) Go to tool than click on option<br />2.) there u vill see SHARED PLATFORM INFO UNCHEKED IT<br />3.)Save and relogin</span><br /><br /><span><b>BY THIS CODE U CAN DC JAVA AND NIMBUZZ DESKTOP BY CHECKING CLIENT VIRSION FROM BOMBUS</b></span><br /><span>1.Put the c0de in your bombus resource and then l0gin.. 2.Then press the acti0n butt0n 0f the online id and select cilent versi0n...then the id will get dc.<br />C0de is </span><br /><br /><span><b>KIDNAP OTHER ROOM USER TO UR ROOM</b></span><br /><span>1. Loging with ur Bombusmod or avalon 2. Join ur ro om and also join that which room users you want to kidnap. 3. Now select actions on other room users ids and select the option "invite to conference" Then select the room and click on ok. The id will in ur room.</span></span></span>
on Jul 17, 2011 | Cell Phones
Water in dishwasher will not drain
first step is to check to see if the spigget on the s bend , under your sink, the place where the drain hose joins the drain pipe is not block, check that to start, usually if the hole in the spigget has not been fully open food residue gets stuck there and prevents the d/w from draining.
Aug 05, 2012 | Whirlpool Dishwashers
When i wash my truck i get mosture in the headlightcover and it will not dry up
Take the bulb out and try to dry the inside of the headlamp with a lint free towel, then clean the outside of the headlamp around where the lens and the assymbly join with alcohol. Them run a small bead of clear silicon around the parimeter of the joining pieces. Or you may drill a 1/8 hole in the lowest corner of the lamp to allow the water to drain out. Hope this helps
Apr 15, 2011 | Land Rover Discovery Cars & Trucks
SEVEN SQUARES ON A PIN BOARD I CANT GET IT
Hi there,here is you answer,enjoy
There are 6 lines of pins
On each line they are in different positions
So for this occasion we are gonna number these from 1-28,from left to right then from top to bottom
We will give each square a colour and a number
1*Large blue square join the 4 corners at pins 8 to 16 to 23 to 28
2*Large yellow square join at pins 4 to 12 to 21 to 27
3*Small red square join at pins 17 to 22 to 24 to 26
4*Small brown square join at pins 14 to 18 to 20 to 25
5*Small light blue square join at pins 5 to 9 to 11 to 15
6*Small white square join at pins 1 to 2 to 6 to 7
7*Medium white square join at pins 3 to 10 to 13 to 18
Hope this helps its the easiest way i think i can describe it
JonnieC
Jan 06, 2010 | Nintendo Professor Layton & the Curious...
Water in bottom of frodge
Sounds like the drain for defrost not draining. probably has got a piece of food or a piece a paper over the hole. depending model you would remove cover for the evaporator to find the drain.
Apr 20, 2009 | Refrigerators
I need help with puzzle 100
There are 28 PINS -- Count each PIN starting from left to right on each line. (1 -- 28)
Square ( 1) Join together Pin No's ( 1 -- 2 -- 6 -- 7 )
Square ( 2) Join together Pin No's ( 4 -- 12 -- 21 -- 27 )
Square ( 3) Join " " " ( 5 -- 9 -- 11 -- 15 )
Square ( 4) " " " " ( 3 -- 10 -- 13 -- 19 )
Square ( 5) " " " " ( 8 -- 16 -- 23 -- 28 )
Square ( 6) " " " " (14 -- 18-- 20 -- 25 )
Square ( 7) " " " " (17 -- 22 - 24 -- 26 )
GOOD LUCK.........
Apr 12, 2009 | Nintendo Professor Layton & the Curious...
Tracks too short to to create CD from hard drive.
either have to delete the short tracks from playlist to burn...when i get mssg theres usually nothing there (hit new track 2x by accident, just silence) Or if u want what is on the short tracks, have to join it to longer track b4 or after it, making one longer track, and no more 1 sec track...to do: hold playlist edit and delete track button, will ask if want to join two tracks, say yes and its done...When u do this, the track you do this on will b joined to the previous track, it will give u mssg showing which two tracks about to join and what track name will b left...(for example do u want to join track 01 to track 02...resulting track name will b track 02)..can then burn once all short tracks either deleted or joined to larger tracks...
Apr 03, 2009 | Alesis MasterLink ML-9600
How to solve no 100: seven squares
There are 28 PINS. Count each PIN starting from left to right on each line. (1 to 28 )
Square 1-- Join together PIN No's ( 1 -- 2 -- 6 -- 7 )
Square 2 -- Join " " " " ( 4 -- 12 -- 21 -- 27 )
Square 3 -- Join " " " " ( 5 -- 9 -- 11 -- 15 )
Square 4 -- Join " " " " (3 -- 10 -- 13 -- 19 )
Square 5 -- Join " " " " (8 -- 16 -- 23 -- 28 )
Square 6 -- Join " " " " (14 --18 - 20 -- 25 )
Square 7 -- Join " " " " (17 -- 22 - 24 - 26 )
Hope you can complete this Puzzle now ----------- GOOD LUCK
Apr 01, 2009 | Nintendo Professor Layton & the Curious...
Danze 1 1/4 Drain - D495082 - Chrome Logo
Top Danze Plumbing Experts
David Wiebe
Level 1 Expert
Donni Steen
john h
Are you a Danze Plumbing Expert? Answer questions, earn points and help others
