Question about Samsung TV Remote Control
The TV button liht keeps flashing on my BN59-00634A remote. Nothinh else worls.
    Habit-Forming:
    Scholar:
  • 85 Answers
I had the same problem with my remote if the red light (TV) flashes it means the remote is transmitting a signal , I removed the back of the remote ( you can ususlly do this by using your nail along the edge it is onnly clipped in) and on the PCB was a white substance I can only summise must have leaked from the batteries I cleaned it ( with Brut aftershave it's 40% alchahol ) and it works fine now hope this helps .. Vortash
Posted on Jul 20, 2012
4 Suggested Answers
  • 11800 Answers
SOURCE: How do I operate my
To operate the tv you only need 6 buttons:
1 - the power -on/off one : top left circle with vertical line in it.
2 and 3 - the volume buttons , in the middle in the form of + and -.
4 and 5 - the channels buttons, next to the volume ones , in the form of up and down arrows.
6 - the mute button, clearly labeled, next to the + button.
There are also the numbers buttons for direct access to the channels but you don't really need them.If you want one that has just 6 buttons then get
http://www.dynamic-living.com/product/tek-pal-simple-tv-remote/
Posted on Jun 01, 2011
SOURCE: bn59 00463 volume works nothing else cant turn on
Step 1: Remove the batteries
Step 2: Press the power button (red button) on the remote control 5 times.
Step 3: Replace the batteries and your remote should work fine.
Posted on Oct 27, 2009
SOURCE: Samsung Remote BN59-00539A not working
Remote Control not working with dvd plyer
Posted on Aug 13, 2010
One for all remote codes don't work URC-3920
Hi keep teaching should come up with more if still dosent work try one for all web site or phone them very helpful
Aug 04, 2012 | Televison & Video
Tv cable and dvd lights keep flashing and tv doesn't get signal
The remote is in safe mode, remove batteries and reinsert batteries while keeping the button 2 pressed.
Aug 04, 2012 | Logitech Harmony 200 Universal Remote -...
I can find codes for a black standard uverse remote which is 1040. But I cant find a code for silver standard uverse remote. Uverse says to talk to DYNEX. Can you help?
i currently use uverse and none of there remotes work for dynex tv's i suggest buying the logitec harmony 520 or 420 or above remote from amazon read the reviews there around 40 dollars and lets you control everything and they connect to you pc you just plug in you model number and the remote learns all the commands as well as lets you set up activities that will allow you to control multiple devices without having to switch between hitting the tv button, home theater button, uverse box etc.
hope this helps.
Mar 14, 2011 | Televison & Video
My Philips remote stopped working. 42PF7421d/37
my philips tv remote stopped working after i tuned a simple remote to it! so now my origenal remote will not worl model no. 26pfl5522d/05
Dec 31, 2009 | Philips Televison & Video
Hi, I have a panasonic tv model tc21xy3 standby power only red liht can you give a solution of this trouble pls.
Your Tv Horizontal deflection doesn't work, try to switch ON your TV by remote control or by pressing the program up or down button in the TV set. If still working check the B+ in the capacitor rated 200Vdc. monitor the voltage as you press the program button, it must have a 90vdc , or remove first the Horizontal Output Transistor before you switch on the Tv. Then monitor the Voltage in B+. If it is present your Power supply is good, if not then check the component in Power supply section. if the B+ is present check the horizontal area.
Sep 10, 2009 | Televison & Video
Lost remote - can't navigate between episodes on DVD
You do need the original remote however, you can use your TV remote or your cable/SAT remote. They usually have DVD button on them. You just need to read the manual on how to program these remotes to worl with your DVD player. If all else fails, Radio Shack or CVS has universal remotes for about $10 ~ $20.
Mar 23, 2009 | Panasonic Televison & Video
SKY REMOTE
Press TV
Press and hold Select & Red until the LED blinks twice
Press TV
Type in code 0 0 6 0
press the Power button on the remote, if the TV turns off press the select button and everything should work, if the TV stays on press the TV button on the remote then the Power button again, keep doing this until the tv turns off, when it does press the Select button and all should be ok.
Feb 01, 2009 | Toshiba MR120 Remote Control
Have 73 inch mitsubishi tv and the timer button keeps blinking, no picture, how do I fix it
i want to know wy my tv sometimes turn on and sometimes not and the green liht is allways flashing
Sep 21, 2008 | Televison & Video
42" Plasma TV Problem
same frustrating symptoms on brand new 42inch here! tv just turns itself off sometimes without warning or if changing to certain channels. leaves red light flashing for a while then red light goes away. any attempts with remote gives flashing green liht on tv. manual power off and on restarts tv but auto off again. found while manual power on keep changing channel on remote till stable picture appears. then use remote to shut down tv - solid red light indicates standby mode. then use remote to turn on again... till next time it happens. but what is technical fault??
Aug 18, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Samsung TV Remote Control Logo
919 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
