Question about Miele Novotronic W1918A Front Load Washer
Leaking Novotronic W 1918
Have the same problem: ever get an answer???
  • Anonymous Jun 21, 2008
    mmmmmmmmm
  • jgum Jul 14, 2008
    Also leaking, not near hoses, but closer to where the electrical plug is located. I also think it's happening when the machine is draining.
2 Suggested Answers
SOURCE: my miele novotronic W 1918 has a bad smell. Is
W1900.pdf (http://www.mediafire.com/download.php?mynd4zimd2m)
Posted on Jan 07, 2011
Mieie novotronic 1918 is filling with water when not in use? I
Replacing water valve will most likely fix your problem
Sep 22, 2017 | Washing Machines
The owners history of colt 45 government model rail gun serial numbers RG09120
Here is a link to the gun, and you will find Serial Number Lookup under 'Customer Services'.
The answer is 1918.
1918 MODEL 1911 MILITARY
Colt Rail Gun
Dec 17, 2015 | Optics
Miele w1918
Link to user manual. Code listed on page 32 indicates internal error Call service department.
Miele 1918 Operating Instructions Manual Page 32
Aug 03, 2014 | Miele Novotronic W1918A Front Load Washer
Miele 1918 w will not turn on
Thank you very much "fixit999" Very helpful manual.
Sep 24, 2012 | Miele Novotronic W1918A Front Load Washer
Novotronic 1918 front load washing machine- not spinning 1st and 2nd rinse lights flashing
the flashing lights mean it's "disabled". You need a qualified repairman to service it further.
May 06, 2012 | Washing Machines
My miele novotronic W 1918 has a bad smell. Is there a filter that i should clean? Can't find it.
There is a fluff filter in the bottom left hand corner behind the flap. have a small tray, like a baking tray underneath it and open the flap with a flat lever or the miele yellow key. Turn the tap about 1/4 of a turn and collect about a litre of water from the unit. when it has stopped draining unscrew the tap all the way out and clean the fluff filter which is the tap in your hand. also have a look in the hole and you will see the drain pump. make sure this is free of any foreign particles and then re-screw the tap back making sure it is tight.
To avoid the smell in the unit run the machine on a few 95c washes. you can use a cleaner or just white vinegar as a cleaning agent. after every wash keep the door open for about 30 mins to let it dry out as shutting the door is then a perfect enviroment for bacteria to develop and the smell.
Also check the door seal for any foreign particles every wash.
Hope this helps.
Jan 29, 2010 | Miele Novotronic W1918A Front Load Washer
Miele W 1918 washing machine door seal replacement. Can my husband do it? Can't find instructions. Have had this problem before and it took the service rep ~15 minutes t o pop off old one and replace with...
I have done it. I had someone fix my machine once and they put it on wrong so I had to take it out and put it on correctly. The only tricky part is getting it in place around the drum. That takes a bit of care to do it right. Then clamp it down with the skinny clamp that comes with it.
Jun 24, 2009 | Miele Novotronic W1918A Front Load Washer
Miele W 1918 washing machine front door seal replacement
the seal on the front door runs around 60 bucks and its quiet easy replaced takes 1/2 hour
May 27, 2008 | Miele Novotronic W1918A Front Load Washer
Miele Novotronic W1918A Front Load Washer Logo
210 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
