Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Copy limit Is there a setting that I can go to to limit the number of copies made at one time?
No, there's no producer intrest in this. you have to make many copies for selling toner and new machines.
A setting to limit on 4 copies and a pause between it is not a setting.
People wil make fast personal copies rather then go to the man with the big cheap copier and ask to do it fot them.
you can only set a a number of copies at an id.
an id is a number with pasword.
Or you can use a chipcard system on the copier.
Network print solutions can only limit the printing from computers not the manual copies.
So people print the document from the computer and manual make 100 copies. Only one copy is counted....
good luck
Posted on Jun 04, 2008
    Problem Solver:
  • 10 Answers
The only way is to goto additional functions > System Settings> dept I.D > set a user code and password, then you can set a copy limit per user id, once a copy limit is reached you have to reset it or create a new user I.D. Thats the only way, you can also get reports on how many copies each I.D has done..
Hope this helps
Posted on May 17, 2008
How do I get phone numbers to sin card ?
A "sin" card would be awesome, but I'm sure you mean the "sim" card! Every phone has its specific procedure for copying contact numbers to the sim card. Some do this by default. Some must have a setting selected. Most have a very simple way to select individual contacts to be copied to sim, from the "context menu" - press the button or key that displays the symbol with three horizontal lines. Note that sim cards have a set limit of the number of contacts that can be copied: if your contact list is large you may only be able to copy some of them. This limit will also apply to defaults chosen in settings. When the limit is reached copying will either cease or existing contacts on the sim will be overwritten. There will probably be no indication when the limit is reached, so you won't know that contacts are not being copied or overwritten. In other words, the sim contacts may be incomplete, so don't rely on this method for backing up your large contact list.
Jul 28, 2014 | Samsung Galaxy Y GT-S5360 Factory Unlocked...
Disable the Key counter on my Konica 7130
HI,
Please refer the manual by clicking on the below link.This will solve your problem.
http://help.nceas.ucsb.edu/images/2/2a/Konica.pdf
Oct 07, 2008 | Office Equipment & Supplies
I have a SanDisk M230 (512 MB) MP3 player. I have never had a problem copying MP3 files to it using Windows Explorer. Never! I've just tried to copy some more files (plenty of available space) and...
When the memory circuit starts to fail it goes into lock mode: it only allows you to copy the files already in, no writing since they will be corrupted anyway and in the process damage the ones already in.
That is an age related defect - the memory chip inside your player has a limited number or write operations available and the chip has reached this number : basically the memory chip is dying of old age.
There is nothing you can do about that, time for a new player.
Jul 11, 2011 | SanDisk 2GB microSD Memory Card
Pin code reached the copy limit. How to re-set the copy limit for pin code?
The Auditron feature is used to prevent the machine from being used by unauthorized users and also to track the total number of copies or prints produced with each account. When the total number reaches the upper limit set up by machine administrator, users cannot use the copy feature on the machine. Before resetting the machine you will want to print a usage report. Those instructions are at the bottom of these instructions.
  1. Press the [Log In / Out] button on the Control Panel. See the Related Items below for additional information on navigating the Control Panel.
  2. Press the [Select] button below the Display Screen to select 'System Settings.'
  3. Use the numeric keypad on the Control Panel to enter the Administrator Login ID, then press the [Select] button to confirm.
    NOTE: The default System Administrator Login ID is set to 11111. The System Administrator mode allows you to customize many settings on the machine to suit your particular requirements. The machine enters the Machine Administrator mode only when a correct System Administrator login ID is entered.
  4. Press the [Select] button until 'Auditron Admin' is highlighted, and then press the [Enter] button on the Control Panel to confirm selection. The Auditron Administration screen will be displayed.
  5. Press the middle [Select] button until 'Reset Acc Limit' is highlighted, and then press the [Enter] button. The 'Reset Accounts' screen will be displayed.
  6. Press the left [Select] button to reset all accounts.
  7. Press the middle [Select] button to cancel the request.
  8. Press the left or middle [Select] button to perform the action. The Auditron Administration screen will be displayed.
  9. Press the [Exit] button to return to the default screen.
Solution : How To Print Reports and Lists (Auditron / Copy Meter Report) The Print Report / List feature allows you to print various reports and lists for each non-print job.
  1. Press the [Machine Status] button on the Control Panel. The Machine Status screen will be displayed on the Display Screen. See the Related Items below for additional information on navigating the Control Panel.
  2. Press the middle [Select] button below the Display Screen to display the Report / List information.
  3. Press the [Enter] button on the Control Panel. The Print Report / List (Non-print Jobs) screen will be displayed with the options referenced in the table below.
Copy Meter
Lists the account data such the account name, the limit set for the account and the total number of copies for each account.
  1. Press the [Select] button to scroll to highlight the required report under the appropriate column, then press [Enter].
  2. Press the [Start] button on the Control Panel. The Report / List will print.
May 16, 2011 | Xerox WorkCentre M118 Black and White...
Maintenance message kept appearing but could still use machine. With info from your site, I think I cleared it. However, we keep getting a message that there is a paper jam (Jam 50). Could find nothing...
Maintenance message is setted by the technician, the numbers of copies that you can make with the same drum is limitted by the technician, (100k) if you reach this limit the maintenance message appears, you have to replace the maintenance kit (the opc drum, transfert corona, main corona) to avoid the bad quality copy. if you need to work with the machine you have to call the technician he can increase the counter limit to clear the warning message.
Dec 27, 2010 | Copystar CS-2030 Copier
Unable to photo copy- error exceeded copy limit
if department code is activated it could be the key operator or copier administrator has limited or set the number copies you can make in a day/month in your account( dept id code) or the original you are copying has to much data on that (example pictures and etc.) try to reduce the number of original so that the scanner memory will not exceed its capacity.
Jun 27, 2009 | Canon Office Equipment & Supplies
How do I program to identify & track users of the copy function
Yes adjust the settings under Colors/Quality.
to track the number of coies, you will have to enable logging (if the printer supports such things)
Otherwise you may need to keep track of the number of sheets of paper rather than copy history.
as far as the black and white option, it's in the printer's settings.
Always in printer preferences on computer, sometimes it can be enabled on the printer itself as well.
Apr 20, 2009 | Sharp MX-3501N All-In-One Printer
Sharp copier AL1655CS will not let us copy until a new drum is installed. There is a code to get it going anyway. It limits you to a set number of copies even if it is working fine.
c photo c photo then prss 24 machine copy quantity key up and down arrow key then press print key press 7 press print key then solve your problem no show any code print fine thanks
Apr 13, 2009 | Sharp SHP AL1655CS Printer, Scanner,...
Changing number of copies a person can make.
Hi
The universal password for Kyocera copiers is 6482 but only when you have gotten past the first password (if you have set one)
You need to go into MANAGEMENT area and set limits for each person.
Hope this helps
Feb 27, 2009 | Kyocera Office Equipment & Supplies
Phone contacts copying problem
sim memory is limited...hence you can retrieve the numbers by copying sim contacts to phone memory....you can get the numbers saved in your sim by opening contacts book and on top you find a menu called"options" there will be option to open your sim contacts
Nov 01, 2008 | Sony Ericsson K790i Cellular Phone
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
187 people viewed this question
old marine
old marine
