Question about DeLonghi Caffe Nabucco BCO70 Espresso/Coffee Maker
Water is leaking out the bottom while brewing coffee
  • 19 Answers
It could be a problem with the hoses and valves on the inside. When the heating element gets hot it pulls water from the reservoir through the valves. The issue with this is the limited availability of parts for this particular machine.
Posted on Sep 15, 2010
Water leaks from the top of the right side of commercial coffee maker
VPR has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the tank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
* If it leaks (from the bottom) only when you pour in water. Then your pouring it too fast and over flowing the fill tray. slowdown, watch the level in the tray. do not fill past the lid.
* If it leaks just sitting (not brewing) then there is a hole in the tank. Call for service.
* If it leaks after filling the tray half way. then the top of the tank has a leak, loose, cracked, or missing gasket. There is quite a few gaskets on the lid. Call for service.
* Final; Leaks are always bad around electrical equip. Best to unplug and call for service to be safe.
Aloha, ukeboy57
Apr 03, 2014 | Bunn VPR Coffee Maker
Bunn pour omatic commercial coffee maker will not brew and it leaks
VPR is a pour over "Volume Displacement" brewer. Required to completely fill the inner tank and heat prior to using brewer. BEFORE plugging in unit, water must be poured into upper tray and with brew funnel and empty pot in place. Keep pouring water into top fill tray until water drips out of brew funnel. Plug in VPR and allow it 15-20 mins to heat up. leave the pot as there may be additional water dripping. Remove power if there is any water spilling out from other places like the top pan cover or bottom of machine. With the initial heating done, take a full pot of water and slowly pour into the top filling tray. HOT steaming water should come out of the brew funnel to fill the (empty) pot. Prep is done and the machine can be used to brew a pot after 10-15mins of reheat time.
*** the machine you have needs to be checked for leaks in areas mentioned above. Water should only come out of brew funnel (if not present then the brew head or if that is missing then the brew pipe. All will need to be replaced prior to brewing.) Leaking under machine is an indication of leak(s) in pour tray,tank,tank cover, gasket, probe gasket. This machine like any used equipment should be checked out by qualified tech prior to use. Be aware that coffee vendors sometimes rent or loan brewers to customers.
Nov 08, 2017 | Bunn NHB Coffee Maker
How to fix the leak from the bottom of my cuisinart dgb-900bc
Re: Cuisinart grind and brew model DGB900BC leaking from the bottom. Finally fixed it before buying a new one. Remove the 4 torq screws (#10 bit check auto stores) from the bottom and remove the bottom. You will see a horse shoe shaped metal coil that heats the water from the resevoir. I found that the coil had a small hole in it. Cleaned it well and applied a coat of epoxy paste to the leaking area ( I used a product called PC11 from Ace) So far, no leaks, and the coffee maker is working like new.
Aug 10, 2012 | Cuisinart Dgb-900BC Grind & Brew Thermal...
Hamilton Beach BrewStation 12 cup Coffee Maker, coffee leaks into the bottom water reservoir after brewing.
there is a small rubber flap valve in the tank. if you carefully clean that on a regular basis your problem should end.
Dec 26, 2011 | Hamilton Beach BrewStation
Leaks water from bottom when brewing coffee or using steam unit
If it is coffee colored water, check the chamber under the white plastic valve behind the brew unit, that might be blocked with coffee grounds. If it is clean water one of the lines might need new o-rings.
Apr 14, 2010 | Gaggia Titanium Espresso Machine
Saeco Odea Go - Hot water leaks from bottom of machine
That's leaking from the hoses coming out from the boiler,if the machine is new it should be still under warranty, may have to take it back to the service center.When making coffee the lines are under pressure and the water never have a chance to pass through the ground coffee.
Feb 03, 2010 | Saeco Odea Go
Water leaking out the bottom of the coffee maker
If it leaks DURING brewing, you may have to decalcify it (aka, run through a cycle of 4 cups vinegar, fill to the top with water, 2-3 times and see if it helps).
If it leaks before you even start brewing a pot of coffee, something is broken on the inside of the coffee maker, and I would recommend contacting Waring--they may be able to get you a replacement coffee maker (and if you're under warranty, usually a replacement would be free!).
Their phone number (according to their website, www.waringproducts.com ) is 1-800-4WARING (1-800-492-7464)
Good luck! :)
Aug 27, 2009 | Waring Pro WC1000 Coffee Maker
Won't brew all the water comes out the bottom of the maker
Cuisinart – leaking from bottom
There is a tube inside that is melted, damaged - cannot get this part from manufacturer. I would call Cuisinart to see if you are still in warranty.
Here is the basic troubleshooting for the Cuisinart coffee makers:
Make sure all baskets are in proper place – especially if unit is beeping.
Do not use a paper and a gold-tone or other permanent filter at the same time.
Unplug for LONGER THAN 15 full minutes to reset.
Clean by brewing 2 oz of distilled white vinegar/2 oz water.
If these methods fail, the unit probably requires replacement – call Cuisinart as they have a longer-than-standard warranty.
-Tha Mp3 Doctor
Oct 20, 2008 | Cuisinart DCC-1200 Coffee Maker
Cuisinart Grind and Brew 10 cup coffee maker warm water leaks from bottom during brewing.
Replacement time. a certain percentage of thse have this problem. There is a small, non-replaceable tube in the inside toward the bottom that has become melted/damaged.
Oct 12, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Directions on how to use my Black and Decker Espresso Mio coffee maker
Be sure the red rubber gasket is in place and clean (ridge side in) and bottom water cup is screwed firmly on to avoid leaking.
HOW TO USE:
1) Fill the bottom water cup with cold water up to the inside lip.
2) Set funnel into bottom water cup
3) Fill coffee basket with expresso grind coffee and level off. (Do not tamp or pack). Make sure it's filled to the top.
4) Place filter onto coffee basket and set coffee basket into funnel
5) Place brewer over bottom water cup and screw firmly into place.
6) Place unit with lid in the center of a microwave oven set on high for 1-1/2 minutes. If boil over occurs, reduce the brew time in 10-second increments until no boil over occurs.
7) Grasp handle to remove unit from microwave when finished brewing.
8) Remove lid and check the level of espresso in the brewer cup. Standard brew is at least 2 oz. If you don't have this level brew, replace lid and microwave on high another 10 seconds. Wait 20-30 seconds for bubbling to stop.
CLEANING/ADDITIONAL BREWING:
1. Under cold running water, unscrew the bottom water cup. CAUTION: It is normal for some water to be left in the bottom water cup. Both the coffee basket and any water in the bottom water cup will be extremely hot! If you prefer, allow the unit to cool for at least 3 minutes before unscrewing it.
2) To brew additional espresso, rinse Funnel, coffee basket and filter, then repeat brewing steps 1-8 above.
3) Parts are top rack dishwasher-safe -- hand washing filter is recommended.
Mar 10, 2008 | Coffee Makers & Espresso Machines
DeLonghi Caffe Nabucco BCO70 Espresso/Coffee Maker Logo
172 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
