My Advent 7204 laptop bettery will not charge, I have replaced the battery and the power lead but fault remains.
  • 2,567 Answers
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Sep 15, 2010
Battery not holding charge and power lead has to be held in position for charging to take place
Use an ESD wrist strap with it's alligator clip attached to a good ground source.
Remove ALL power. Remove the AC adapter (Charger) and Battery.
Disassemble the laptop, remove the motherboard.
Replace the DC Power Jack. http://www.laptopdcjack.co.uk/product/Advent_6411_DC_Power_Jack_Socket_DC-ADV-6411
Information that may help to disassemble,
http://www.adventsupport.com/viewtopic.php?f=1&t=6770
http://www.uktsupport.co.uk/advent/laptop/6411v.htm
ftp://ftp.packardbell.com/pub/itemnr/7602080000/Disassembly_EasyNote_MZ_rev_100.pdf
(Advent 7211 series is like a P.B. MZ35 series. Just thought it may help)
http://www.youtube.com/watch?v=Im_n9K-14_I
Regards,
joecoolvette
Nov 25, 2012 | Advent Computers & Internet
Advent 7109b battery wont charge
Yes! it is very possible, specs are different in none original power adapters, because it sounds like the charging circuits are working. I recommend getting the original adapter for your model.
Apr 19, 2012 | Advent Computers & Internet
I have an Advent 7204 laptop two years old and suddenly it doesnt work anymore. When turning on, the lights which flash on went all the way through as normal then suddenly started fading and the machine...
I would suggest you to check with a different adapter, first.
You don't have to buy a new adapter for that.
Try to borrow from someone who has a compatible adapter.
Mar 13, 2017 | Dell Latitude D600 Notebook
Advent Netbook 4489
IT sounds like you need to replace your battery. If your laptop (notebook) is working properly while plugged in with Ac power we know it is not your power supply.
I would visit the manufacturer's website for replacement batteries. One complaint I have read about over and over on these particular systems is that the battery life is very poor.
Sep 17, 2009 | Advent Netbook
Bios password advent 7204 laptop
I dont know which kind of bios you have but trying to take out/disconnect the bios battery might help.
/BS
Feb 28, 2009 | Dell Latitude D600 Notebook
Advent 9912 wont turn on
remove the ac adapter
take the battery out
be sure nothing is connected with your laptop
then press and hold the power button for 60 secs to drain static as it is the most probable reason laptops stops working.
then connect the ac adapter only and without the battery try powering on the system
if it powers on
you can again shut it down
insert the battery
it should surely power on
Apr 20, 2008 | Dell 2600 Notebook
Computers & Internet Logo
161 people viewed this question
David Payne
David Payne
