Question about Bissell THE BISSELL LITTLE GREEN MACHINE Vacuum
I have power but no suction - Bissell THE BISSELL LITTLE GREEN MACHINE Vacuum
    Sniper:
  • 67 Answers
Im sorry to say, it sounds broken..... i know of this great site that sells bissell's for like half of retail check it out.....maybe your best solution....http://stores.ilikenew.com
Posted on Nov 17, 2010
    Problem Solver:
  • 5 Answers
Probably something plugging the hose or where the water goes into the recovery tank
Posted on Oct 11, 2010
If I put a smaller diameter hose on my shop vac will it create more suction power?
Yes, in one way the suction would be higher, but there would now be an additional load on the motor. Also, it would have more suction, but less volume (air flow).
Mar 18, 2015 | Shop Vac Vacuums
Hoover power drive supreme has no suction
If there is no suction at all, not even a little bit, then most likely the suction fan is broken. They aren't too complicated to replace if you want to.
Jun 08, 2014 | Hoover U6311-930 Power Drive Bagged...
Miele Silver Moon Losing Suction
if there's no blockages and filters all OK it's probably the suction fan that as worn down and not creating as much suction..
May 02, 2013 | Miele s558 Silver Moon Vacuum
How do I switch the vacuum from floor to accessory suction
It automatically switches over when you disconnect the hose from the power nozzle. No suction it getting to the power nozzle, so the suction is only through the attachments. If there is no suction through the hose, check for clogs in the hose and in the tank where the hose plugs in. Also, check the screen at the bottom of the tank. If there is a clog in the hose or tank, then there also will be no suction to the power nozzle.
Remove all clogs and you should get suction.
Dec 19, 2010 | Hoover U5721-900 WindTunnel Upright Vacuum
No suction & brush will not turn when power
Check your belt. It is broken or stretched out. Replace the belt first. Should be your answer
Nov 09, 2009 | Hoover Elite Rewind Bagless Upright...
The machine will not suction - it will spray and spin the brushes but will not suction - the power is going to the machine, but it will not suction.
Disconnect the suction hose. While running, check the suction port if it works, by putting a piece of paper. If the paper is taken in, then it is oK. Now, check the suction Hose for breaks or opening before the suction head. Breaks or opening breaks the suction power at the suction head. Loose connection between the suction pipe and the suction port also must be check as this will also cause the same
problem. You may need to replace the suction hose
to correct this problem,
Send us the e-mail and your vote if this solves your problem.
Sep 27, 2009 | Eureka Atlantis 2590A Wet/Dry Vacuum
My VAX Vacuum has lost ALL suction power. I've
vax power pet 1 filter keeps getting clogged up so dirt not going into cylinder
Jul 05, 2009 | VAX Appliances Vax X5 Bagless Upright...
How to for Belt replacement and solution to suction loss
You say it lost its suction, then you also say this is plenty of suction power, seems you cant figure out the prob. Try cleaning the fan on the suction blower. The blades can get chocked with dust which will give you a reduced suction.
Jan 05, 2008 | Vacuums
Power unit suction problem
Have you checked the filters?
Nov 15, 2007 | Electrolux Central Vacuum
Bissell THE BISSELL LITTLE GREEN MACHINE Vacuum Logo
108 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
