Can anyone help me to find a remote control fot the air con model TECO 5M000C345G024.
My teco air con turn on/off manually but not with the rote while the same remote used to work last yeat I cant change the temperature settings can anybody help me to change the temperature manually.
As far as I know you will need the remote to change the temperature
Check the operation of the remote with a digital camera or cell phone camera - hold the remote close to the camera and press any button - you should see a while flash in the camera - if not either the batteries are faulty in the remote or the remote is faulty
Good luck
Jan 07, 2016 | Heating & Cooling
WHAT IS FAULT CODE 00 01 Ad on Teco LU160DHRA1 Air Con
Carrier Split Air Conditioner Error Codes - AC Error Code
acerrorcode.com/carrier-split-air-conditioner-error-codes.html
Jan 25, 2015 - REMOTE CONTROLLER FOR AIR CONDITIONER (SPLIT TYPE). Carrier Split Air Conditioner Error Codes. 00-01-02-03. 11-12-04-05.
Nov 25, 2015 | Heating & Cooling
Remote not communicating with air con
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Mar 15, 2015 | HQRP Universal A/C Remote Control...
I have a teco air con model LA0814C i attempt to set temp to 23 on cool and it just keeps going back to room temp and won't cool ?
Best bet is to call Teco tech support. It looks like another rebranded gree or shinco unit to me. Since teco is still in business, they should be able to help you figure out what's going wrong.
Contact Us
Please mark his answer as helpful.
Jan 06, 2015 | Heating & Cooling
Teco air conditioner LS1826H fault code F2
F2 on this model means that the indoor unit pipe sensor has failed. You would probably need someone who is at least a licences electrician or preferably an Air con tech to repair this. You will need a new pipe sensor. Contact Teco Australia who can put you in touch with your nearest service Agent.
Sep 09, 2013 | Electronics - Others
I have an old Kelvinator air conditioning. Not sure what the model is since I have lost the manual, but from the remote control I can see some code looking like the model number: 6711A20012M. A few weeks...
You're right! It's receiving sensor problem with your PCB. Only repairman who knows electronic tech could only repair. I could say the cost of repair in Indian Rupees IRS.850/- maximum. Hope it's helpful?
Dec 25, 2010 | Heating & Cooling
I need operating instructions for a teco air con model LT2424YS
I have an TECO Model 7K34STC, that has the two end bearing & housings missing from the opposite end to the motor.
Could anyone tell me of a parts supplyer in Florida U.S.A.
Please reply to
Peter Lawrence
brin4512@hotmail.com
Jun 28, 2009 | Heating & Cooling
Cant get air con to work it is a teco air conditioner
Ours did the same. My husband checked the manual and found that the filters were FILTHY! The filter is at the front of the inside unit. If you still have the manual it will show you where. This fixed ours as it was NOT working at all!!
Mar 01, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
