Red lite comes on no sound or picture - Televison & Video
  • relyard Sep 17, 2010
    hi model sharp lc32le600e thanks roger
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please post back with name of the manufacturer and model number# to provide you with model specific information.
Thanks
Rylee
Posted on Sep 15, 2010
  • Rylee Smith
    Rylee Smith Sep 17, 2010
    From
    what you have described it seems the issue is with the power board or the main
    board and we'll need to check few things. When you open the unit up; take a
    look at the power board-the board where the power cords/plugs goes into. You
    might see some filter capacitors a little bulged up in the top-If this is the
    case-this is your defective part(you can try to replace them-but some soldering
    equipment is needed). If not, then probably the main board has gone bad. This
    is the other board-where all the inputs are going into. All this is only
    recommended if you have electrical expertise and know how to solder/re-solder
    components. Please note that the TV components consists high voltages even when
    in off position.
    Please
    do accept the solution if the issue is resolved or post a comment for further
    assistance.
    Thanks
    Rylee
    From what you have described it seems the issue is with the power board or the main board and we'll need to check few things. When you open the unit up; take a look at the power board-the board where the power cords/plugs goes into. You might see some filter capacitors a little bulged up in the top-If this is the case-this is your defective part(you can try to replace them-but some soldering equipment is needed). If not, then probably the main board has gone bad. This is the other board-where all the inputs are going into. All this is only recommended if you have electrical expertise and know how to solder/re-solder components. Please note that the TV components consists high voltages even when in off position. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
Sony kdf-37h1000. push power button and the green lite comes on steady and i can hear a fan. never gets to a picture or sound. it then sounds like it shuts power off but lite goes from flashing green to...
Hi catfishbob,
You're lamp came to its peak burning life and now its dead that's why you can't power up the unit and the led light keeps flashing. Once the lamp replace with new one your unit will back to normal again. Click this link for the replacement http://shop.ebay.com/i.html?_nkw=KDF-37H1000&_sacat=0&_odkw=sylvania+ld370sc8s&_osacat=0&_trksid=p3286.c0.m270.l1313.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Mar 05, 2011 | Sony KDF-37H1000 37" HDTV
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
No sound or picture, 2004 pt50dl54j
remove back panel. blow out all the dust from all the components except the fan on the right.
Vacuum out all the dust.
Have you replaced the lamp? that would help too.
There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
Jun 13, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Red lite comes on but tv will not power up.
Follow the solution for service port 'jump start' with a usb plug. Plug your cell phone charger in next to the TV. Touch the metal prongs of the service port with the metal part of the usb until you get a brief 'flash' on the TV. Then turn on the tv set. It takes patience and a flash light to do this, so you can see what your touching, as my husband couldn't get it to work, but I could.
Apr 20, 2009 | Olevia LT23HVX 23 in. LCD Television
No sound no picture flashing red lite
try to put heat on the back of the tv with a hair blower and wait 30 sec then turn it on
Jan 22, 2009 | Philips 42FD9954 42 in. Plasma HDTV
Green lite comes on for about 2 to 3 seconds then shuts down red lite pulses
If the back was off the board on the left is your Ysus board. It will have a cable plugged into the right side of the board from the signal board. Unplug the the Ysus board. If it stays on without a picture change both Y and Z sustain boards. If this helps let me know.
Oct 15, 2008 | Philips 42FD9932 42 in. Plasma Television
I have a 56" rear projection panasonic tv when i turn it on green lite come on then a lamp lite comes on red no picture or sound lamp lite flashing
Doulbe check in the owner's manual, but this is usually an indication of a bad lamp or fan error. There will be a table in the owner's manual listing the error codes as shown by these lights. I can't give you more details without the exact model number.
hope this helps,
Dan
Sep 08, 2008 | Televison & Video
Broken
there is a L2 <, always come lose from solder when it is drop the ds lite or at least that was what happen with mine once
Jul 08, 2008 | Nintendo DS Console
Lamp lite
Does the lamp indicator stay yellow, or does it turn red?
May 17, 2008 | Mitsubishi WD-52531 Television
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
