DrayTek Vigor 210 Modem : Cant get it to see my Apple Extreme Base Station ISP is o2.
remt23c
  • 78 Answers
SOURCE: disabled dhcp, cant access router with browser
the default ipaddress for that is 192.168.0.1 you will need to set your computer with a ip address like 192.168.0.2 then you should be able to access it. be sure to change your computer back to DHCP after you reset the router
Posted on Dec 26, 2007
  • 17 Answers
SOURCE: New Apple Airport Express Base station blinking amber light
Using the Airport utility on your macbook (located in your Utilities folder) will tell you what the conflict is.....most likely you have DHCP issue or the network is at the incorrect setting.
The wizard in the utility will tell you what you should fix.
Posted on Feb 15, 2009
  • 5 Answers
SOURCE: apple extreme bridged to apple extreme (Windows network)
Using a wired connection:Using the Airport Utility, set up the extreme wireless with the same network name, security and password as the 2Wire but use a different channel. On the Internet Tab, change Share a Public IP address to OFF Bridge Mode. Click on Update Button.
Using a wireless connection: You will need 2 Apple devices, at least 1 Extreme and the second can be either an Extreme or Express. Replace the 2Wire with the extreme and using Airport Utility, set to "Allow this Network to be Extended". Set the second to "Extend a wireless network".
Posted on Dec 24, 2009
anandg27
  • 1272 Answers
SOURCE: LAN connections dropped
Well, this make of the router DGN2000 has been diagnosed with hardware failure. I would suggest you to contact NETGEAR and get a replacement from them.
You can log a complaint with them at my.netgear.com
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Feb 17, 2010
Testimonial: "Very helpful... also see comment"
APPLESUPPORT
  • 70 Answers
SOURCE: how to use apple time capsule and apple base
Basically Time capsule is same as Airport extreme base station added with a hard drive to take wireless backup.Put same Network Name and password in both Time capsule and airport base station.Suppose your are making TC as a primary base station and Airport extreme as a secondary base station. Select WDS in both the base stations .In "Wireless Mode" select"Participate in WDS network" in both the base stations.Dont change rest of the options.Put TC Mac id to Extreme base station and extreme Mac ID to TC.now open the airport option in your laptop and check.you can see a single network name.Its DONE.Njoy using wireless
Posted on Apr 12, 2010
My router keeps signing me out of psn, yet it will allow me to talk on skype and surf the internet on my laptop without any problems, what can i do?
SOMEONE HELP ME OUT WITH THAT TOO I HATE THIS DRAYTEK VIGOR 2830N ROUTER , MY BROTHER GOT IT AND I CANT CHANGE IT!!!!!!!!!!!!!!!!!!!!!!!!!! IT KEEPS SIGNING ME OUT ESPICALLY ON WIRELESS!!!!! HELP ME
Nov 01, 2012 | Draytek Vigor 2830n-plus Wireless Gigabit...
How can i set up my router?
The Draytek Vigor router supports USB-based Wide Area Network, or WAN, modems. It has four 10/100 Base-T ports, Network Address Translation IP packet filtering firewall, Demilitarized Zone and Virtual Private Network. The initial setup requires installing the firmware. Then, connect the USB router to the modem, in order to upload the firmware automatically to the modem.
Mar 07, 2012 | Draytek Vigor 2600VG Wireless Router...
The router is blinking a yellow light
Here are some of the more common reasons that the status light may blink amber:
  • The Wi-Fi base station has not yet been configured because it is new.
  • The Wi-Fi base station has been reset.
  • A new firmware update is available for the Wi-Fi base station.
  • No IP address is available for the Wi-Fi base station.
  • A Wi-Fi base station in Extended Mode is out-of-network Wi-Fi range of a primary Wi-Fi base station.
  • The WAN Ethernet cable is unplugged from the Wi-Fi base station.
  • The Wi-Fi base station lacks a path to the Internet (or local router).
  • Internet access may be temporarily unavailable from your Internet Service Provider (ISP).
  • Your AirPort Time Capsule has detected that the internal hard drive has reported a SMART error, and is failing (This requires firmware 7.5.2, and AirPort Utility 5.5.2).
Feb 10, 2011 | Apple AirPort Extreme Router
How to use apple time capsule and apple base station together?
Mar 31, 2010 | Apple MacBook Pro Laptop Computer with...
Base station won't connect to isp
Change your internal network from 192.168.1.x to 10.0.1.x...many times you find smaller ISP's that use the default address scheme and cause conflicts with the default address used on most routers, etc.
Jul 17, 2009 | Apple AirPort Extreme Base Station
Apple AirPort cannot get IP address from cable modem using DHCP
go to applications,utilities and go to airport set up and check the settings, it could need the DHCP setting up or the old settings deleted
May 24, 2009 | Apple AirPort Extreme Router
Cant connect to internet with Airport Extreme 802.11n
An airport extreme is just a dunb Wireless Access Point. It could be that it has been mated to the Linksys router and is looking at a different set if IP addresses that are not coming from the etherent connection out of the wall.
If you know how to obtain network addresses on your computer, find out what you get from the wall jack and from the airport through the Linksys. You can try to reset and reconfigure the Airport, but if you are not familiar with the hardware, get someone who is to help you. The manual offers several tips and procedures to do this http://manuals.info.apple.com/en/AirPortExtremeBaseStationSetupGuide.pdf
Carl
Oct 09, 2008 | Apple AirPort Base Station
Draytek Vigor 110 modem
There is no default username or password to access the Vigor routers. Reset the router to clear any previous settings from its memory. Default IP Address is http://192.168.1.1 Manuals and firmware is available from the device maker.
May 17, 2008 | Draytek Computers & Internet
Wireless Modem don"t connect
well imac G4's don't  have built in airport (wireless internet) included as usual with apple its another item you must buy an airport extreme card  then hook it up to an airport base station another item to buy via wireless internet then hook you airport extreme base station up to your modem via ethernet. whew ok now sync the airport base station to your imac using airport set up application then select your network and type your WEP password and viol internet in about 1 hour if your lucky hope this helped my fingers hurt now LOL.
Apr 07, 2008 | Apple iMac G4 Desktop
Draytek Vigor 2600we
I do not have one of these devices however from the specs it is a combination DSL modem / Router that supports both wired connections to 4 ethernet ports as well as wireless connections. This device has configuration options that apply to the ISP side as well as the wireless side that could be causing issues. Lets try eliminating the wireless issues first. Do you have a computer with an ethernet port for a wired connection. If so attempt to connect to the internet using a wire to the ports on the wireless router. If this works we are assured the ISP connections and configuration are correct. If not I would suggest working with your ISP to get this working first. If this does work the next step will be to review the wireless configuration. If you got this new or from your ISP these settings may be known. However if you bought this used we may have some discovery to make this work. However we can address that after we determine the solution to the above issues.
Dec 01, 2007 | Draytek Vigor 2600We (Vigor2600WE)...
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
